Question about Motorola Mobility RAZR V3i Cellular Phone
I am haveing a pc issue it won't connect to my network
  • Shaun Plencner
    Shaun Plencner Nov 15, 2008
  • 849 Answers
It is connect throught wire supplied with it, ot through bluethoot connectivity
Posted on Nov 15, 2008
How do I connect my laptop into an existing LAN network?
Unless you have some security in place or messed with the adapter settings, plugging it into an Ethernet cable should be enough to get it connected.
Sep 29, 2015 | HP Computers & Internet
Won't connect to router
Shut down compter, unplug router and the ISP modem, Check ALL cables and reseat ALL connections, plug in the ISP modem allow it to selftest, plug in the router allow it to selftest. Reboot the computer, plug in Ethernet cable.You didn't give much info to work with. Wired? Wireless? Does it connect to other devices? What is the OS? Vista? Is this a recent issue? What it the router Make ,Model? Open the Network and Sharing Center, Manage Network Connections, Is the Ethernet Adapter enabled?
Jan 07, 2013 | eMachines ET1161-03 PC Desktop
Network won't connect
As you may guess, I'm going to need more info to help you. What network? Won't connect to What?
Nov 18, 2012 | Computers & Internet
Hot to connect wifi?
Wifi will only work if you connect to a network. First check at the bottom right hand of you screen for the symbol for network connections. You can run the mouse over all the different symbols until you find the right one. Now if your afapter is working correctly you will be able to choose to network connections and the choose net work connections. From there you can choose the correct connection name depending on what name your network is under. Then you will need a password that you can type in or use you existing modem to configure automatically. Now if you are connected and it still won't open the web page you will need to right click on the symbol when connected and choose repair connections and this usually fixes it. If you have any issues please feel free to contact me. Thanks Igor!!
Sep 29, 2012 | Computers & Internet
Dell Inspiron Mini won't connect to wireless- won't ask for wireless password and therefore cannot connect. Help!
Learn easy Steps To Set-Up A New Dell Inspiron mini. If you need assistance with issue, Call immediately -18002044427 Dell Laptop Technical Support number, Read More
May 08, 2017 | Dell Inspiron Mini 10 Notebook
I have a toshiba A305-S6905 notebook with an A/G/N wireless adapter, but won't connect to an 802.11n network
Check the information that came with the router or access point to find out what connection mode the device is set to. The mode should be either ad hoc (when devices communicate directly without going through a router or access point) or infrastructure (when devices communicate by going through a router or access point). Make sure the setting in Windows for this network matches the setting on the device. To check this, follow these steps:
  1. Open the Command Prompt window by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking All Programs, clicking Accessories, and then clicking Command Prompt.
  2. Type netsh wlan add filter networktype=network type.
    Where network type is either adhoc or infrastructure.
  3. The router or access point is busy.
  4. The network you are looking for is set to not broadcast its network name (SSID).
  5. Your network administrator is blocking access to certain networks.
  6. The wireless network adapter is in monitor mode. Was this helpful?
Apr 18, 2012 | Toshiba A305-S6909 PC Notebook
My hp pavillion dv9000 won't connect to the internet via wireless or network cable
Your having driver issue's sound and Network drivers either corrupt driver missing. input exact information needed, download them and be done.
Apr 16, 2012 | HP Pavilion dv9000z Notebook
Dose not want to connect to the internet
If you mean it won't connect to the playstation network this is because playstation network suffered a security breach and will be down until they fix their network issues. They are already past their deadline so I am unsure when full network functionality is supposed to resume.
May 11, 2011 | Sony Video Game Consoles & Games
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default DNS server address type the default gateway in primary DNS and in secondary your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Install D- Link adapter
It's not generally possible to connect two computers directly via a network adapter.  You need a hub or router in between the two computers (you would connect a cable from each computer to the hub or router, and that equipment facilitates the connection between the two computers).  Alternatively, you would need a "crossover cable" to connect the two computers directly without a hub or router.
Oct 22, 2007 | Computers & Internet
Motorola Mobility RAZR V3i Cellular Phone Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
