Question about Beko 24 in. D3731F Free-standing Dishwasher
Beko dishwasher lights on but won't work
My Beko dishwasher has just stopped working, lights are on but it wont go through its cycle, its not making any noise at all.
  • 4 Answers
SOURCE: cycle wont run and lights on main washes flash
When you switch it on can you still select the wash type ?
If you can, when you shut the door does it start the cycle normally by pumping out the sump, but then when the wash pump (the cause of the main noise during the cycle) would normally start it stops and beeps - opening the door then shows the flashing error code ?
If your symptoms are the same as above or similar, suspect the heater is stuffed. My BFI62 did the above and it turned out to be a faulty (open circuit) heater. As I had no knowledge of dishwashers at the time, I called in a repair guy. As soon as he saw the fault code he suspected the heater - seems a batch of heaters (from the USA) had proved very unreliable (apparently Hotpoint got compensation from the manufacturers because of the number of problems it caused them). The replacement was made in Germany and the repair guy said he'd not known one of those to go faulty !
The repair guy diagnosed the heater open circuit from the control panel inside the door without even removing the dishwasher from it's location. Unfortunately, I didn't have a chance to note which wires ran off the board to the heater. Changing the heater needed it out and on it's side (be prepared for quite a lot of water on the floor).
Finally, when he'd fitted the new heater, it took him two goes to get the pipes either side of it to seal properly - quite common apparently and the source of even more water on the floor !
Hope this helps.
Posted on Jan 01, 2008
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Posted on Jan 10, 2008
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
  • 187 Answers
SOURCE: Brand new dishwasher, doesn't drain water and will not work now!
try this site Noise During Washing or Drying
please rate my suggestion..
Posted on Apr 12, 2009
  • 909 Answers
SOURCE: Dishwasher not cleaning properly, and not stopping
Your fault is not the normal complaint. Question is, "are you sure it doesn't just keep on running during the heating cycle"?. My thoughts are the heating element is possibly not functioning which will disrupt the continuing of the cycle.. Check element for a resistance reading,(approx. 23ohms). Check for a thermal cut out (sometimes a little reset button found on an item with wires attached). Press until click is heard.Retry. If all this heating does happen, then there is definitely an issue with the timer being it electronic or mechanical. Please let me know if not the solution. Thanks.
Posted on Sep 26, 2009
Beko dishwasher doesn always fill with water but makes sounds as if it does. Other times it works great any ideas?
depending on chosen wash cycle washers are not always supposed to 'fill' just use enough for that cycle .
If you mean sometimes no water at all and sometimes water with same settings check hoses and valves .
make sure valves are fully open hoses securely attached and hoses from valves to washer are not pinched twisted or damaged.
Hopefully the water not getting in the washer isn't leaking all over your floor below the washer.
Jul 18, 2016 | Beko Dishwashers
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
I have an ariston built in dishwasher. It wont start washing cycle, and has 2 flashing lights from the left
Here is a dishwasher manual search engine, they will find the Beko user manual within minutes. Just send them a search request for your model.
Aug 11, 2012 | Dishwashers
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
I have a Beko DE2431FW Dishwasher which has stopped working. I select a cycle and then press start, the green light starts to flash and the cycle begins to start but after about 30 seconds it stops and the...
Can be that you have a leak somewhere.
At the bottom is a reservoir with a plunjer , wich switches everything off when this reservoir is full.
This is to prevent , that your kitchenfloor gets wett
Nov 20, 2017 | Dishwashers
I have a beko washing machinethe start button keeps flashing during a cycle and it wont go on to the next cycle
Make sure that the inlet flow is good, remove the inlet valve to check. Also check the door switch and then the connections of the program controller unit. If there is loose connections it can cause errors and halt the program. Also it can be related to the program controller unit if after resetting the above there is no change .
Sep 30, 2011 | Beko 24 in. D3421F Free-standing...
Apr 11, 2009 | Beko Dishwashers
My BEKO D3421F dishwasher wont start?
hi there......sounds like the door switch on your apliance has given the door close it firmly lidstening for an audible click as the door switch makes...
regards SirGalahad
Mar 15, 2009 | Beko 24 in. D3421F Free-standing...
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Beko 24 in. D3731F Free-standing Dishwasher Logo
Top Beko Dishwashers Experts
Shekar Avadhani
Eric Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
