Is it possible that norton ghost 3 have a probleme with new thecnologie of pc(double core and pci e video card etc..)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 59 Answers
Check their applicable sites faq for possible compatibility issues.
Posted on Nov 15, 2008
Disable integrated graphics
I assuming you want to install a new video card. Enter the BIOS and change from "onboard" to maybe PCI, PCI-e ,PCI 1x etc, shutdown the PC install your card. Start PC and install the software for the new GPU if windows 8 doesn't have a driver of its own.
Jul 13, 2014 | HP Pavilion P6-2390 Desktop PC with Intel...
Why is dell optiplex 780 lights 1 & 3 ok and power button amber?
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.
Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 28, 2014 | Dell OptiPlex 780 MT Desktop Computer...
Yellow Amber light on Dell Optiplex 390 not booting or display what to do?
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 21, 2014 | Dell Precision 380 P4 Dual Core 3 GHz...
Video Card
Wow, I think/know you went down the wrong path would you like to try troubleshooting with me?
Mar 19, 2014 | Acer Computers & Internet
We installed a new internet card to our hp a6300f but for some reason when it is plugged in the pci slot the video card in the pci express slot stops working any help as to why?
New one on me too sorry i have no suggestions other than try a different brand ethernet card or possibly the new one you have is faulty. Could you please post when you do find the solution im very curious now......good luck from Scott
Oct 21, 2010 | HP Pavilion Desktop a6300f Intel Pentium...
Don't know how to restore files from backup done with North Ghost
Using Norton Ghost 9.0 is very good program to backup your System & Documents.
You said the PC is dead then you want to restore back your System to a new PC.
All you have to do is that Norton Ghost 9.0 CD is Bootable.
Of course also your external hard drive are plug in it too.
Manually you're going to open that Sv2i file to restore back again your old system but there are some programs that are not going to use. Like for example: System Drivers (Motherboard Driver, LAN, SOUND, etc.) but at least you have the Documents and the rest of the programs run again.
I try it myself this kind of situation, I'm using Windows 2000 with Norton Ghost 9.0 version, and it's 100% works. Good luck!
Hope i might give you some tip & idea.
Tell me more about if you got a problem.
Please rate me.
Thank you.
Sep 04, 2009 | Symantec Norton Ghost 9.0 for PC
More compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
Faulty motherboard?
bullnosestep
It is possible that the new (secondhand graphics card) was faulty and sent an incorrect voltage to part of your motherboard (frying it). However in my experiance it is not likely, I have installed and un-installed 100's of video cards over the last 10 years many of them faulty and only on one ocassion did it ever damage the board.
Things to try:
Double check (triple check) that your card is seated properly in the pci-e slot, this is one of the most overlooked things and is one of the most common problems when installing a new video cards. It may be drawing power from the slot but could still be slightly out of line.
Also most new ish psi-e card require an additional power supply direct from the PSU, did you connect this up if needed. (don't know what make the graphics card is so just in case)
Remove the cards and check the slot for dust and dirt, quite often when you remove an old existing card you can dislodge dust/durt from around the slot pushing it into it, thus making a bad connection to the video card. Blow the slot clean with a compressed air cleaner, can should cost £5-£10, don't use vacuum on the motherboard as this can cause extreme levels of static.
Are you sure you didn't knock a component on the motherboard during installation?
If you have tried all these things then you may have a damaged board. You could take it to a repair outlet to check the board over. They would be able to check the voltages etc... and may be able to locate the trouble.
The Pci-e slots can be replaced and re-soldered but it is a very skilled operation, to be fair you would be much better off buying another board. Lets face it, the slot is probably ok, you may have blown something elsewhere on the board.
Hope this helps and let me know if you solve the problem
Bri
Feb 01, 2009 | Computers & Internet
Trying to reinstall norton ghost v14
you need to remove Norton with Nortons own removal tools. Add/remove program not the same thing as it leaves stuff in the registry. Go to norton.com and get removal tool..Run it, then try the re-install.
Dec 27, 2008 | Symantec Norton Ghost 14.0: Windows
Computers & Internet Logo
23 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
