Question about Philips DVDR3455H/37B
Dvdr 3455H/97 hard disk unable to reboot
My 2-yr old dvdr 3455 hard disk unable to reboot. If I buy a new hard disk I need the software to make it work with the dvdr. Where can I get the firmware?
  • 4 Answers
From krystle i am an electronic tec:
what i have found the big difference between the philips dvdr3455h and the dvdr3575h is the
dvdr3455h boot from software on the hard drive and the dvdr3575h boot from an eprom.
the dvdr3455 has both booth software and movie edit software, if the hard drive become
bad in the 3455 or the software become corrupted it wil hang at the philips logo screen.
the dvdr3575h will boot with a bad hard drive or no hard drive at all you will you wont be able to
capture your video to the hard drive.
if the movie edit software become corrupt or damage when you press record button
it will just lock up the recorder.you will need a software reload if the software become corrupt.
if you need a reload on your hard drie email me i will tell you what you need to do my email is krystle913@yahoo.com
Posted on Jan 27, 2009
My laptop will not start up and I have no boot up disk
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Dec 02, 2012 | Acer Aspire 5349-2592 Intel Celeron B800...
I lost manual of my Philips hdd & dvd recorder.The model is DVDR 3455 SH. Please send me another copy. Thankyou
is this what you needed?
http://download.p4c.philips.com/files/d/dvdr3455h_37/dvdr3455h_37_dfu_aen.pdf
Apr 19, 2011 | Televison & Video
I need a Hard Disk for DVD LG Ref. RH399H
I believe you are looking for a 320 GB replacement drive, I would remove the one in there first to check which brand it is, and then just replace it.
LG haven't release any information saying that the hard disk has any specific brand (or as far as i have read about them) And the software to run the drive should be separate. The only info i cannot provide, is the formatting options. You would need to check that with your PC first by putting the old drive in your pc and checking the formatting on the old disk, then just format the new one to the same file system and it *should* work. I say should strongly because sometimes there are hidden gremlins in problems like these, and I don't want you to go ruin your player but taking my advice as you would from an LG representative. I do work in the I.T. industry and all of the DVR recorders I have seen just use a normal hard disk with certain filing systems.
Hope this helps, anymore problems, just ask!
Nov 23, 2010 | LG DVDR 313 DVD Recorder
When I start it it says operating system not found, and stops loading!
When you start it up press f2 to enter bios. Go into boot configuration. Make sure the boot order is:
1. A:/ (floppy)
2. D:/ (cd drive)
3. C:/ (hard drive)
If the boot order is correct make sure your bios are registering your hard drive. If it's not then replace the hard drive. If it is then reformat and re-install the operating system.
Aug 16, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Macbook black will not start beyond the initial 'bong'. Blue screen followed by endless spinning gear. PRAM, SMV reset, no go. Safe mode can't complete. With battery or on power adapter same result....
Hello yang2699tlk,
Try this instead of using your Leopard Disc.
  1. Immediately after the "bong" press and hold down "Command + S".
  2. Wait for blinking cursor and then type fsck -y (exactly like that).
  3. If you receive an "Appears to be OK" then type reboot and hit the return key.
  4. If you receive a "Disk has been modified" then repeat the fsck -y command until you get an "Appears to be OK" then type reboot and hit the return key.
This set of commands entered in "Single User Mode" will repair your disk. If this does not work remove the hard drive, plug it into another Mac and transfer your data to a different computer. Then install a new hard drive and reinstall Mac OS X.
Hope this helps, don't forget to vote. Thanks.
Feb 27, 2010 | Apple MacBook Pro Notebook
Actually I have a 4 yr old dmr eh50 panasonic dvd recorder
Make sure remote is set to unit code ex: press enter and 1 at same time see if this matches try enter and 2 or enter and 3 see if this matches and works
Oct 03, 2009 | Panasonic DMR-E50 DVD Recorder
Is there firmware update for Philips DVDR 3455H ?
Well you get your firmware from below link -
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_HARDDISK_RECORDERS_SU&session=20090905122441_125.63.122.112&grp=HOME_ENTERTAINMENT_GR&ctn=DVDR3455H/37&mid=Link_Software&hlt=Link_Software
Good Luck!!
Thanks
Jul 14, 2009 | Philips DVDR3455H/37B
Firmware update
Email address is scott.ferris@dsl.pipex.com
Many thanks for this
Greatly appreciated
Scott
Jun 24, 2008 | Philips DVDR3455H/37B
Program information!
if its a laptop u need to buy an external hard disk case to connect yr old drive so when pluged to the usb port the system see's it like flash drive so what yu do flash drive yu do to it..
if its a desktop system then u need a second hard drive cable so u can connect it to the IDE-2 port on yr motherboerd then boot yr system yu should see the second drive as d: in my computer so u do the normal copy and paste from d: to c: if u dont have a second hard disk cable(bus,data cable) then yu will need to use one cable to connect the 2 drives by making the good one a master and the bad one slave through the jumper settings.
hopes this helps
do give me feed back when done.
May 29, 2008 | Computers & Internet
Philips DVDR3455H/37B Logo
1,799 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
