Question about Sony VAIO VGN-SZ460N/C Notebook
I like to replace old hard disk
Can you tell me how to access the hard disk on my laptop
  • Dave Gman
    Dave Gman Nov 17, 2008
    Thank you, I got it.
  • Sony Master
  • 32,281 Answers
There are panel/covers on the base or near the bottom edge of most laptops these enclose the RAM and hard drive. Remove these screws and covers to reveal the hard drive and possibly the hard drive carrier.
Before you attempt this I suggest to login to the Sony WEB site and download the drivers for the graphics and sound device including modem and LAN if you don't already have them and back up your data. You will need these drivers when you install a new and larger hard disk and the operating system.
Posted on Nov 15, 2008
Please how can i fix this problem of this kind my laptop is showing no-system disk or disk error replace and strike any key when ready
Invariably there has been a hardware failure of the primary hard disk with operating system (also known as HDD)
You would have to replace it with a new disk and try to restore as much data (if you are lucky) from the old disk.
It would we wise to install SSD instead of the old tech HDD if there is still some life on the laptop
Alternatively, if you are a tech geek (and if your laptop supports)
- Verify if the BIOS is able to recognize the HDD.
- Set bios for boot from usb
- Boot from a USB stick and try to access the hdd
- Recover as much data as possible
- Run a disk diag
Sep 30, 2016 | HP Computers & Internet
Laptop very very slow to start up
If you have a virus program installed, it ismost likely is running a scan on your hard disk. It can slow down your computerespecially if you have a large hard drive.
To make your computer (hard disk) lean and mean, uninstall any programs you donot use.
Also you need to maintain your hard disk by running Disk Cleanup this willremove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plusrun Defrag. this makes your files contiguous so the system can access filesoff the hard drive quicker because it does not work as hard.Disk Cleanup and Defrag should carried out at leastonce a month.
Jun 13, 2012 | HP Compaq 6720s Notebook
Acer Extensa 5420-5038 Laptop I have access to the CMOS (via master password) but i cannot get access to the Hard Disk (also password protected) Any suggestions?
The hard disk passwords can be removed only by the manufacturer, at great cost - over $500 per disk. Unless you have really critical files that you cannot lose you should just replace the hard disk and reinstall.
May 31, 2011 | Computers & Internet
My new laptop see the toshiba sata mk1646gsx from my old -damaged- laptop but i can't use it when i connect it by USP conection, because it has password, how can i use my old hard didk
Your old hard disk may have been password protected (it may have the same BIOS password that was used on your old laptop). To access the data on the old hard drive, enter the hard disk password and if it is correct, you will get access to the data on the old hard drive.
Apr 06, 2011 | Computers & Internet
Hi everyone, I'm new here and I hope get along with all of you and also to get an answer to my problem :) First of all, sorry if I may be long but I like explaining in detail so that you can understand my...
When you have everything connected and are ready to access the old hard drive, right click in the drive and see if you get the run as administrator option, if you do, click on it and log in as the administrator of your machine, if you don't get that option, go to the control panel and security and disable the User Account Control, reboot and you should be able to access it. just be sure to turn it back on later.
Jan 18, 2011 | HP Computers & Internet
Install new hard disk??
Turn your laptop over so you can see the buttom. There is a panel at the side of the laptop and two screws holding it down. Take the two screws out and slide your hard drive out. Remove the screws at the side of the hard drive caddy and installing new one is reverse of removal
Jul 22, 2010 | Toshiba Satellite M30 Notebook
Installing windows on acer notebook help
you cannot usually switch installed operating systems from computer to computer like that and still expect windows to boot, but with windows 98 it *might* work.
to install windows 98 on the usb drive, insert and boot from the windows 98 disk like you were to install it on that computer , and then, it should, before it formats any drives, give you a choice of what drive to format.
Oct 09, 2009 | Acer TravelMate 340T Notebook
How can I access the hard disk to replace it?
most laptops you can access the hard drive very easily. there is usually a cover on the bottom that when removed allows you to pull out the hard drive and replace it. The only issue is if you have a restore disk for your laptop to restore the o/s after replacing the hard drive
Jul 17, 2009 | Sony Computers & Internet
Whenever i insert an external hard drive, it tells no drivers
It is possible when *********** board is of old model.
you should update your computer's hardware system.
try your hard disk in your friend's computer, if it will work ther, that's mean *********** board can't support your hard disk, try hard disk of small sizes.
Jul 06, 2009 | Toshiba Computers & Internet
HDD prob
The machine should recognize that there is a hard drive there, if it doesn't then the hard drive has crashed or failed. You will have to replace it.
Jun 24, 2008 | Dell Latitude C610 Notebook
Sony VAIO VGN-SZ460N/C Notebook Logo
176 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
