I cannot turn my Palm 500 on the light just stays green
    Scholar:
  • 91 Answers
Have you tried to reset? Turn your Palm over. On the back side there will be a little indentation for resetting the device. Take your stylus and push the button inside the indentation.
Did this work?
No, then leave it on, (assuming it is on because of the green light) and let the battery run out of power. When it does run out, the light should go off. Plug your Palm back in to power to recharge and see if it comes back on normally. If it doesn't, there is one last thing you could try. Your manual will explain how to do a full factory reset. If it doesn't, reply back to this post and I will explain how. Binary Bob
Posted on Nov 16, 2008
Red light blinking green light steady on
THIS IS A NORMAL THING FOR UNIT TO DO
GREEN IS POWER APPLIED
AND RED IS HARDDRIVE RECORDING VIDEO DOWN
Mar 07, 2014 | Lorex LH118501C4 8 Channel 500 GB DVR with...
I tryed charging my palm centro with the USB cord and the red light came on but it didnt charge what do i do?
your laptop is plugged in right? I would check the battery options on your laptop.
Aug 30, 2009 | Palm Treo 500 Centro
Red light staying on but phone not on
well when my light turns red it usually means my phone is dead
Aug 09, 2009 | Palm Treo 500 Centro
My palm centro does not turn on and the red light stays on
Hello halvarez,
Have you tried a soft reset by removing the battery and leaving it out for a couple minutes then reinserting it ? The Centro should run as normal after removing the battery and reinserting it. All your information is retained when you perform a soft reset.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
May 10, 2009 | Palm Treo 500 Centro
My Phone dont want to charge
Try to turn off and on the phone. If that still does not work try to use a different charger. Sometimes even if the light is on the charger does not charge.
Feb 06, 2009 | Palm Treo 500 Centro
Headlamps work all the time
pull the parking light fuse from the wire harness on the remote starter, it should be a blue 15amp not the green 30 amp, if that works you wired the parking light wire to the wrong one, if not post me and we will go from there
Jan 27, 2009 | DLX 500 Remote Car Starter
MY PALM CENTRO WONT STAY ON. IT TURNS OFF RIGHT AFTER I TURN IT ON, AND MY BATTERY IS FULLY CHARGED
Try look at the setting by pressing the House (right key)
Choose Prefs, select Power --> check time of Auto-off Receive --> set to maximum time
Try and see if this works
Nov 20, 2008 | Palm Treo 500 Centro
Blue tooth for a palm centro
the problem was that you must open the headset after you hold the talk button till the light comes on then flip it open and the light stay on so that the phone can receive the signal.
Jul 09, 2008 | Palm Treo 500 Centro
Palm m505 Won't Start Up
I have an M505 with the same problem. After taking off the back cover, I found a defective (short circuit) SOT23 device nearly centered just below the expansion card slot. The markings are A5RGC, but I have been unable to verify whether this may be a programmable UJT (BRY61), a transistor or a diode. Does anyone have a schematic diagram, or kno where to get one?
Sep 15, 2005 | Palm m505 Handheld
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
