Question about Pentax Optio S50 Digital Camera
Lens wont go back in once camera is turned off.
I turned the camera on, took some pics. i fell, then the camera shut off, but the lens wouldnt go back in. now if i turn it on, i get the start up menu, but i can't do anything. HELP!!!
anyone have any clue on how to fix this thing!
(pentax optioA30)
  • 579 Answers
Lens motor probably blew a SMT fuse when it got jammed. either take it apart and probe for an open fuse with a miltimeter and jump it with a blob of solder, or remove batteries for 48 hours and try again. Maybe a hard reset (no battery for 48 hours) can reset a shunt type protection.
Posted on Nov 16, 2008
I got this camera for xmas and the first time i turned it on i took aboout 3 photos and the focus error thing came up and wouldnt go away. I turned it off and left it for a week and then it worked for...
Were you on the beach? Check for sand particle around the lens barrel, and make sure that you are using good quality batteries (rechargeable preferred). Also see this, maybe it will help.
Jul 09, 2011 | FUJIFILM FinePix AV100 Digital Camera
Kodak v803 wont turn on
i had the same problem, if you try to turn the lens in as if you turning a dile, the lens will go back in manually once you have the lens completly in again, as if the camera is switched off, then turn the camera back on at the power button and the camera will operate as normal, this worked for me i hope it works for you too.
Jul 28, 2009 | Kodak V803 Digital Camera
Tried uploading pics on computer now my camera wont turn on or off...did i break it..is there a virus???
I had the same problem. I took the battery out for 30 seconds and put it back in. I then turned it to the view mode, and turned the camera on. Hope this helps.
Oct 14, 2008 | Sanyo Xacti VPC-T700 Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Camera lens stuck
this occured to me whilst using my Sony P200, took it appart and found the lens motor had basically jumped its gears and jammed, the only solution was to replace the lense section (as motor & gears were built in) as no other part was damaged but to do that it would be at least £70 and the camera had dropped value to £160 and i could get a better camera for that amount...so my advice get a new one. and sell the remains on eBay.
May 13, 2008 | Cameras
Sanyo VPC-E760 Lens not closing
THis is really easy to fix. just pull the lense out so it is alligned. it might seem like your breaking the lens but its just jammed.
Feb 17, 2008 | Cameras
Lens is stuck and will not power on
Hi ive got a solution to this
apparently i have some bad news , its the lense which is misaligned or broken in terms of gears, the thing to do turn on the camera and make sure that lens is out and then LIGHTLY tapp on the lens the direction of which you feel that the lens is not equal legnth to the outer ring > place that looks uneven
Nov 19, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Kodak dx6440 wont power up lens wont and retract
I have the same/similar problem. I could hear the camera attempting to retract the lens. Camera shut down after timeout.
Disassembled camera & found two teeth missing from plastic gear in gearbox attached to lens motor. Don't know yet if part(s) are available.
Camera had light use. Patheticly short life & that Kodak didn't use stronger nylon gears. Bought a barely use Kodak P880 recently, & the autofocus died shortly after. Web search showed others had same failure. I'll never buy another Kodak camera.
Sep 20, 2007 | Kodak EasyShare DX6440 Digital Camera
Pentax Optio S50 Digital Camera Logo
102 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
