HP INSTALLER RE-INSTALLATION PLUG HAS STOPPED WORKING
I have purchased an hp deskjet f4235 I have windows vista o/s and when I try to install the printer software the following error message appears:
HP Installer Re-installation Plug as stopped working. I have tried turning off firewalls and virus programs , clearing temp folders and caches and so far nothing works. Please help :)
  • Anonymous Nov 24, 2008
    with the f735...unistall IE8 if you have it. (go to installprograms and then look for the ie8update.
  • Anonymous Mar 01, 2009
    HP INSTALLER RE-INSTALLATION PLUG HAS STOPPED WORKING" can't install a new HP 6380. Please help.
5 Suggested Answers
  • 77 Answers
SOURCE: hp psc 1317 unable to use hp director scanning
Uninstall "HP Director" and replace with "HP Solution Center" New Updates (especially IE 7) make this application incompatible. Ed
Posted on Aug 07, 2007
MerlinTech
  • 197 Answers
SOURCE: fatal error msi.webreg
hmm..did you run disk clean and defrag, after uninstall?
Posted on Jun 16, 2008
  • 7 Answers
SOURCE: Job Status Window Interface has stopped working.
The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
you can copy and paste the following links to download and run the files :
Patch file to remove xp drivers:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
Driver for vista
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
Posted on Feb 17, 2009
SOURCE: trying to install printer Lexmark X5400 without errors
You have to buy a USB cable. It is written on the box itself.
Posted on Apr 15, 2009
SOURCE: IS034 Error when intalling driver software for MFC-490CW on vista
This issue is cause when the print spooler service isn't running, MFL pro installs the printer driver 1st (after paperport install) which will not wun if the service is disabled
Posted on Oct 09, 2009
Installation software for hp f4235
go to http://welcome.hp.com/country/us/en/support_task.html
Aug 04, 2010 | HP Deskjet F4235 AllInOne InkJet Printer
Want to install hp printer 845c in my computer
Before plugging in the USB cable you will need ti install sofware drivers.
Here drivers for Windows XP: Select software and drivers HP Deskjet 845c
On Vista the drivers are built in, see: HP Printers - Installing the Printer Driver Located in Windows Vista (SF)
On Mac and other OS see: HP Deskjet 845c Printer series - Download drivers and software ...
Dec 17, 2009 | HP DeskJet 845c Printer
HP Deskjet 3740 Series
You have to go www.hp.com select your region and product then you have to choose OS and now you can printer's driver for free for life.
Your problem will solve.
Aug 04, 2009 | HP DeskJet 3740 InkJet Printer
Unable to install HP deskjet F4288 All in one in laptop(OS Vista)
thjs is because some files needed for installation areorrupt.reinstall ur operating system again and then install printer drivers .it will 100% solve ur problem.
Dec 26, 2008 | HP DeskJet F4280 All In One Printer InkJet
HP Deskjet F4280 All in one will not scan
Open Paint, from Start>All Programs>Accessories and select File>From Scanner or Camera...
Dec 11, 2008 | HP DeskJet F4280 All In One Printer InkJet
Windows vista
Here is a link to HP Support to download the Vista software and driver.
F340 Vista Downloads
Uninstall any current software you have installed and reboot before downloading and installing the new software.
Nov 14, 2008 | HP Deskjet F340 All-In-One Printer
Hp deskjet 656c vista version
The driver you need is located in Vista already. Please follow these instructions from HP on how to install your printer under Vista.
Jan 23, 2008 | HP DeskJet 656c InkJet Printer
Printer hp deskjet D2360 installer
Click here and select your windows version to download driver
thanks for rating!
Jan 16, 2008 | HP Deskjet D2360 InkJet Printer
642 people viewed this question
k24674
