Question about Symbol PPT 2800 Portable Terminal
Symbol PPT 2800 Scanner Problem
One of my 2800's is only throwing a scan beam about 1/2 inch wide. The others are much wider than this, which means that they are usable. Is there any way to adjust this errant scanner that doesn't involve sending it to Symbol and writing them a big check?
5 Suggested Answers
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
  • 4 Answers
I'm sure it will help you
Posted on Apr 28, 2008
  • 97 Answers
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Posted on Mar 26, 2009
  • 31 Answers
SOURCE: Windows Mobile Symbol Find WLAN error
Warm boot the MC55 if that doesn't help then cold boot it, if that doesn't help then reload the Operating system, if that doesn't fix it then send it back to Motorola for a warranty repair.
Posted on Jun 30, 2009
  • 724 Answers
SOURCE: Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Posted on Jul 27, 2009
0 characters
1 Points
Does anyone have a successful experience using this to scan outdoors in full daylight?
not sure if you found a solution , but I figure I''ll share mine anyways.
we had the same problem in scanning outdoor so this is what we did:
there are 2 types of MC9090 standard range and short range. the short range works batter for outdoor sine it has a wider longer beam. you will loose in distance , you will have to come closer to scan but it will work ....
let me know if you came up with something else ...
Aug 06, 2009 | Symbol MC9090 Barcode Scanner
Can the Symbol LS4804-I400A scanner scan a QR code bar code?
No, this is a Laser Scanner. The laser beam can scan the barcode only in 1 direction (1D Barcodes). For QR Barcode (2D) you would need an Imager (Digital Scanner).
Jul 14, 2009 | Symbol LS 4800 (LS4804-I400A)
Need a users manual
Hello, You will get the reference guide for your Symbol PPT 8800 scanner in the following link. Hope it helps, Good luck! ~regards, Jegan
Jun 03, 2009 | Symbol PPT 8800 Wireless Barcode Scanner
Laser beam too short
We can change the scan engine for you if you'd like - it's the only way to solve your issue. You would need a Lorax scan engine (scan up close up to approx 32feet).
Let me know if you'd like more information:
DC Solutions
Sep 24, 2008 | Zebra Symbol Technologies MC909X-G Series...
How to hard reset my symbol scanner (model #: PPT 2846)
Hello - you may need a board level repair:
Let me know if you need help with this
DC Solutions
Aug 28, 2008 | Symbol PPT 8846
Symbol PPT 2800 Portable Terminal Logo
47 people viewed this question
Top Symbol Barcode Scanners Experts
Brian Friend
Are you a Symbol Barcode Scanner Expert? Answer questions, earn points and help others
