XFX GeForce 6200, Graphic Card
Problem for XFX GeForce 6200, Graphic Card
Computer reboots after about 2-5 mins, OR hangs on high 3D graphics games
By CraigBest on Nov 22, 2006
Hey, My friend bought this card, after finding out it was on the list of approved cards for the game he runs, (world of warcraft). We installed it, and upon the restart, the computer got to the desktop screen, and rebooted over and over. Then upon total cleaning, rechecking connections, and hooking the monitor to the MB video out port temporarly to get online, we downloaded the latest NVIDIA drivers... reinstalled the card, and PRESTO! it works.... sort of. We can run every application like MS explorer, and word, outlook etc, but when he turns on the game, and it uses the high powered 3D rendering, the card works fine for about 2-5 mins, then the screen hangs up. We can hear from the sound that the game continues to run.
Any suggestions?
Comments:
Nov 24, 2006
- Thanks! I believe you are exactly right. first, NO! this card does not have a dedicated fan. It operates with a very large heat sink which is not bolted in or soldered in, but rather uses those crappy spring loaded plastic rivits. And I noticed its loose. Second, the card worked for, like I stated, about 2-5 mins, now it wont work at all. Third, I performed a rude experiment on this situation also.. I took the perfectly functional card out of my computer and installed his..(the one in question). The computer wouldnt even boot. I left the card in, and moved the monitor cable to my MB port temporarly. Still no boot. I left the cable where it now was, and removed the card in question. Computer booted. I loaded the drivers for the card manually, and reinstalled the card, and moved the cable. Nothing. At this point, we're fairly confident the heatsink was not in place well, and has not fried the card.
Thanks for your help!
Always buy a card with a fan on it for todays high powered graphics.
Same Problem
Nov 15, 2008
-   my system restart when update antivirus
-   savanil
May 18, 2008
-   damn pc boots every time i try to run a game or anything that uses the card ...dunno what to do ...pls help -   H4RnIcu7zu
Best Solution
posted on Jan 01, 2007
Very Helpful)
madafaka
Rank: Apprentice
Rating: 100%, 1 votes
The card works fine whit no driver, but hangs or reboot after a few min. with latest drivers from ATI (maybe they return to theyr habit of making bad drivers :( again). PS: heat problem is out of the question (3 minutes in 12C enviroment temp with open case). DXdiag crashes on Direct3D test. Some game and all aplications works fine for hours, so I don't think is a heat problem
Was this helpful?
Yes
No
Solution #2
posted on Nov 24, 2006
Helpful)
Swobovike
Rank: Master
Rating: 79%, 159 votes
Sounds like an overheating problem. The increased demands on the video card create a lot of heat that is most likely not being dissipated properly. Two suggestions - does the graphics card have a dedicated fan? I am assuming it does, and it likely runs at one speed all of the time. Ensure that the fan is actually spinning when the computer is powered up. Another possibility is to add a whole case fan to push heat out of the computer case (most computers do not come with them but usually have the vent and mounting holes in the back to install one, and a connector on the Motherboard to plug it in - I added one to one of mine that was overheating and it is easy and relatively cheap). Also make sure the computer has free flow of fresh air around it. I have seen many cases where the computer case was put in a computer desk where the case is closed up behind a swinging door with one little vent hole. These do not provide sufficient air flow and computers overheat often. Good computers will shut down before damage, but not all. Good luck!
Was this helpful?
Yes
No
Solution #3
posted on Sep 26, 2007
Somewhat Helpful)
saitekx50
Rank: Apprentice
Rating: 70%, 1 votes
You know I have to agree Swobovike. A friend of my had that problem and add a fan to blow air over the graphics card and it worked after. He even overclocked and it still worked.
Was this helpful?
Yes
No
Solution #4
posted on May 31, 2008
Not Rated)
dffgfg
Rank: Apprentice
Rating: 0%, 0 votes
I have tried everything like even changing my Hardisk and the cooler fans and nothing works.
Was this helpful?
Yes
No
Solution #5
posted on May 21, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
,i have formatted my hard drive.and then installed a fresh copy of windows xp. but after the install my graphic card is not working. and i also dont know my pc model number
Solution #6
posted on Mar 12, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If you can run the v8420 in save mode (f8)
then check the voltages. Or check the voltages
in the BIOS at POST.
If agp voltage is too low, then must get a better
power. Some detail power on each rail of
5v 3.3v, and 12v.
Solution #7
posted on Jan 27, 2007
Not Rated)
adi_techmax
Rank: Wiz
Rating: 82%, 76 votes
Dear Friend, it seems that overheating is the culprit here. If possible, try installing a fan on the Graphics card.
If not, recude the clutter of cables around the card and invest in some good Cooler fans.
I would also recommend a VGA cooling solution from Cooler Master. Will cost you a couple of more bucks but will rid you of this issue forever.
I hope i was able to solve your issue because i faced the same issue and i got the resolution from some geek at ***.
Was this helpful?
Yes
No
Solution #8
posted on Dec 02, 2006
Not Rated)
coppertop
Rank: Apprentice
Rating: 0%, 0 votes
Craigbest
Did you resolve this problem, as I have the identical problem.
I have a heatsink & fan on the card. I also have run my computer with all the covers off to increase air flow, but still the problem persists.
Was this helpful?
Yes
No
Popular Solutions for XFX GeForce 6200, Graphic Card
Questions and Unsolved Problems for XFX GeForce 6200, Graphic Card
Do you recommend XFX GeForce 6200, Graphic Card?
Answer
Answer
How do i program remote to turn on and off tv
Answer
9-SOCKET_DATA . LOOKUP(S) = = O CAPTURELSPNOISPWSP_PATCHES.CPP:1313 IEXPLORE.EXE ASSERT IN LSP tHIS... (More)
Answer
im on pizerebel and i dnt l know what to do next i need a zcard badly help me plzz
Answer
Hey man i got this dumb this streched desktop waring when ever i play a game on multiplayer i get... (More)
Answer
ok i just bought the geforce 6200 xfx graphics card agp. when i try and run like counter... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Graphics Cards Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
