Good Morning
I am trying to plug my sony laptop into my Sony Bravia 46''LCD. I am using a SVGA cable ( decent cable make) From my laptop into the PC input to the back of the TV. I have changed the settings on my laptop to include monitor 2, and changed the graphic output to monitor. All I see on my TV is ''unsupported signal''
Can some one please assist
Thanks in advance
Julie
May I know whether you are using onboard graphics card or an installed graphics card like nVIDIA or ATI? If you are using the latter then yuo can directly connect using the DVI port. The ouput signal from your DVI port will be HD by default and no adjustments are required. Just plug and play!
"Unsupported signal" suggests one of two things. Either the refresh rate on your computer is set too high (it MUST be at 60 Hz.) or you have the display resolution set too high
Hi Julie,
There are a couple ways to go here. I'll give you the procedures step by step. If you want clarification on anything, just ask. If I make an assumption that is wrong, stop me and let me know. The more you know, the easier this will be for both of us.
First I'd like to double check on MisterSony's diagnosis. Refresh rates that are too high end up as a black screen on many LCD models.
This is my first assumption, the display settings are currently for both monitors. Your original screen is still functioning.
If so,
Get back to me with the results. If it was already set at 60Hz. We go to the next step.
Mike
Thank you for your help - although i am still only seeing upsupported signal on my TV screen. I will continue to try and resolve the problem.
Many Thanks
Julie
the set power off then right back on when one particular commericial comes on.
no inputs
