Question about Nokia 6600
Sending bluetooth message
Allways sending bluetooth messages automatically
Hold Call key (Green key) + * key + 3 key + power button then results the format of the cell you been using with this you can be depart from the problem
Posted on Nov 16, 2008
Stop receive and send messages sms allways after press send it display
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Sep 26, 2012 | Sagem Puma Cell Phone
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you
select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed
My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running
on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery
application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon,
the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already
exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the
devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new
search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to
be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and
the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a
passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device
to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the
device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via
Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the
devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for
both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is
shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the
message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Hope it helps .
Fill free to pass your comment.
Thanks for using fixya...
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
HOW DO I TRANFER DATA FROM THE MESSAGING FOLDER IN A NOKIA N79 TO ANOTHER MOBILE USING BLUETOOTH CONNECTIVITY.
hello,you can not send it from the messaging folder except you save it to another folder then you will be able to send it through bluetooth.simply because every content in the message folder could only be sent through sms or saved to another foolder.kindly go to options you will definitely see save to folder or you create a folder and move it there for you to be able to send it through bluetooth.
wish you good luck,
take care.
Apr 23, 2010 | Cell Phones
Hi...I have motorola v750 and when I try to send any video it allways ask to send the video via bluetooth. I don't have or ever had a bluetooth with this phone. any help? thanks
You do not have a BT but you do have IR on your phone. You can send the video tp your PC via Infra Red. If you do not have an IR facility on your PC then attach an IR dongle to it, install it and Connect your phone via IR. And sen the files. If you want to send to a phone then that phone should have an IR on it. Switch on the IR of both your phones and place them such that the IRs of both are in line with each other. They will connect and when connected you can send files from one to the other.
Nov 28, 2009 | Motorola Mobility V750 Cellular Phone
Bluetooh is not working properly
hard reset the whole phone and it should clear this problem..just make sure it is on charge when you this else it's good for the bin.
Jun 20, 2009 | Nokia 6600
My phone is sending an unknown message to another phones.how can i stop this ?my phones bluetooth is in off possition i have nokia 6600 my phone sending unknown files to other devices if my bluetooth in...
by pressing Calling key and 3 and * and switch it on ur battery must be charged it will show formatting for 5 minutes and it is done. dont remember to vote my solution as fixya
Jun 03, 2009 | Nokia 6600
ur phone or mem card contain virus.. the easiest way to recover this is first put ur mem card in card reader and format it seperatly. then format ur phone seperately. there are two ways of 6600 formating !. use the coad (*#7370#) if u know ur security code. 2. if u forgot ur cade then switch off ur phone press #, 3, and dial call button at the same time and holding these buttons press switch on button n hold it. note::: hold these four buttons uptil formating doesnt start.
then insert ur formated memory card in the phone (100% working) i tried it.
WARNING format will cause deletion of ur cont nos , messages , images, softwares, videos, and all other data.
May 27, 2009 | Nokia 6600
Bluetooth 5500
Hi. Theres no way to send any messages via bluetooth - formally.
You can send messages by writing it first on notebook and send it forward with bluetooth.
If you recieve any messages from another bluetooth handset they will go to same place as your SMS. In your inbox.
You can send pictures, music etc. by going in the gallery, selecting file what you want to send, and click send. It may ask do you want to send it by MMS, IR, bluetooth or something like that.
This is my favourite. Search super bluetooth hacker from Google and send it to your phone. It may came to your inbox. Install it, turn bluetooth on, cheat your friend that you will send him some cool clips and songs. Then your phone will ask password. You both enter same password (example 1111) and you may have access to his/her phone. >:)
If you want to any more help, connect me and I will help you.
Oh! By the way, I think you can download online instructions from Nokias website. Have a nice day - with bluetooth.
Sep 07, 2008 | Nokia 5500 Sport Cellular Phone
Nokia 6600 Logo
70 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
