Question about Microsoft Windows Vista Ultimate Edition
C++ run time error
When I open the computer it shows microsoft c ++ run time error library. until I press ok the system will not start.. Please help to solve this problem.
  • 66 Answers
Hi ,
Try loggin on to safe mode and check whether you get the same message ---
How to log on to safe mode - Keep tapping f8 While system boots and choose safe mode or safe mode with networking. --- If no error message do a clean boot.
How to do clean boot --
Click Start - Run - types msconfig - opens system configuration utitlity --- Click on services tab -- check the box hide all Microsoft services, then click disable all ***** click to the tab start and disable all click apply then close and it will prompt you to restart the computer . Restart the computer. I hope it fixes the issue .
Posted on Nov 15, 2008
Everytime I turn on my computer, I get this error message: Error loading C:\PROGRA~2\MYWEBS~1\bar'1.bin\F#SCRCTR What does it mean and how can I fix it? My operating system is Microsoft Vista.
Please click on Start, Click on Run and type the following in the open box and click OK
msconfig
Vista: In the Start Search field, type msconfig , and press Enter . The System Configuration window opens.
Or
Press and hold Windows logo key on keyboard and press R. It will open Run Window. Type the following in the open box and click OK
MSconfig
Please click on Startup tab
Remove the check mark from entries related to Mywebsearch OR M3PLUGIN.DLL
Then click on Apply, Close and Please click on Exit without restart.
When the system restarts, you will see a message about System Configuration Utility. Click in the box for "Do not Show this message" and then click on OK.
More on this solution here.
May 05, 2011 | HP Computers & Internet
I keep getting a message in a grey box as below. Any help would be appreciated. Microsoft Visual C++ Runtime Library Runtime error Program:C\PROGRAM FILES\MICROSOFT OFFICE\OFFICE10\WINWORD.EXE
I'm assuming this error is occuring when you open Microsoft Word. I'll continue under that assumption.
I suggest that you perform both of these fixes:
FIX #1
  1. Click Start, and then click Run.
  2. Type "regedit" and click OK.
  3. The Registry Editor will pop up. BE VERY CAREFUL WHILE USING THIS EDITOR. Do not delete anything unless you are sure you are deleting the correct folder or key.
  4. On the left sidebar, expand this path: HKEY_LOCAL MACHINE > SOFTWARE > Microsoft > Office > (May have several folders here, only one will have the Word folder in it. Find it.) > Word
  5. You should see the folder 'Add-ins' or 'Add-ons' in the 'Word' folder. Delete the 'Add-ins' or 'Add-ons' folder. DO NOT DELETE THE 'Word' FOLDER.
FIX #2
  1. Click Start, and then click Control Panel.
  2. Double-click 'Add or Remove Programs'.
  3. Click 'Microsoft Works in Word Suite Add-in', and then click 'Change/Remove'.
  4. Click OK to confirm the removal.
  5. Click Close.
  6. Restart your computer.
One or both of these fixes should solve your problem.
Feb 20, 2011 | Microsoft Windows XP Professional
Runtime error
Method 1: Clean Boot with Only MoSearch loadTOCNode(2, 'resolution'); The Mosearch.exe (Microsoft Office Search Service) and Mosdmn.exe (Microsoft Office 10 Search Filter Daemon) Startup items may be conflicting with some other program (or programs) running in the background. Therefore, clean boot your computer with only MoSearch selected on the Startup menu to determine whether this program is the source of the conflict. To do this, follow these steps:
  2. In the Open box, type msconfig.exe, and then click OK.
  3. On the General tab, click Selective startup.
  4. On the Startup tab, click to clear all check boxes except for MoSearch.
    NOTE: In Microsoft Windows Millennium Edition (Me), leave the *StateMgr check box selected as well.
  5. Click OK, and then click Yes when you are prompted to restart the computer.
  6. If the error message can be reproduced, repeat the preceding steps. In step 3, also click to clear the Process System.ini file and Process Win.ini file check boxes.
If the error message cannot be reproduced, this indicates that MoSearch is conflicting with some other program or programs running in the background. Follow these steps to locate the conflicting program:
  3. On the Startup tab, click to select one of the check boxes.
  4. Click OK, and then click Yes when you are prompted to restart the computer.
  5. If the preceding steps reproduce the error message, the last item added to the Startup menu is causing the conflict. If the error message is not reproduced, repeat these steps until all Startup menu check boxes are selected.
  6. If all the Startup menu check boxes are selected and the error message is still not reproduced, start Msconfig again, and then click to select the Process System.ini file and Process Win.ini file check boxes.
If these steps don't help you find and eliminate the conflict, proceed to the following method. uparrow.gifBack to the top Method 2: Uninstall the "Support for Fast Searching" Feature loadTOCNode(2, 'resolution'); To uninstall the "Support for fast searching" feature from all Office XP products that are installed on your computer, follow these steps.
Note This applies only to computers that are running Microsoft Windows 98 or Microsoft Windows Millennium Edition.
  1. Quit all Office programs.
  2. Click Start, point to Settings, and then click Control Panel.
  3. Double-click Add/Remove Programs.NOTE: Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  4. On the Install/Uninstall tab, click Microsoft Office XP product, where Office XP product is the name of the specific Office product in question. If you are using a stand-alone version of one of the Office programs, click the appropriate product in the list.
  5. Click Add/Remove.
  6. In the Maintenance Mode Options dialog box, click Add or Remove Features, and then click Next.
  7. Click the plus sign (+) next to Office Tools, point to the icon next to Support for fast searching, and then click Not Available.
  8. Click Update.
  9. Repeat steps 2 through 8 for all other Office XP products installed on your computer.
  10. Restart your computer.
Apr 18, 2010 | Microsoft Windows Vista Home Premium with...
When installing the computer back to its original settings. The systems will freeze when it gets to the point of checking the mouse. But in the beginning of the process the mouse is fine. I was told that...
Sounds like a virus. You might have to erase your hard drive and reinstall windows. If you have a boot disk that came with your computer, it will reinstall the entire system as it was when you bought it. You will need to save any files you want to keep first on a separate drive or burn to CD before you do it though.
Another option is to run check disk. Here is the instructions:
Manual steps to run Chkdsk loadTOCNode(2, 'moreinformation'); Notes
  • Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
  • Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
  • Chkdsk might not accurately report information in read-only mode.
Manual steps to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N) Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
Manual steps to run Chkdsk from My Computer or Windows Explorer loadTOCNode(3, 'moreinformation');
  1. Double-click My Computer, and then right-click the hard disk that you want to check.
  2. Click Properties, and then click Tools.
  3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  4. Use one of the following procedures:
    • To run Chkdsk in read-only mode, click Start.
    • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer? Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Collapse this tableExpand this table Exit code Description 0 No errors were found. 1 Errors were found and fixed. 2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified. 3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
For more information about Chkdsk, visit the following Microsoft Web sites: For more information about Chkdsk, click the following article number to view the article in the Microsoft Knowledge Base: 314835 (http://support.microsoft.com/kb/314835/ ) An explanation of the new /C and /I switches that are available to use with Chkdsk.exe For help with common system maintenance tasks in Windows Vista, visit the following Microsoft Web page: Fix problems with common system maintenance tasks (http://support.microsoft.com/gp/system_maintenance_for_windows)
Dec 07, 2009 | Gateway Computers & Internet
When I turn my computer on, I get a runtime error.
If this doesn't fix it, let me know and I'll post another, more advanced repair.
Good luck, and please let me know how you do.
~ Spoem
Mar 24, 2009 | HP Computers & Internet
WHEN I TURN MY COMPUTER ON I GET AN ERROR MESSAGE - HOW CAN I STO
msconfig
Or
MSconfig
When the system restarts, you will see a message about System Configuration Utility. Click in the box for “Do not Show this message” and then click on OK.
It may work!
REGARDS
RAHUL
Feb 22, 2009 | Microsoft Windows Vista Ultimate Edition
New Printer Installation Error
ISSUE: When trying to install an HP LaserJet P2015 printer, a MSVCR80.dll error message is received.
SOLUTION: To resolve the issue, complete the following steps:
  1. Before installing the printer, disable any Anti-Virus and/or Firewall software. To disable the Anti-Virus and Firewall software in Microsoft Windows XP and Microsoft Windows 2000, press the Ctrl+Alt+Delete simultaneously to enter the Windows security screen. Then select Task Manager , select the Process tab, select Anti Virus and/or the Firewall Image , and end process on the software.
  2. Disable XP firewall. To disable the firewall in Microsoft Windows XP, right-click My Network Places , select Properties , right-click Local Area Connections , and then select Properties . Select the Advanced tab and remove the checkmark from Internet Connection Firewall .
  3. If the issue persists, before trying to install the printer, we suggest you complete follow the steps:
    1. For system clean boot to perform, click Start , click Run , type msconfig in the Open box, and then click OK .
    2. On the General tab, click Selective Startup , and then clear the Process System.ini File and Process WIn.ini File , and Load Startup Items checkboxes. You cannot clear the Load system Services and Use Original Boot.ini checkboxes.
    3. On the Services tab, select the Hide All Microsoft Services checkbox, and then click Disable All .
    4. 4. Click OK , and then click Restart to restart your computer.
    5. 5. When the system restarts, click Start , and Printers and Faxes . Delete all the printer icons.
    6. 6. Click Start , click Printers and Faxes , click File , click Server Properties , and then click the Drivers tab.
    7. 7. Select all the printer drivers individually, and click Remove . Remove all the drivers one by one.
    8. Click the Ports tab and delete the listed TCP/IP ports individually by selecting the Port and clicking Delete Port .
    9. Click OK , and then restart your computer.
    10. When the system restarts, begin the installation process. You may insert the installation CD into the CD-ROM and follow the onscreen installation steps to install the printer locally.
      NOTE: Do not connect the printer to the computer until prompted to do so during installation.
Oct 28, 2008 | HP LaserJet P2015dn Printer
Error in Installation CD of HP2015dn
There may very well be a glitch in the HP installation CD. Go to their web site, HP.com. On the home page, left hand side - middle of the page, you will see a link for software and driver downloads. Click on that and then fill in the blanks on the type of printer you have. It should take you to a page that shows all software available for your printer - including the latest drivers. Once you find the driver(s), you can either download the file(s) to your computer and then do the installation - or just run the installation program from HP's web site (probably the easiest way to do it).
If that does not solve the problem, contact HP Customer Care via email or live on-line chat.
Hope this helps - Ghost
Oct 27, 2008 | HP LaserJet P2015dn Printer
Microsoft Windows Vista Ultimate Edition Logo
93 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
