Question about Canon BubbleJet i9950 InkJet Photo Printer
Ink pad absorber almost full
I have followed the proceedure for the waste ink pad absorber and I still keep getting the same message. Is there something else I can do to solve this problem.
Thanks Donna
    Sergeant:
  • 306 Answers
The Canon inkjet I had required that a service facility perform that task as there is a reset of the firmware that must be done. Try contacting a Canon service provider or tech support to see if they will assist you. I had taken mine completely apart, disconnecting the electronics board and changing the printhead as well before that error cleared but I am not sure if you have to go that far.
Posted on Nov 15, 2008
Where is the waste ink
You're probably referring to the Waste Ink Tank in a Canon printer. If you've received the Waste Ink Tank nearly full message, there's a workaround.
The waste ink absorber is actually a pad/sponge that absorbs left over ink spray. There's really no precise way to measure the amount of ink these pads hold so when the message first appears, "waste ink absorber is almost full" it's just an estimate.
The workaround for the message is as follows:
Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Using the above procedure should clear the message and your printer should function normally afterward. Best of luck and thanks for using Fixya!
Greg
Nov 26, 2009 | Office Equipment & Supplies
Canon ir 2022 - waste toner full message
Reset ip2000 / 3000
1. Turn off printer
Greg
Nov 18, 2009 | Office Equipment & Supplies
My Cannon ip pixma 2000 is saying that the waste ink absorber is almost full how can i solve this
Reset ip2000 / 3000
1. Turn off printer
Greg
Nov 08, 2009 | Canon PIXMA iP2000 InkJet Printer
Won't print. I get a message that waste ink absorber is full. What do I do?
Hi
Thanks for using FixYa. Open the cover, move the cartridges to the centre, and then press the pad of absorbent paper towel onto the waste ink pads. You can locate the waste ink pads to the right of the cartridges. This will absorb a lot of ink in the pads and that will remove the warning after you reset the printer waste ink tank counter. To reset your Printer please tell me the model number of your Unit so that I can provide you with model specific information.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 05, 2009 | Canon Office Equipment & Supplies
Ink waste absorber is full. Canon IP2000. How do I repair it?
Well, at some point you will need to either replace or wash the absorber pads in the printer - but you can reset the warning as follows:
1) Turn the printer off
2) Press and hold the <resume>button
3) Press and hold the <power> button
4) While holding down <power> release <resume>
5) With the power button still held down, press <resume> twice more
6) Release the power button
7) Press and release the <resume> button 4 times
8) Press and release the <power> button twice
At this point, the printer should come back online with the waste ink warning reset
Personally, I would only do this once before actually changing the ink absorber pad...
Aug 31, 2009 | Canon PIXMA iP2000 InkJet Printer
Wast ink
Your MP780 printer has decided you have too much ink from the cleaning cycles in the absorbent pad inside the printer. Go to www.fixyour ownprinter.com and put "MP780 waste ink" into the search function. Follow the leads to find out how to clean the waste ink out and more important to find the code to reset the printer to get rid of the waste ink message.
Apr 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Waste Ink Absorber is almost full message every time I print
you need to change the inks waste pads, and reset the ink waste counter in service mode.
you can just reset the ink waste counter and still use the machine but it will probably start leaking a bit of ink after a while unless you sit it on something to absorb the excess ink.
to reset the ink waste count just do a search on the web and you will find it pretty easy to do.
Apr 01, 2009 | Canon PIXMA iP1600 Printer
Waste ink absorber is full
Hi!
The printer counts every single droplet ejected by the print head due to waste ink absorber capacity. When the waste ink counter rise to about 90 % the printer shows message 'Waste Ink Absorber Near Full'; in this stage we can still continue printing by pressing Resume button until waste ink absorber capacity reach 100% and 'Waste Ink Absorber is Full' appears.
To fix this problem you have to reset waste ink counter to 0%. Even though we can just reset waste ink counter without resetting waste ink counter, it strongly recommended that you replace waste ink absorber to prevent ink flooding inside the printer.
To reset waste ink counter, perform the following steps:
  • Plug in power cable
  • While pressing Resume button press and hold Power button (do nor release the buttons)
  • Release Resume button (still hold Power button)
  • Press Resume button twice in a row (still hold Power button), after that release both Resume and Power button (then the printer standing bye)
  • Press Resume button 4 times then turn off the printer
In this stage your printer has operated as usual.
Regards,
Nov 19, 2008 | Canon S200X Ink-Jet InkJet Printer
Canon IP500 printe displaying following error message, 'waste ik absorber almost full'. What does this mean? and how do I fix it?
hello
there is an absorbent pad in the bottom of the printer starting under where the print head rests, this is to absorb the ink that the printer sprays out during a cleaning cycle or a startup cycle.
the manufacturer knows the capacity of the pad and how much ink they spray out during the cycling, they keep track of this because when the pad becomes over full the ink will start to puddle under the printer making a very nasty mess.
sometimes one can order a replacement pad from the manufacturer and replace it yourself, sometimes they wont sell it to an individual because the printer needs to be disisembled to change it.
if they send you the pad it usually comes with directions on replacement and re-setting of message.
norm
Nov 06, 2008 | Office Equipment & Supplies
Waste ink absorber on canon iP 1600
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Apr 01, 2008 | Office Equipment & Supplies
Canon BubbleJet i9950 InkJet Photo Printer Logo
193 people viewed this question
old marine
old marine
