2000 Volkswagen Beetle Logo
Posted on Nov 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power Mirror Switch
I would like to input switch press to output rotation of mirror of power mirror switch. Can you provide information for the same.
Everything related to power mirror switch mechanical and electronics included in it.
i am happy if you post few documents related to power mirror switch
Colin Stickland
Level 3:
  • Volkswagen Master 22,516 Answers
  • Posted on Nov 15, 2008
Colin Stickland
Volkswagen Master
Level 3:
Answers
22516
Questions
Helped
6998201
Points
66324
Change the wires around on the switches ,practice makes perfect
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1698
Points
Where is the switch to adjust side mirrors on a 2000 beetle
I have a 2002 Pontiac Booneville SE. The interior lamps, door locks, windows and sun roof do not work but I still have power to the mirros on the doors. What could be the problem?
Mirrors are separate from the other things.
Driver and Passenger Outside Mirror Operation
In order to control outside rear view mirror adjustments, two switches are contained within the driver door switch assembly (DDSA). The DDSA contains a built in mirror select switch and a built in mirror position switch. The DDSA reports the switch activity to the driver door module (DDM).
The mirror select switch is used to select which mirror, left or right, is to be moved.
The mirror position switch is used to move the mirror that has been selected to the desired position. When the mirror position switch is activated in a Up, Down, Left, or Right direction, the DDSA recognizes the input and sends this data on to the DDM via the power door serial data circuit. Depending on which mirror has been selected for adjustment, the DDM either moves the driver door mirror to the requested position, or sends a power door serial data message to the passenger door module (PDM) indicating that the passenger door mirror needs to be moved. The PDM then moves the passenger door mirror to the requested position.
Each mirror has two reversible motors for position adjustment. The door modules control the reversible motors by supplying Battery Positive Voltage (B+) and ground to these motors.
Outside Mirror System Components
The power outside mirror system consists of the following components:
• Driver door switch assembly (DDSA)
• Driver door module (DDM)
• Passenger door module (PDM)
• Driver outside mirror
• Passenger outside mirror
• Power door serial data circuit
• DRV MDL 10 A fuse (door module logic and internal driver operation)
• PASS MDL 10 A fuse (door module logic and internal driver operation)
Power Windows Operation
The vehicle is equipped with power windows controlled by the door modules. Each passenger door power window can be operated, either from a switch built into the driver door switch assembly (DDSA), or from a switch mounted locally on its associated door. The driver door power window can only be operated from the driver door window switch built into the driver door switch assembly (DDSA).
When the driver door module (DDM) receives a window switch request from the DDSA, the DDM checks the Class 2 serial data to see if the status information is correct (i.e. ignition switch position) to permit window operation to occur. If the status information is correct, the DDM, either supplies power and ground to its associated window motor, or, if the request is for one of the passenger windows, sends a command via the power door serial data circuit to the passenger door module (PDM, LRDM, or RRDM) controlling the window. The passenger door module (PDM, LRDM, or RRDM) controlling the window then supplies power and ground to its associated window motor to move the window as requested.
When one of the local window switches mounted on one of the passenger doors is operated, the associated door module examines the request and checks to see if there are any messages from the DDM prohibiting the movement. If conditions are correct, and no prohibitive messages have been received from the DDM, the associated door module then supplies power and ground to its associated window motor to move the window as requested.
The thing to do first would be to hook up a factory or some other type professional scan tool an check for DTC'S - diagnostic trouble codes.
DTC B3377, B3382, B3387, B3392, B3397, B3452, B3457, B3462, B3467, B3472, B3477, B3482, B3517, or B3522
Circuit Description
The switch that failed and generated this diagnostic trouble code (DTC) is part of the driver door switch assembly (DDSA). The DDSA contains a microprocessor which takes the signal generated by this switch and assigns a digital message to it. The DDSA then sends this message over a power door serial data circuit to the driver door module (DDM).
Same thing for locks.
The DDM must be powered and must not have DTCs B1327-Battery Low Voltage or B1328-Battery High Voltage set for this DTC to set.
Your best bet might be to find a good auto electrician.
Which fuse controls front windshield wiper pump
Do the wipers work ? Fuse for wipers is same as washer pump .
Principles of Operation
The wiper motors receive inputs from the following:
  • Multi-function switch
  • Powertrain control module (PCM)
  • Ignition switch
  • Smart junction box (SJB)
The following components are integrated in the wiper motors:
  • Windshield wiper motor module
  • High/low speed relay
  • Run/park relay
  • Washer pump relay
  • Park sense (Hall-effect sensor)
Washer System
The windshield washer and the rear window washer are activated by the internal wiper motor modules when it receives a ground from the multi-function switch between the washer inputs. Depending on the correct ground, the internal wiper motor modules activate either the windshield washer or rear window washer relays (internal) by grounding the respective relay coil. When either module is activated, it connects voltage to the washer pump while the deactivated module provides ground to the washer pump. In this manner, voltage polarity is reversible to achieve directional change of the washer pump and washer fluid.
  • The washer pump is inoperative
  • Circuitry
  • Washer pump
  • Rear window wiper motor
  • Go To Pinpoint Test I .
Does your expedition have programmable/recall memory option for seats an mirrors ?
Driver Seat Module
The power driver seat and power exterior mirrors are controlled by the driver seat module (DSM) only when the vehicle is equipped with the programmable/recall memory option.
On the Expedition Limited, the power fold exterior mirror option is controlled by the DSM. Before running a self-test or retrieving codes, the power fold switch must be inactive for at least 30 seconds.
This is a complex vehicle , electronics , control modules an serial data communication networks. You mite be better off taking it to the dealer or some other repair shop . There could be DTC'S - diagnostic trouble codes stored in the SJB - body control module !
B1667 Mirror Driver Up/Down Motor Stalled Go To Pinpoint Test D . B1668 Mirror Driver Right/Left Motor Stalled Go To Pinpoint Test D . B1669 Mirror Passenger Up/Down Motor Stalled Go To Pinpoint Test D . B1670 Mirror Passenger Right/Left Motor Stalled Go To Pinpoint Test D . B1735 Mirror Driver Vertical Switch Circuit Short to Battery Go To Pinpoint Test D . B1739 Mirror Driver Horizontal Switch Circuit Short to Battery Go To Pinpoint Test D . B1743 Mirror Passenger Vertical Switch Circuit Short to Battery Go To Pinpoint Test D . B1747 Mirror Passenger Horizontal Switch Circuit Short to Battery Go To Pinpoint Test D . B2312 Mirror Horizontal Feedback Potentiometer Circuit Failure Go To Pinpoint Test D . B2314 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Battery Go To Pinpoint Test D . B2316 Mirror Passenger Vertical Feedback Potentiometer Circuit Failure Go To Pinpoint Test D . B2318 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Battery Go To Pinpoint Test D . B2320 Mirror Driver Horizontal Feedback Potentiometer Circuit Failure Go To Pinpoint Test D . B2322 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Battery Go To Pinpoint Test D . Normal Operation During normal operation, when the front wiper wash is selected, the windshield wiper motor provides power to the washer pump through circuit CRW14 (BU/WH) and ground is provided to the washer pump through circuit CRW12 (GY/OG) and the rear wiper motor. If rear wiper wash is selected, the rear wiper motor provides power to the washer pump through circuit CRW12 (GY/OG) and ground is provided to the washer pump through circuit CRW14 (BU/WH) and the windshield wiper motor.
    Possible Causes
  • Open in circuit CRW14 (BU/WH), CRW12 (GY/OG), CRW07 (GY/BN), CRW20 (GY/YE), SBB49 (RD) or GD149 (BK/GY)
  • Short to ground in circuit CRW14 (BU/WH), CRW12 (GY/OG), CRW07 (GY/BN) or CRW20 (GY/YE)
  • Washer pump
  • Rear wiper motor
    This is
How to fix a power mirror
First check that you have voltage to the switch with a 22 volt test lite then trace the wire down to the mirror motor on the mirror press the switch if the test lite glows change the mirror if know lite comes on when you press the switch while probing the window motor wires change the switch
2007 gmc heated mirror module
Could have a DDS an PDS .depends on what RPO code yours has >
Outside Mirror Description and Operation (with RPO DL3)
Or
Outside Mirror Description and Operation (without RPO DL3)
Without
Heated Outside Rearview Mirror Operation
The REAR DEFOG relay controls the operation of the heated outside rearview mirrors. When rear window defogging is requested, the REAR DEFOG relay is energized and B+ is applied to the supply voltage circuit of the mirror heater element, located in the mirror face. A constant ground is also applied to the mirror face. Current will pass through the mirror heater element, warming the mirror, so long as the rear window defogger is commanded ON.
With
The DDS and PDS control the activation of the mirror heaters. Upon receiving a serial data message indicating a request for heated mirrors, the DDS and PDS, will apply voltage to the mirror heater element supply voltage circuit. The mirror heaters will remain active until a new message is received indicating rear defogger is to be deactivated.
The power mirror system consists of the following components:
• Driver Door Switch (DDS)--An electronic control module with integrated switches and requires programming when replaced
• Passenger Door Switch (PDS)--An electronic control module with integrated switches, requires programming when replaced
• Power Mirror Direction Switch--Integrated into DDS and is a four position momentary switch that provides a signal input to the DDS for up, down, left/extend and right/retract with a mirror switch activation
• Mirror Select Switch--Integrated into DDS and is a three position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• Mirror Extend/Retract Switch--Integrated into DDS and is a two position switch that allows the operator to select the mirror extend or mirror retract position
• Left Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Right Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Body Control Module--An electronic control module that requires programming when replaced, serves as the power mode master and is the main message handler
• Horizontal and Vertical Position Sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDS/PDS and provide a variable voltage signal to the DDS/PDS that is proportional to mirror position
• Folding Mirror Motor, in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Your best bet mite be to take to a qualified repair shop , i really don't think you'll be able to do anything with it.
Do you have wiring diagrams so you know which wires to test ,do you know how to do electrical testing ?
The Driver Door Switch (DDS) and Passenger Door Switch (PDS) supply voltage to the outside rearview mirror heater elements upon receipt of a serial data message from the HVAC module indicating that the rear defrost system is active. The door switch supplies B+ through the driver/passenger mirror heating element supply voltage circuit when a request is seen. Ground is applied through the driver/passenger mirror heating low reference circuit.
2001 explorer sport trac side mirros not working"
did you check power mirror fuse? if ok, remove your power mirror switch at the driver side and clean the contact area, take a test light and check all wires for good connection. one by one test the voltage output,-/+ by pressing the switch, if all wires have output -/+ , and mirrors still not working, remove the switch connector, find out the three wires going to power mirror and direct it to - and positive voltage alternately, if the mirrors move, repair the wire that cut on the moving area, if still not moving repair or replace the two motors inside the mirror
2008 Chev Suburban 4wd Z71 1/2 ton; several items on my passenger side stopped working: my passenger side front seat heater stopped working; the passenger side electric mirror stopped working; the signal...
Power windows an locks work ok ? Do you know anything about automotive electeronic control modules ?
Power Mirror System
Power Mirror System Components
• Power Mirror Direction Switch--Integrated into DDS and is a 4 position momentary switch that provides a signal input to the DDS for up, down, left/extend and right/retract with a mirror switch activation
• Mirror Select Switch--Integrated into DDS and is a 3 position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• Memory Switch, if equipped with memory mirrors--Supplied power by the DDS and provides a voltage signal to the DDS upon a switch activation
• Powertrain Control Module (PCM), if equipped with memory mirrors--An electronic control module that requires programming when replaced and provides the message indicating transmission gear selection
• Driver Information Center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a an electronic control module that requires programming when replaced and is used to personalize the memory recall functions
• Fold Motor, in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
Do you know what DTC'S - diagnostic trouble codes are ?
DTC B1023
Circuit/System Description
The driver door switch (DDS) and front passenger door switch (PDS) each contain switches that control power door lock and window functions. The DDS also contains the control switch for the power outside rear view mirrors. These switches are integrated within the door control modules and are not serviceable as separate components. The DDS and PDS monitor these switch inputs for internal faults and set B1023 00 if any are detected.
You could have any number of problems an without testing , hooking up a scanner that can check DTC'S in the door module ,electrical circuit testing etc... we'd only be guessing . Your best bet mite be to take it to a qualified repair shop.
2003 gmc mirrors do not fold in
The power mirrors are controlled by a module (computer) DDM - drivers door module an the PDM - passenger door module .
Folding Mirror System
Folding Mirror System Controls
The folding mirror system requires signals from 2 separate switches. The mirror select switch must be in the neutral/fold position and the mirror direction switch must be activated to the left/extend or right/retract positions. Both switches are integrated into the DDM and provide direct signals.
Folding Mirror System Operation
Upon receipt of the required switch inputs the DDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function. The DDM will also send a class 2 message to the PDM indicating the requested function. The PDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function.
Power Mirror System
• The driver door module--Class 2 module with integrated switches and requires programming when replaced
• The passenger door module--Class 2 module with integrated switches, requires programming when replaced and also contains the RFA receiver
• The power mirror direction switch--Integrated into DDM and is a 4-position momentary switch that provides a signal input to the DDM for up, down, left/extend and right/retract with a mirror switch activation
• The mirror select switch--Integrated into DDM and is a 3-position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• The left outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The right outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The body control module--Class 2 module that requires programming when replaced, serves as the power mode master and is the main message handler
• The DDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The PDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The memory switch, if equipped with memory mirrors--Supplied power by the DDM and provides a voltage signal to the DDM upon a switch activation
• The horizontal and vertical position sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDM/PDM and provide a variable voltage signal to the DDM/PDM that is proportional to mirror position
• The park neutral position switch, if equipped with memory mirrors--Provides transmission gear selection information to the PCM and is used for memory recall and mirror tilt in reverse functions
• The powertrain control module, if equipped with memory mirrors--Class 2 module that requires programming when replaced and provides Class 2 message indicating transmission gear selection
• The driver information center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a Class 2 module that requires programming when replaced and is used to personalize the memory recall and mirror tilt in reverse functions
• Fold motor in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
DTC B1722
The driver door module (DDM) and passenger door module (PDM) switch the mirror fold motor control circuits to battery voltage and ground in response to mirror extend or retract command.
Power mirrors don't work. Which fuse controls this
Here is repair information from Mitchells:
1) Disconnect power mirror switch connector. Connect test light between power mirror switch harness connector terminal "A" (orange wire) and ground. If test light illuminates, go to the next step. If test light does not illuminate, repair open in orange wire between power mirror switch and righ rear power distribution center fuse block No. 1 (located under left side of rear seat).
2) Connect test light between power mirror switch harness connector terminals "A" (orange wire) and "J" (Black wire). If test light illuminates, check for poor connections at the power mirror switch. If connections are okay, replace power mirror switch. If test light does not illuminate, repair open in Black wire between power mirror switch and ground.
Electric Mirrors do not work (Drivers & Passengers)
There are two power wires to the DDM - drivers door module .Both are orange ,one is powered by a fuse DDM fuse 15amp . in the left I/P fuse block , plus LT DOORS 25amp circuit breaker .
Do you know what DTC'S are ? Diagnostic trouble codes
DTC B1544, B1600, or B1605
DTC B1580, B1590, B1610, or B1620
• If DTC B1580 is set by itself, the left horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1590 is set by itself, the left vertical position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1610 is set by itself, the right horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1620 is set by itself, the right vertical position sensor signal circuit maybe open, shorted to ground or battery.
• If DTCs B1580 and B1590 are both set, the left 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
• If DTCs B1610 and B1620 are both set, the right 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
Need a factory scan tool to test !
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Driver Door Module (DDM) and Passenger Door Module (PDM) data lists.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
0.50-4.75 V.
Your best bet , take it to a GMC , Chevy , buick or cadillac dealer
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
