Question about Sony KP-46WT510 46" Rear Projection HDTV
Won't turn on
When you press the power button you hear a click and then nothing happens. It flashes 6 times where the stand by light is. For about two weeks now when the t.v. was still working the screen would flicker. And sometimes it would even cut off. You wouldn't be able to turn it on for about 15-30 minutes and it would flash the same 6 stand by lights. To top it all off about two months ago, while I was watching television, there was a 'boom' sound and the sound went out. Sound hasn't come on since that day.
  • 203 Answers
Although the other response is in much better technical lingo, it sounds to me like the television had a high voltage arc which I have seen on quite a few of the sony big screens lately. Usually, it causes a part on the circuit board, (one of many that were listed on prev. solver's list) to fail. This causes a delimma for the repairman, because when they find the bad part and replace it, sometimes it will pop again causing repeat failure of boards and/or parts on the board. Sony is known for having bad tubes on their projection sets, and it can be a difficult repair even for a trained tech. I suggest calling a sony service center in your area, and get an accurate estimate before deciding if replacing the set is the best idea. Hope this is helpful input, Russmann.
Posted on Nov 17, 2008
  • 15,935 Answers
Replacing the G-board or the D6116 & D6301 diodes will fix the issue
Posted on Dec 26, 2008
  • 42 Answers
Event ID
E26519207 Type
Break/Fix Info Level
5 Safety Issue
No AutoFlag
No Last Update
10/17/2008 6:43:09 PM
Shutdown symptoms
Symptoms / Customer Description
Shutdown symptoms
[Primary Symptom Code: 2111 ]
1. Standby light flashing 8 times and TV has no picture or sound.
Checking CN8016/pin 3 on the D Board was going above 7.4v, thus causing
IC8008/pin 12 to put the set into shutdown.
Found HV Block was defective.
2. Goes into shutdown with the
timer LED blinking 6 times.
This is supposed to indicate a loss of 5V on the A board.
3. HV came the shutdown with 6
Unfortunately, just about any problems on the low B+ lines will generate this error. I've run into several situations where the
tech has replaced all of the boards and the problem remains.
It is usually one of the deflection yokes and if not that, one of the video drivers on the C boards. Unplug the yokes (CN017, CN018 and CN019) one at a time while turning the set back on to
isolate the defective yoke.
NOTE: Disconnect the C boards from the tubes to avoid phosphor damage.
4. TV Timer LED Blinks 6 times.
The 6 blinks indicates the loss of 5 volts on the emitter of Q714 on the A Board. This 5 volts
is supplied from
the 5 volt regulator IC 2 (A Board) which receives 6 volts from the G Board.
If the 6 volts is missing or a short on the 5 volt line you will receive 6 blinks. The 5 volts is also supplied to the B board. Therefore before changing boards check if 6
volts is present at CN 4 /pin 3. 5v to CN12 /pin 17 to AD Board, and is 5v at CN 13/pin A23 A Board .
So you can see the 5v is supplied to the A, AD, & B board and is created by 6 volts off of the G board. You might want to un plug the
connectors CN13 & CN12 (A Board) and test for short circuit with your ohm meter on either the A, AD, or B board.
5. HV came the shutdown with 6 blinks.
Found D5021 short on the G Board
D5021 8719-988-61 ISS355TE-17
6. KP-53HS30 Set shutsdown.
Yoke was causing D Board to fail repeatedly.
After replaced D board and convergence was away off, most likely problem is in yoke's.
Ref 205 P/N 145153711 Yoke
7. KP-43HT20 Shutdown 6 blinks
Found FBT has no
ringing at all using the Sencore VA 62.
Replaced the FBT T8005.
Also refer to E22668796
Ref. T8005 P/N 145328521 FBT
8. No picture 5X
Set has no picture and goes to 5X. Determined that set had audio, and was going to HV
shutdown with no
filament on the CRT's . Replaced HV block.
9. Turn on retrace line then shutdown.
Found ground wire on CN8016/pin 4 was pulled out not grounding the HV Block
10. KP-51HW40 Shutdown 8 Blinks
Found the 6v supply from the G Board dropping to
3.2v. CN4/3 drops to 3v, pix mutes,
Red LED flashes then a grayscale type pattern comes back on but pix is reduced in size vertically/horizontally then pix would flash bright and unit would shutdown/8 blinks.
Found bad connections on IC5004.
Re-soldered IC5004 and unit has been operating normally
for past 3 days.
11. The TV shutdown with 5 Blinks no high voltage and no Horizontal Drive to Q8042.
DC voltage on the emitter of Q8041 was 2.7v. Voltage on the base was .07v. Q8141 was
open. Found a shorted IC8007/pin 5 was 14 volt DC.
Replaced IC8007 P/N 875970007 on the D Board.
12. KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
13. Shut down, 8 blinks. Does hear HV start to come up before it shuts down.
the protection voltage from the HV Block to CN8016/pin 3 was going above 7.4v causing IC8008/pin 12 to turn the Horiziontal Drive OFF.
Replace HV block.
14. Shutsdown
Replaced D board. After 1.5 hours, pix starts to flag then will shutdown.
Reading NVM emergency history showed no fault codes.
After the set had been on for 1 hour, 120 hz interference could be seen in picture, causing picture
Found AC input filter capacitor, C6032, to be cold soldered on the G Board.
Ref C6032 P/N 113775011 1500UF 250V.Notes:
15. Shutdown, 4 blinks
Replaced the D board- same issue. Unit has +/-15 volts. Has 5 and 9 volts to the Jungle
Has waveforms from the Jungle to the Vertical Output. Suggested to check clock/data lines on IC001 for 4.6 volts DC. They were low. Tech replaced the B Board to resolve the issue.
B Board P/N A1136218A
16. The TV shutdown and the LED flashers
6 times.
Found Q8038 shorted on the D board.
Q8038 P/N 872903810
Break/Fix information may be based on a single instance of this problem.
It in no way indicates a serious problem and is only provided as an aid, in the case that
you are repairing this model for a similar symptom.
The P/N listed for
boards, or components COULD be based on the sets model
And/or serial number.
Please refer to the S/M and check for Service Bulletins before ordering any part.
The full repair manual for KP-WT510 can be found HERE!
Posted on Nov 16, 2008
Green power light comes on then 20 seconds later the red stand by light flashes 6 times & keeps trying to turn on, can hear it clicking but nothing comes on screen only red light flashing. can prob fix...
These flashes are called blinking codes, and are fault indications. If you wish to get more details to these blinking codes, check the site linked here.
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 02, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Plasma tv green light flashes 5-6 times then stays green but no picture or sound
Remove one at a time the Y sus and Y buffer cables that go to the power board and see if the set stays on then, you may have a distorted pic, replace the board that makes the set stay on...there are some transistors on the buffer board that give issues a lot and I'd guess that's where your issue is at
Jan 27, 2018 | LG Televison & Video
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Sony Computers & Internet
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
Will not power on
line o/p transformer & transistors are gone ...take help of a tech person to change them
Apr 22, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
I have to get a printout... When I went to my IP2200, I found several pages jammed. I simply pulled them out and rebundled the paper and set them in the feed tray. I then pushed the resume button, which...
Hi. In such situations it is best to reset the printer.
This procedure resets canon iP1200 /iP1600 / iP2200 printers.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Jul 29, 2009 | Canon Office Equipment & Supplies
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Tv wont turn on
How many times does the light flash, as there is a code that can give an indication as to what circuit is bad.
Jul 15, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KP-46WT510 46" Rear Projection HDTV Logo
602 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
