Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Water is not coming out of the water dispencer.
The water works on and off. It will work for a week or a month and then it will suddenly stop for months.
Try taking out bottom trays there should be a plastic water tank 2 small pipes atatched this could be freezing up use hairdrier to defrost then check if water is working
in my case the drain plug at fan was iced up and fridge would not keep temp
remove the light panel cover 1 srew at top there are 3 screws remove these remove plugs for light and thermostat.
remove 4 srews on bottom panel and remove it is on with sticky tape so take care remove 2 plugs for motor use hairdrier to defrost the pipes at back, remove 5 screws to take motor plate off on my fridge the drain hole was full of ice defrost with hairdrier refit all parts and if the same as my fridge it should work ok
Posted on Dec 31, 2008
  • 958 Answers
Please check the water inlet solenoid for the dispenser. check if there is voltage present. if there is, solenoid should click in and water should flow.
check also the water filter if it has one. it could be clogged.
if there is no voltage present, you may have a problem with the switch at the dispenser or the main board that controls the water inlet solenoid.
tnx 4 using fixya,
Drcool
Posted on Nov 15, 2008
Bissel powerwash 1690 does not dispence water
Hey George, not having spray when you're ready to clean can be frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1052&cid=ccsocial
Jan 21, 2013 | Bissell Carpet Cleaner Powerbrush Deep...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Water dispenser does not work
One of the following items is most likely the problem.
The inlet valve. The dispencer switch. the water filter, or the water storage tank.
If the ice will dispence then you can eliminat the dispencer switch. If you have heated the tank in the freshfood section then you can eliminat the tank. You may also have a frozen water line. The most common would be the inlet valve. it is located on the back of the refrigerator. It is the item the water line connects to from the wall. You can feel free to give us a call and we can help trouble shoot.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Feb 17, 2009 | GE Refrigerators
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
302 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
