Question about LG 24 in. LDS 5811 Built-in Dishwasher
Not good washing
I have a fagor 2LF-013S dishwasher. After my dishes are washed by machine there are always white points on my dishes. So that they look dirty
  • 833 Answers
You are either not using enough of the wash chemical or you need a product like Jet Dri...what you are seeing is mineral deposits.  Make sure your water temperature is hot enough.  If not sure, use the cycle which heats the water.
Posted on Nov 16, 2008
Hi, my new FAGOR 2LF-013S has no problem fortunately, but i have questions. is it possible i connect the water hose to hot water mains ;if ok; does it lead to power consumption reduction, or any other...
some fagors have a built in water heater (not all) your manual should say so , even so I allways connect my machines to hot supply as yes it's less expensive to use domestic heater for water , the heater inside (if equipped) machine just boosts the temp for cleaner dishes
Sep 11, 2011 | Fagor LFA-013 Stainless Steel Built-in...
I have an older GE dishwasher Model # GMB921HB119. The machine operates normally till it reaches what I believe is the final rince cycle and stops. The timer continues to advance, reaching the drying cycle...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
0--0
Dec 26, 2010 | Maytag Dishwasher
White residue baked on dishes and wont come off even when washed by hand
Unfortunately this could be caused by water that is to soft combined with bad wash liquid. Typically you want to make sure you get the highest possible phosphorous content in wash liquid. This will help with the staining on your dishes. At this point you won't be able to get it off the dishes.
Dec 23, 2010 | Whirlpool 24 in. DU915PWP Built-in...
DISH WASHER RUNNING FINE . NOT CLEANING AS GOOD AS USED TO. LEAVING DISHES NOT ALWAYS REAL CLEAN. IS THERE FILTERS TO CLEAN ?
Run 1 quart of white vinegar through a wash cycle.
Use only powdered detergent when washing.
Use a rinse aid product like Jet Dry.
Dec 12, 2010 | Whirlpool Dishwashers
Food always gets stuck in the water spray holes pluging them up. It needs a better food filter system. We have a GLD4500N
As recommended most of the dishwashers are not equipped with this filter. But it is always recommended to clear the food off the dish/plates, wash off or wipe and put it for cleaning. The dish washer cleaning is entirely the degreasing/ sterilising of the vessels.
Hence the tip to get your dish washer in good shape is to wipe/wash off the food and load it to the trays inside.
This is my suggestion as we cannot improvise the machine. I hope this helps Good day
Aug 18, 2010 | GE 24 in. GLD6300L Built-in Dishwasher
Dishwasher is throwing food bits back on dishes during wash. How do I clean out dishwasher?
While loading into the machine always remove the food particles from the dishes. The wash machine will clean the sticky oil grease only.
Check the drain filter in the machine and clean. Refer user manual.
May 17, 2010 | Frigidaire 24 in. FDB126RB Built-in...
DISHWASHER MODEL # KUDS03FTBL2 WORKED VERY WELL UNTIL TWO TO THREE DAYS AGO DISHWASHER NOW LEAVES MASSIVE FILM AND DEBRIS (LOOKS LIKE FINELY GROUND UP GRAVEL AND DIRT) OTHER DISHES AND SILVERWARE HEAVILY...
There is a product out called the dishwasher filtration system. it filters the water going into your dishwasher reducing the hrad minerals that leave that white residue. it is very affordable and works amazing. it goes right under the sink and is easy to install. go to www.dishwasherfilter.com for more info on it.
May 01, 2009 | Dishwashers
I have to buy a dishwashing machine,
go with bosch they are about the best made
Jan 28, 2009 | Fagor Dishwashers
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
The correct way to start the wash cycle
we have just purchased a Fagor dishwasher also - the instruction manual is worthless.
in regards to the 2 thin tubes, we just inserted them in the gallon jugs that the soap/rinse agents comes in and it works fine. just make sure the clear tube without the label goes in the rinse agent and the labeled tube goes in the soap jug. we did drill a hole in the top cap of the jugs and pushed the line thru and that helped keeping the tubes in the jugs and minimized the mess if the jugs fell over.
in regards to the temperature problem, we found that running it thru a couple of cycles before you start the actual dishes helped get the water temperature up faster. it seems to like to start with normal tap hot water first, so the 1st couple of cycles get the cold water out of the line.
Dec 29, 2007 | Fagor 24 in. FI-48W Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
128 people viewed this question
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
