Question about Apple AirPort Extreme Wireless-N Wireless Base Station
It just stopped working.
My airport extreme base station just stopped working for no reason. It does not power on. The front status light is dead, no flashing no nothing. The only lights that work are the ones on the back where the Ethernet cables connect to. They all light up green but nothing happens.
  • mej1431 Nov 18, 2008
    It doesn't power up. The only sings of power are the green lights at the back of the router where the Ethernet cables connect to. Other than that, nothing...
    Genius:
  • 1,913 Answers
First discovnnect all cables .then power up the router .then see in backside one reset button.press that button for 10 secoonds.
it reset to factory defsults.
then it working but may be u hace configure aagan your router.
che k both link to configure router.
http://192.168.0.1 and http://192.168.1.1
then type admin and pasword aslo admin if pasword is not accept then left it blank.
Posted on Nov 17, 2008
Apple airport extreme stopped sending out a signal. no wifi pick up on any comp phone or ipad light is flashing amber. did a reset unplugged rest again noting
Go to your Airport utility, if you do not have it. download it in the app store. use the wizard setting, it will find your probles
Jul 03, 2011 | Apple AirPort Extreme Base Station Router
We just bought an Apple Airport Extreme router. After installing the Airport Utility software, and hooking up the router, we can not configure the base station using the Airport Utility. No matter what...
First time you should connect an Ethernet cable to the AirPort, and set it up with the software it came with. Then take a note of the wireless network's name (SSID) and the password (you might want to chance them to your personal preference though), security youre using (WEP, WPA, or WPA2)
Feb 20, 2011 | Apple AirPort Extreme Base Station
The router is blinking a yellow light
Here are some of the more common reasons that the status light may blink amber:
  • The Wi-Fi base station has not yet been configured because it is new.
  • The Wi-Fi base station has been reset.
  • A new firmware update is available for the Wi-Fi base station.
  • No IP address is available for the Wi-Fi base station.
  • A Wi-Fi base station in Extended Mode is out-of-network Wi-Fi range of a primary Wi-Fi base station.
  • The WAN Ethernet cable is unplugged from the Wi-Fi base station.
  • The Wi-Fi base station lacks a path to the Internet (or local router).
  • Internet access may be temporarily unavailable from your Internet Service Provider (ISP).
  • Your AirPort Time Capsule has detected that the internal hard drive has reported a SMART error, and is failing (This requires firmware 7.5.2, and AirPort Utility 5.5.2).
Feb 10, 2011 | Apple AirPort Extreme Router
Trying to update firmware on y airport extreme but i forgot my password
You need to perform a soft reset of your router. There directions to do this from the Apple web site are:
  1. Connect the AirPort Base Station or Time Capsule to power.
  2. Press and hold the reset button with a pen or pencil for 1 full second, then release it. The light (LED) will begin flashing amber, indicating that the AirPort Base Station or Time Capsule is in soft reset mode.
  3. From the AirPort menu bar item, choose the network created by the AirPort Base Station or Time Capsule (the network name does not change).
  4. Open AirPort Utility in Applications > Utilities on a Mac using Mac OS X, and in Start > All Programs > AirPort on a computer using Windows.
  5. Select the AirPort Base Station or Time Capsule and click Continue.
  6. A window indicating that the device has been reset will appear.
  7. Select "Restore the previous settings" and select OK.
  8. Move through subsequent windows to make changes to your passwords or other settings as desired, clicking Continue after each one.
  9. When you have moved through all of the selection windows you will be able to select Update. Click Update to install the new settings.
  10. Click Continue to allow your AirPort Base Station or Time Capsule to restart.
  11. Quit AirPort Utility.
These directions are from the Apple Support Web Site:
http://support.apple.com/kb/ht3728
Jan 02, 2011 | Apple AirPort Extreme Base Station
Someone helped me hook up my dell laptop to the airport exteme wireless. The wireless is on the actual new laptop, but it asks for a security key. I have no idea what the security key is any ideas? ...
If your network is being created by an Apple AirPort base station, use AirPort Utility to put the base station into "manual setup" mode, then pull down the "Base Station" menu and select "Equivalent Network Password". Try the value shown there.
Oct 13, 2010 | Apple AirPort Extreme Base Station
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
All of a sudden the light on a airport extreme is blinking green.
That is the standard for the airport extreme indicating that it is operating properly. If you go to applications and then utilities open up airport utility. Click on your airport in the left hand box then click on manual setup then on base station and then click options under status light you can then choose either flash on activity or always on (which is the default).
Nov 06, 2009 | Apple iMac 24" Desktop
I need a 5.1 v dc power supply for an older airport base station
There are universal multi-voltage adapters available at electronic hobby shops, they are available with various adapter plugs. Make sure you connect the adapter plug that matches the power socket for the airport AND also make SURE you connect it with the right polarity and set it for 5 volt setting. If you reverse the polarity you could destroy the airport.
Sep 12, 2009 | Apple AirPort Extreme Base Station...
Airport extreme stopped, front light dead, back lights flash
Your airport just died, contact apple support and request a replacement.
Jun 21, 2009 | Apple AirPort Extreme Wireless-N Wireless...
Airport Extreme Bases Station not detectable with utility
This depends... Reaching them wirelessly may be unreliable for a number of reasons, so, I'll proceed on the assumption that you are attempting to test in the simplest lowest-variable situation:
First, make sure that you have the latest Airport Utility for your Mac.
Connect your Mac to the Airport via a single Category 5 (or 5e or 6) cable. Factory-reset the Airpot and then wake up the Mac. If the utility still can't discover your airport, it's probably time for a trip to your local Genius bar as you most likely have a hardware problem.
Lather, rinse, repeat for each of the two airports.
Apr 28, 2009 | Apple AirPort Extreme Base Station...
Apple AirPort Extreme Wireless-N Wireless Base Station Logo
960 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
