Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Dishwasher has lights but won't do anything
I changed my disposal recently. I am not sure if washer has worked correctly since then. Brand new whirlpool DU1048 built in with electronic buttons. Right now, dishwasher has water up to bottom of door and won't drain or resume. Dishwasher will allow you to push any buttons and they light. When you hit cancel/drain it makes a faint sound like something is going on, but no water exits. When you hit resume/start, it make a sound like it is resuming the draining, but nothing happens. The noise is so faint, you can hardly tell if it is actually doing anything at all. Had less than 60 days and no problems until now.
  • Anonymous Sep 20, 2008
    i have the same problem .it does notihin lights comes on. no humming sound. i had to remove te dishwasher when i was getting kitchen done .since it doesnot work.
    thanks
    sam.
    President:
  • 878 Answers
Jacksonville, did you remove the knock-out for the drain on the disposer? Use a screw driver and punch it out. Let us know if that did the trick..Catriver..post back.
Posted on Nov 23, 2006
The disposal will not work untill i take the wrench and turn it a few times then it works fine but the next day i have to do the same thing and it works.Can i lubricate it.???
Garbage disposal mechanism cannot be disassembled for repairs.
Disposal will need to be replaced at some point.
I wrote tips for replacing disposal from days when I worked apartment maintenance.
Here are basic disposal parts:
1) Sink basket that connects to sink and is held with 3 screws from below.
2) Disposal body which connects to sink basket using metal ring.
3) Rubber washer between disposal and sink basket.
4) Dishwasher connection at upper part of disposal with a hose.
5) Electric wire from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connection on side of disposal
In apartment maintenance, we replaced disposal with same size and brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Using hammer and screwdriver, rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, black wire to black and white to white, and push in red reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Lift new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, Use new washer.
Connector ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
Image shows direction for connecting new disposal.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove 3 screws that hold sink basket, remove basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Always slap a good amount all around washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 20, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 is leaking from the bottom around what seems to be the electrical cord opening. any suggestions
Your disposal is rusted out and needs replacement.
4) Dishwasher connects to upper part of disposal with a hose.
5) Electric wire coming from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connects to side of disposal
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
When I worked apartment maintenance, we replaced disposal with same size and brand disposal.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal, or any do-it-yourself project.
Jan 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Garbage disposal works and it turns but it sounds as if something is loose in there...it's the Insinkerator 5-81.....Is it possible the cutting blades are loose and if so, how do I fix this?
Garbage disposals can get noisy and sound like they're eating spoons instead of banana peel.
You can put vacuum hose in sink opening and see if something is in there.
As long as disposal is not shaking around a lot, and causing pipes to leak, then you can use it until it dies.
Here are basic parts:
2) Disposal which connects to sink basket with metal ring.
3) There is a washer between disposal and sink basket.
4) The dishwasher connects to disposal with a hose.
I wrote tips for replacing disposals that you can use when disposal gives out.
When I worked apartment maintenance, we replaced disposal with same brand and size disposal.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Attach electric wire to new disposal, and push in reset button.
Attachment ring catches at three points, all three have to connect.
Remove old sink basket and clean sink opening.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 04, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 9 disposal just stopped working. It is less than 2 years old. The blades turn freely, the reset button is in. It does not make any noise. Any other ideas?
1) Test disposal is getting electricity and switch is not bad.
Pull out switch so you can test wires:
Switch in ON position.
Use ordinary tester and test each brass screw to bare ground wire.
Tester should light up on each screw.
2) Next open wire connection at disposal and test & check wiring.
Be careful under the sink. Do not touch anything metal while working on live electricity.
Stay on completely dry surface.
3) In event of bad disposal, I wrote installation tips.
These tips do not include installing new disposal and taking old one back in same box as if it was a defective product.
Attach electric wire to new disposal.
Push new disposal up into place, and attach to old sink basket.
Use new connector washer.
You might want to install new sink basket that comes with new disposal because it looks shiny and new.
Jan 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
One of the grinder broke inside the unit, is this a replaceable part?
If disposal has loose parts inside, you have to replace the disposal.
If disposal still work and doesn't vibrate and loosen pipes under sink, then it's ok.
The don't sell replacement parts for disposals.
I wrote tips for replacing disposals:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
Jan 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My in-sink-erator model 5-81 is just over 2 years old and is leaking from the sides whether it's running or not. Is there anything I can do or do I need to contact a professional>
Find out exactly where leak is coming from.
You say water is coming from the side... is that where the pipe connects? Then take apart pipe and reassemble pipe using instructions below, and use rectorseal on joints as described below..
Is water coming from where dishwasher connects to disposal? Then tighten the clamp.
Is water coming from top where disposal connects to sink? Run paper towel around top to check for moisture, and then use steps below to dissemble disposal and re-install same disposal.
Is water coming from a rusted hole in disposal. Then replace disposal using steps below:
Here are the disposal steps:
That way we didn't have to change out sink basket or change pipes.
How to: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Remove old sink basket and clean opening.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Apply good amount on washer just before pushing washer in place and attaching nut.
Add a comment
Dec 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal work and the reset button doesnt reset. There is no jam. Turned off power and checked for electricity--ok. Noticed that plastic was in the disposal when cleaning out. This is a 1/3 hp...
Disposals go bad.
If reset is popped out and won't reset when power switch is turned OFF, then that says reset button is bad.
Reset button cannot be replaced on disposal, so disposal is no good.
Your question said you checked following things, but it doesn't hurt to review.
If reset keeps tripping, then disposal has internal short.
Check for power at switch to see if switch is bad.
Check for power at disposal where wires connect.
Put wood broom handle in disposal and see if cutter disk rotates freely.
Use vacuum cleaner to remove unwanted debris from disposal.
I wrote tips for replacing disposal:
Add a comment
Dec 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking from the bottom of the disposal in the connection area.
Disposals rust out and need replacement.
Check a couple things first.
Run paper towel around top of disposal to see if moisture is leaking from around sink basket or dishwasher hose connection. Then check where tailpiece connects on side of disposal.
If these places are dry, the disposal has probably rusted out.
I wrote instructions for disposal replacement:
How to change disposal: Disconnect p-trap and tailpiece going into disposal.
On image below loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Apply rectorseal where lower p-trap comes together.
Add a comment
Dec 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage Disposal is about 2-1/2 years old It is now no longer grinding up potato peels and clog every time! HELP--do we need a new one!!!
1/2 horsepower is the lighter weight model, and if you use it heavily, then it will not work like before.
Another thing to consider is whether the water is draining away completely while you're cutting.
If water and potato peels are both present, your p-trap and tubular drain may need to be cleaned.
Let's go through the whole thing: replacement, p-trap, tubular pipes, everything.
That way we didn't have to change out sink basket or move pipes around.
How to replace disposal body: Disconnect both nuts on p-trap. Remove p-trap and loosen tailpiece going into disposal.
If this is your home, you might want new sink basket that comes with new disposal because it looks shiny and new.
On image above, loosen both nuts on p-trap, trap falls loose, and then work on disposal.
Add a comment
Dec 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
While using our garbage disposal this afternoon, it went from grinding to humming. The blades do move freely, but the plate is very loose and tips. Is it possible to tighten the plate?
There is no way to tighten plate that I know of.
Maybe a clever welder could stick it back together, but the problem implies something underneath is rusted out or broken. The main thing is the cutter plate, and if disposal wobbles, it will loosen drain pipes under sink and cause dripping.
I wrote some tips for installing new disposal, and include them here since disposal will be replaced at some point.
That way we didn't have to change out sink basket.
How to replace disposal:
Make sure there's enough putty that it squeezes up all around sink basket.
Add a comment
Dec 06, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
136 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
