Amp goes 20 when turned on to lisen a cd or what ever
I use the remote to turn on the amp so i can lisen to a cd but
the volume goes to 20 how can i solve this problem
amp LINKMAN LM-5040
your sincerly
geoff anderson
2 Suggested Answers
  • 1175 Answers
SOURCE: I have a SONY amplifier, TA-F410R. When I turn it
My 1st thought would be the main power supply capacitors.
If they are dried out or "leaky" they WILL take a long time b4 the power supply gets up to where it will run the amp
Get the main capacitors replaced
Posted on Nov 03, 2010
Testimonial: "Wow, what a fast answer. I will get new capacitors and replace them. I hope this is the right solution for my problem, but I have faith."
Volume goes up but can't lower the volume.
The contact-pads of the remote's PCB / Printed-Circuit-Board may be oxidized.
Remove bottom cover & spray with fast-dry Servisol contact cleaner.
Feb 04, 2018 | Televison & Video
The radio works and plays fine but if i put a dvd or cd in no volume the dvd does play though just no volume
Are you running the audio through an amplifier? If so, it sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). The power antenna remote turn on turns off when leaving tuner mode, turning the amp off.
Nov 07, 2012 | XO Vision X341BT 7-Inch In-Dash Touch...
When I put the CD in the player the CD comes up and the time playing but the volume doesn't play. Is there a trick to it?
Is the radio working fine? Are you using an amplifier? If so, you may be using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn you amp on. The antenna remote turns off when leaving tuner mode, turning the amp off.
Jul 04, 2011 | Sony XPLOD CDX-GT200 CD Player
Need to use remote to change volume
this aiwa equipment failure is common, is that the contacts within the volume botton causing misreading get dirty when going up or down the volume. you have two options the first is to buy the button or pull it out and clean it is not difficult. bye
Jun 14, 2009 | Aiwa NSX-A999 Shelf System
Arrange the volume of your jukebox without using the remote
In earlier models you plugged either the remote box OR the volume control box into the same socket on the amp. If you still have the volume control box simply plug it in where the remote is plugged in.
Dave F.
Feb 22, 2009 | Wurlitzer Jukebox 1015 One More Time...
Works, but goes into protect when you turn up/down volume
If its new call Sony and get service????????????
Aug 28, 2008 | Sony STR-DE445 Receiver
Speakers cut off when bass goes up...
sounds like you hava a load problem.if your'e running your woofers at 1ohm,make shure your amp is 1ohm stable.....
Jul 03, 2008 | Car Audio & Video
Slow decline in volume
I'm a bit of a bose LS 30 expert myself, very closely involved with bose lifestayle reanges professionally for many years.
thers a problem on the amp module on the back of the bassbox or a problem with the CD 20 volume output being reduced over time or lastly and quite simply the remote is fualty.
in each case the problem is easy to track down.
1st. take batteries out of remote ( and any other bose remotes that may control the cd 20, ) if the problem goes, get a new remote, impossible to fix unless its obvious mechanical damege to remote.
2nd get a loaner from somebody else or the shop of either cd 20 or bassbox, ( it doesnt really matter for the purpose of the test which nor which bassbox you try, it dosent have to be perfectly acoustically matched to see if the sound is dropping., once the cables match up. ) this will eliminate the possible probelm in either remaing unit.
as far as repair is concerned. you could have a go if you wanted to mess around witha lot of baord level electronics, but once youve identified the cause of the problem i suggest get a bose authorised repair or buy a spare one second hand. ( you'll only need the faulty part complet and in tact)
whatever you do.......... don't open the bassbox, as its a few years old the chances are you'll not be able to seal it back up properly in a way that will rerproduce the same quality of sound. and even if the bassbox is not at fault you'll probably have to suffer an ugly looking repair or a new bassbox that isnt necessary.
if on the other hand if you are determined to open the bassbox, let me know and i will help you do it properly but the chances are there is nothing there causing the volume to fall, that can be repaired without building a complete replacement and lots of visits to radioshack or your local electronics shop, and i would be extremely amazed if the problem is in the bassbox.
i would bet you have a faulty remote or at worst a control voltage problem in the CD20 unit.
Mar 02, 2008 | Bose Lifestyle 30 System
it might be that your wires from your amp to your subs are too thin. since they were relatively new the first three months, they were probably undamaged, but after pushing them too much, they probably have broken wires, and can't get enough power to the subs when turned up, i suggest getting thicker wires before investing in a capacitor, it could save you money.
Mar 21, 2007 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
97 people viewed this question
