Question about ASUS A8N32-SLI Deluxe Motherboard
A8n32-SLi Deluxe - Will not boot
Connected a corrupted IDE hDD from a friends PC.
After that my PC wouldn't boot.
Remove the faulty HDD and PC booted up again.
Reconnected the HDD again after changing jumper settings. Still wouldn't boot.
Remove the HDD again and reset the CMOS, computer fails to boot up at all.
Check the RAM green light on the mother board is on. Disconnected everything from the MOB other then PSU, CPU, RAM and VIDEO card. Still will not boot.
Is it possible the CMOS is corrupted ? or I have blow my mother board up.
I am about reseat the video card and the RAM again and check all cables again.
  • 1 more comment
  • doom92 Nov 17, 2008
    Still no luck computer is still dead.
    remove the ram again, video card, cleaned the mobo, tested the PSU with a multi-meter which is fine.
    no blown capacitors on the mother board.
    the only other thing we are thinking is the BOIS has been corrupted or a circuit
    has blown out on the mobo even though there is no signs of it. There is power to the mother board as the green light is on and there is power to my card reader and the mouse.
    whats involved in getting the BOIS fix if we can't get the computer to boot.
  • Anonymous Feb 04, 2009
    any solution to this is have the exact same problem
    chip is fine..
  • Seabizkit Feb 04, 2009
    i have the same problem
    ive checked the chip -works
    checked slost - look line
    blown out the MB including slots
    tried different ram
    tried different ram slot combernations
Your bios can be reset to defaults by removing the CMOS battery, then moving the little blue jumper to the right of it from the 1-2 pins to the 2-3 pins fpr 10 seconds, then place it back onto the 1-2 pins, replace the battery and boot as usual.
Posted on Dec 10, 2009
  • viper seeb Jan 04, 2011
    honestly U SAVED MY ***!! there is no docuementation on how to reset the bios and after a failed over clock it all went wrong and the MOBO manual dont show where the reset jumper is..
    TYYYY SOO MUCHHHH!!!!
Reset CMOS as stated in motherboard manual. When rebooting use only 1 stick of RAM in the B1 slot, as probably indicated in the motherboard manual :)
Posted on Feb 13, 2010
  • ASUS Master
  • 32,281 Answers
It is possible that the CPU has stopped working, it is easy to replace or test it on another computer, make sure you test or replace with the same model CPU with the same specs.
If it is the BIOS that is faulty, then it is difficult to identify and replace, especially if it is a surface mounted IC chip. On older computers the BIOS is easier to identify and sometimes it is labled with the makers name (eg, Award, AMI, Phonix etc.), and sometimes it may be inserted in a DIP IC socket which makes it easier to replace. If it is soldered on the motherboard it may be a bit difficult to remove without damaging the motherboard, although it can be done with care. I suggest you use a fine tipped temperture controlled soldering iron.
Posted on Nov 17, 2008
  • ASUS Master
  • 32,281 Answers
What are you trying to do with your friend's hard disk?
Are you trying to install it as a slave drive so you can see what is on his hard disk, if so you need to set the jumper on his drive to be a slave drive and your drive as a master or master with slave drive.
The easiest way to connect a second drive temporally to your computer without opening your computer is to use and external USB hard drive adapter/case (ie a USB external hard drive case) and all you need is to plug it into your USB port to view the contents of that hard drive.
Posted on Nov 15, 2008
  • 50 Answers
Remove all the removal devices, clear the cmos, blow off the ram slots and then try if u can boot.
  • Ismail Shifau Nov 15, 2008
    u can try cleaning the pci slots,and ram slots , usually this happens when a card is not plugged in completely in other words short circuit.firstly just blow ur motherboard and then clean the slots and the cards with some anti static cleaner or u can try surgical spirit it does the job. let me know if u need more assistance.
Not support 500gb harddisk
Check the BIOS if the harddrive is begin detected if not check to see if your raid or ide drivers are installed if correctly installed HDD hes corrupt file... download (live boot) iso burn on cd and boot with cd with your 500gb HDD connected
Jan 31, 2013 | MSI 845GVM-V (MS-7057-010) Motherboard
GA-EP41-UD3L problem with SCSI/IDE
Sounds like the motherboard bios is only capable of booting from drives connected to the motherboard's ide connector and not additional / or external ide connectors. Looks like you would have to have 1 HDD and the CDRom Drive on the built in ide connector and the other hard drive on the extra ide connector you added. Although that would probably stop the other HDD from booting. Have you thought about putting both operating systems on the same drive. I do it all the time.
Feb 11, 2012 | Computers & Internet
"A8n32-sli deluxe" SATA support disapeared
call or visit ASUS support forums, you may need to RMA this board.
Aug 09, 2009 | AMD ASUS A8N32-SLI Deluxe Socket 939...
2nd sata connected and xp won't boot
It seems you have not made the second SATA the slave of first SATA. You'll have to fix the jumper pin in the designated slot to make the second SATA the slave. a1d66e3.jpg
Jul 07, 2009 | ASUS A8N32-SLI Deluxe Motherboard
IDE#0 ERROR
Usually the HDD is set on IDE #0.
The PXE error appears if the notebook tries to boot up from the LAN but the cable is not connected or there is no possibility for LAN booting.
In my opinion there is something wrong with the HDD or the BIOS cannot recognize the HDD correctly. I would recommend checking the HDD pins. Furthermore you should change the booting order in the BIOS.
Apr 24, 2009 | Toshiba Satellite A100-S8111TD Notebook
Screen does not work
Make sure your video card is fully secured down if it is and you still have the same issue check and make sure for compatibility otherwise you video card is cooked.
Mar 19, 2009 | ASUS A8N32-SLI Deluxe Motherboard
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
Help please
*check wheather hdd cable(ide cable) is connected properly
and powerconnecter also
* set hdd to master in jumper setting choose first from right of the power connecter
*change the ide cable ie hdd cable
* go to bios by pressing F2 or F8 or Del while booting and in that
bootsequence enable first boot device as hdd and save &exit
Mar 13, 2008 | Microsoft Troubleshooting Your Web Page...
ASUS A8N32-SLI Deluxe Motherboard Logo
1,199 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
