Question about Navman GPS
I HAVE BOUGHT A BMW1150GS MOTORBIKE AND IT WAS FITTED WITH A ICN630 VERSION 2 GPS BUT WHEN I TURN IT ON IT ONLY STAYS ON FOR 1-2 SECONDS
    Brigadier General:
  • 6,966 Answers
Since to my knowledge this particular model does not have its own internal battery, then the connection to the bike's 12V system would be suspect. Course of action would then involve visual inspection and the use of a volt meter (DVM or VOM) to the source. Additionally, pls be informed that removing the Sd or MMC card while unit is in operation would perform a reset and revert the unit back to factory defaults removing personal settings and configurations. However, maps would not be affected. You may want to reference the user's manual for more information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 15, 2008
I have a cracked touch screen My &%T can it be
Welcome to FixYa!
Yes it ca be replaced. Go to Satellite Navigation Repairs for qoutation. Click the link below. http://satnavrepairservice.com/repair-satnav/navman-repair/14.html
Thank you for using FixYa. Have a great day.
Jas247
May 10, 2011 | Navman Navm ICN630 GPS Receiver
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
Aug 25, 2010 | Ford Focus Cars & Trucks
How do i reset it
There are (2) versions of this model.
1. Version one has a reset flap on the bottom where the decal is. Push on the flap and hold for 8 seconds.
2. Version 2 is reset by holding the power switch to the left for 8 seconds and releasing.
This info comes from the manual.
- Jim
SHARCNET-USA
Nov 24, 2009 | Garmin Nuvi 265W GPS Receiver
Dropped in fresh water for approx 2 seconds. Unit powers up but I can not get past the Drive safely screen.When tap the Continue button, it will not continue.
Just been trawling through tomtom's website and the only reference to waterproofing I can find ( The IPXX rating) is for the motorbike version. So in short, it's not even remotely waterproof. So the best thing for now is to turn it off, remove the battery if possible, but don't worry if you can't, and leave the gps in a warm, dry place to dry off. This can take a few days but it tends to work for phones etc that are accidently dropped in water.
If it still doesn't work after that it will need to be sent back to tomtom to see what the damage is...
Oct 06, 2009 | Tomtom ONE GPS Receiver
How would i fit my rider 11 to my bmw r1100rt please? it doesn't seem to fit to my bars at all thanks
this requires a bit of mechanical technique to modify the holder using aluminum to make a new holder
Jul 05, 2009 | Tomtom Rider 2 Europe Motorbike GPS 3.5"...
My navigon 2110 wont turn on
2 things that might help...use a paperclip and press the reset button (small hole on side, you'll feel a click) hold it for 5 seconds. THEN hold down the power on button for over 10 secs (keep holding while it shows version number) and it will perform a factory reset. You will likely lose any settings and addresses, but better that than no GPS unit.
May 10, 2009 | Navigon 2110 Series Satellie GPS Receiver
TomTom Go300
If you follow the instructions on the Tom Tom support site - It states
1) First download TomTom HOME version 1
it will update the boot code on the card
2) Install TomTom Home Version 2
Aug 25, 2008 | Tomtom GO 300 GPS Receiver
Navman icn630 crashed
oooooohh..ok..remove the battery..let it chill for a few and then try it again..I understand that you are to only plug that unit into a usb, when it's powered down.
Mar 20, 2008 | GPS
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
Magellan roadmate 300 wont stay on
It is the cigarette adapter, mine was doing the same thing until I bought a new adapter. When the old adapter plug to the GPS unit moved at all it would lose power.
Jan 13, 2008 | Magellan RoadMate 300 GPS Receiver
GPS Logo
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
