Question about Samsung CLP 300 Laser Printer
Samsung CLP-300 has grinding rollers
Recently the rollers on my Samsung CLP-300 started making a grinding sound.  The area gets very hot and the printer refuses to print.  Do the rollers need to be replaced and if so, are they available to order?
Thanks
  • 2 more comments
  • dafini Nov 27, 2008
    I've got the same problem, no idea what it is. Sounds like it's eating the paper.
  • dhp523 Nov 28, 2008
    I am having the same problem. It is a fairly loud popping noise as if there is a plastic/nylon gear that is slipping.
  • Niko Flocke Jan 24, 2009
    I have the same Problem.
    While this is happening i can push the front left part of the lid (which covers the ink tanks) and it stops. Once i let go of it, it starts again =(
  • Anonymous Apr 30, 2009
    My Samsung CLP 300 pulls the paper in just a little crooked so that checks print badly and each page is cut off just a bit at the top
Mine is the same way, to solve this I elevated the bottum by 2 inches, then i kept it off, also i blow a fan on it while running. also, you need to clean the filter (the gray "L" inside) black dust should come out. lastly, mine actually broke because it overheated. matt
Posted on Jun 05, 2009
Samsung CLP-310 Colour laser doesn't print properly
This is not a driver or Windows issue, has the ink cartridges been changed recently, it sounds like the the paper is not being magnetically charged before the ink, unplug the power cord for 30 sec plug back in and try printing again
Nov 07, 2013 | Samsung CLP 300 Laser Printer
Samsung CLP-300 paper does not seem to be catching when printing?
Hi. Kelly,
I think the issue is the due to paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam etc.. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with damp (with luke-warm water) and lint-free cloth. I hope this would fix the issue. If the Roller is damaged or worn out, it needs to be replaced.
Hope this helps! Good Luck!
CreativeTECH
Feb 15, 2011 | Samsung CLP 300 Laser Printer
We have an samsung clp 300 printer. problem is it makes a grinding sound with the gears plus paper feed takes paper put then stops half way
The grinding sound is usually caused when the toner cartridge gear is slipping with the one in the imaging unit. To troubleshoot, remove the toner cartridge and turn the gear by hand and check for binding. It should turn freely, if it doesn't there nothing you can do but to replace it when it gets empty. Another cause of the gear slipping, is that sometimes the cartridge contacts force it out of the socket so it does not seat properly. To fix, try pressing on the cartridge contacts with the back end of a pen a few times to see if that will free up the contacts.
If your printer get paper jams when it starts to pull the paper from the cassette. This is caused by a dirty paper pickup roller. If it is not too worn out, you can fix this by using a damp cloth and clean the roller. Hope this helps you.
Jan 31, 2011 | Samsung CLP 300 Laser Printer
Samsung clp 300 starts to feed paper but stops feeding (jams?) midway
This is a common problem with both this and the Xerox phaser 6110 (a rebadged Samsung)
It is due to the pickup roller "tyre" that is the rubber roller that pulls the paper from the tray.
It gets shiny and slips on the paper.
The cure is to "rough up" the roller with some sand paper or emery cloth.
The best way is to remove the imager unit and store it in a cupboard or a box IN THE DARK.
This stops toner getting everywhere.
Remove the paper tray turn the printer on its side you will see the roller underneath, using some sand paper or similar carefully rough up the rubber roller all round.
now put the machine back together and try printing it should be ok, if the problem persists try repeating the process.
Jan 05, 2011 | Samsung CLP 300 Laser Printer
Samsung CLP300 - All LED lights red and getting very hot when on
drl1069.dyndns.org/Public/CLP-300.pdf Ok above is your service and repair manual, inside is all troubleshooting procedures used by the engineers to troubleshoot and repair these units.
May 11, 2010 | Samsung CLP 300 Laser Printer
Paper jam at exit
The rollers at the exit area are worn out. They can be changed, in the mean time you can use something like sand paper to rub across the rollers to take the smoothness out of them. That will help them get a grip on the paper as it is exiting.
Jun 02, 2009 | Samsung CLP 300 Laser Printer
My CLP-300 makes a loud clicking sound and sometimes a grinding sound when printing. I am thinking about getting a replacement but the machine is not that old. If it can't be fixed, what can you...
did you use a non samsung replacement cartridge? I had this problem with one i used the gear on the cartridge would slip and sometimes even push the cartridge loose. replacing it cured the problem
Apr 03, 2009 | Samsung CLP 300 Laser Printer
Gringing noise when printer boots up and when it prints
Probably worn gears for the rollers along the paper path or the gears that mesh with the imaging roller in the toner cartridge. Remove the toner cartridge and reseat it. Also look for any rounding of the gear teeth on any of the rollers while you have to cartridge out.
Mar 18, 2009 | Samsung CLP 300 Laser Printer
Clp-300 with printed lines
when you remove the imaging unit, look into the area and you will see a black shiny belt, make sure there is nothing on their.
Mar 30, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
524 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
