Question about Cisco 2610XM Router
Cisco 1721 router serial port not showing any loop.
Sir...i have cisco 1721 router. i have connected serial 0 port to 64 kbps modem and serial 1 to another 64 kbps modem.now both modems are connected back to back by 4 wire...but the serial ports are showing "serial up,line protocol down". and it is not showing any loop given from modem..configurations are correct modem also fine.router also showing serials ports connecting LED.....so where is the problem...
  • 1 more comment
  • pradip1069 Mar 24, 2009
    hi ,
    I have Cisco 1721 router.On modem line showing ok but in router line protocol showing down
    Please Help?
    Thanks& Regard,
    Pradip
  • Noe Lana
    Noe Lana May 11, 2010
    can you please paste here the interface of s0?
    thanks
  • lanmster54
    lanmster54 May 11, 2010
    Sir,
    Are you using the same 4 or 8 wire cord to the demarc for both modems? It may seem obvious, but...
    lanmster
    Sergeant:
  • 286 Answers
The problem is with your modem....did you tested the local loop from router to modem....are u getting local loop from one modem till router or not...try first checking local loop from modem to router...
Posted on Feb 11, 2009
How to config Wrt160N Router
192.168.1.1 usually. or 192.168.0.1 hope this helps
Jul 26, 2014 | Cisco Computers & Internet
Verizon dsl and cisco valet
Connect your computer directly to the Internet modem and make sure that you have Internet access directly from the modem.
If that is working properly then connect the modem to the Internet port on the router. Connect the computer to port 1 on the router.
Reset the router and configure it manually.
Here is link which will help you troubleshoot Cisco Valet M10 or M20 router
Mar 01, 2014 | Linksys by Cisco Cisco Valet Plus Wireless...
Im connected to my wifi internet in the office but i cannot open the internet . the brand of router is cisco WRT54G2VI, SERIAL #CSVO1HC21627, MAC.ADD 002369214852, ARROW SYMBOL UP DOWN 45103834, please...
If your computer shows you the little yellow triangle (limited connectivity) then you might have to reset the source of your internet, the modem if you can access it, by unplugging the power for 30 seconds. then reset your router by unplugging the power for 30 seconds so it can aquire a new IP address if you get the internet through dynamic settings. The router could also have a bad ethernet internet port. If you can connect to the router wirelessly and tried resetting it and if you can get internet being directly hooked up to the modem or source of internet such as a wall outlet...then your router may be bad.....if it is a Belkin...then it was junk to begin with.
Aug 28, 2013 | Cisco Computers & Internet
How do I connect cable modem to cisco 3560 switch and configure it?
The cable modem will need to go through a router because it needs a NAT and PAT translation table, connecting the cable modem direct would lose the ability to get to the internet.
Jun 05, 2012 | Cisco Catalyst Compact 3560-C PD PSE -...
I need to connect cisco 2800 router to my pc through hyperlink
I think you mean hyperterminal? you need a cisco serial cable (blue) and a serial port on your PC, maybe a USB to serial adapter if there isn't one. Set hyperterminal to use the COM port you have plugged in to, speed 9600 8 bit no parity. (8N1).
Without the serial cable you need to know the router IP and password.
Oct 31, 2009 | Cisco (UBR904) Router
Cisco 1721 Router IOS
I can help you with the IOS you need, but Cisco does not list 12.3.x XC, they only have YZ, YG, XR, XK, XG for this router. Email me at thrca@thrca.com for more help.
Aug 30, 2009 | Cisco (WIC-4ESW) 4-Port Ethernet Switch...
G'day, I have a Cisco 1841 router which I would like to get the cable or pinouts to connect a PSTN modem. The aux port is RJ45 and the modem db25
Here is the pin out:
RJ45 DB25
1 -------- 4
2 -------- 20
3 -------- 2
4 -------- 7
5 -------- 7
6 -------- 3
7 -------- 6
8 -------- 5
Jun 30, 2009 | Cisco (1841) Router (cisco1841)
ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Mar 27, 2009 | Zyxel IP Express IES-1000 (91004098002)
How to connect Nortel BSR222 (Business Secure Router 222) with tplink
rj11 are connectors used to deliver signals to a device. Mostly, modems will be able to support this type of connection. Make use of a modem, bridge it and connect the router to it.
Aug 17, 2008 | Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL...
Open Questions:
2611XM Inbound NAT/Port-forwarding/Service Distribution Problems My NAT port-forwarding is working on some servers but not all servers. Keep getting (111) Connection refused when trying to access a number of the servers from outside. Searched and searched..tested...re entered them..have not been able to figure out. Thanks, Greg interface FastEthernet0/0 description ***Outbound interface connected to ISP*** ip address xxx.xxx.xxx.xxx 255.255.255.248 ip nat outside ! interface FastEthernet0/1 description ***Inbound interface connected to 2924 Core Switch-port 1*** ip address 192.168.15.1 255.255.255.0 ip nat inside THESE TWO WORK ip nat pool xxx_SAP 192.168.5.2 192.168.5.2 prefix-length 30 type rotary ip nat pool xxx_webserver 192.168.5.130 192.168.5.130 prefix-length 30 type rotary ! ip nat inside destination list 101 pool xxx_webserver ip nat inside destination list 102 pool xxx_SAP ! access-list 10 permit 192.168.0.0 0.0.255.255 access-list 101 permit tcp any host xxx.xxx.xxx.xxx eq www access-list 102 permit tcp any host xxx.xxx.xxx.xxx eq 3299 access-list 102 permit udp any host xxx.xxx.xxx.xxx eq 3299 THIS IS ONE OF THE ONES THAT DOESN'T WORK ip nat pool xxx_RDP 192.168.5.11 192.168.5.11 prefix-length 30 type rotary ip nat inside destination list 115 pool xxx_RDP access-list 115 permit tcp any host xxx.xxx.xxx.xxx eq 8089 access-list 115 permit udp any host xxx.xxx.xxx.xxx eq 8089 xxx_distribution_1#sh ip nat statTotal active translations: 1504 (0 static, 1504 dynamic; 1504 extended)Outside interfaces: FastEthernet0/0Inside interfaces: FastEthernet0/1, FastEthernet0/1.5, FastEthernet0/1.10, FastEthernet0/1.15 FastEthernet0/1.20, FastEthernet0/1.25, FastEthernet0/1.30 FastEthernet0/1.35, FastEthernet0/1.40Hits: 4130866 Misses: 93029CEF Translated packets: 4158864, CEF Punted packets: 110268Expired translations: 109237 Dynamic mappings: -- Inside Source [Id: 1] access-list 10 interface FastEthernet0/0 refcount 1469 -- Inside Destination [Id: 2] access-list 101 pool xxx_webserver refcount 22 pool xxx_webserver: netmask 255.255.255.252 start 192.168.5.130 end 192.168.5.130 type rotary, total addresses 1, allocated 22 (2200%), misses 0 [Id: 3] access-list 102 pool xxx_SAP refcount 13 pool xxx_SAP: netmask 255.255.255.252 start 192.168.5.2 end 192.168.5.2 type rotary, total addresses 1, allocated 13 (1300%), misses 0 [Id: 14] access-list 115 pool xxx_RDP refcount 0 pool xxx_RDP: netmask 255.255.255.252 start 192.168.5.11 end 192.168.5.11 type rotary, total addresses 1, allocated 0 (0%), misses 30
Feb 26, 2017 | Cisco 2610XM Router
Cisco 2610XM Router Logo
589 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
