Back to:
Tags:
Teac Floppy Drive FD-235HF Internal Floppy Drive
REPAIR FLOPPY DRIVE
posted by ULISEL on Nov 22, 2006
I'M LOOKING FOR A SOFTWARE TO ALIGN DE TEAC FLOPPY DRIVES HEADS.I KNOW THAT THERE IS IT, THIS FLOPPY HAS SOME JUMPERS BEHIND.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 29, 2006
FixYa! (100)
Keeter
Rank:Master Master
Rating: 85%, 136 votes
There are a few different applications that can aid you in doing this. Here is one. http://www.accurite.com/AAD.html Most often than not, the heads will not be realigned properly with such software, and the cost of purchasing the mechanical tools to do it manually and the time and energy it takes outweigh the cost of just buying a new drive. If you are having read/write problems, and an inexpensive head cleaner (http://pc-extras.com/prods/cl35ck.html) does not solve the problem, I would recommend replacement.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on REPAIR FLOPPY DRIVE:
I don't want to Accept this solution
Solution #2
posted on Dec 28, 2006
Not Rated (0)
mrast
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I used to do this for a living and at $25 for a new drive its not worth the time or cost to realign the drive.
Thank You!
Can you Help with these Floppy Drives problems?
Floppy Drives
1. if a rectangle has a length that is 3cm less than four...
Floppy Drives
A positive number is 5 times another number.If 21 is added...
Floppy Drives
back lite is ok, but no data on display screen
Floppy Drives
The community concert hall is hiring a new agency to sell...
Floppy Drives
The monthly cost (in dollars) of a long-distance phone...
Loading problems.
Repair Service
Find Floppy Drive Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
