Question about Arrow 8000 Power Shot Pro Staple & Nail Gun
Stapler repair where abouts near newcastle can you get an arrow electric stapler repaired looks like firing switch inoperative
  • palm040 Nov 15, 2008
    where to need name or location
    Scholar:
  • 132 Answers
Sydney 02 8004 2111 you might have to post to sydney for service
Posted on Nov 15, 2008
Will Arrow #506 staples work in an Arrow JT27 manual stapler?
Hello, there. No, 506 staples will not work in the JT27 stapler. This staple gun takes JT21 staples in 1/4-inch, 5/16-inch and 3/8-inch. Did you have any more questions about your JT27?
Oct 02, 2015 | Office Equipment & Supplies
What staples does a black and decker electric stapler 9700 take and where can I buy them?
Hi Stephen,
Of course the manual states to use their staples for best results.
However it does at least state it is designed for a wide variety.
Most hardware stores have a range of staples to choose from.
Home Depot, Harbor Freight, Lowes etc. Try a chisel point this may help penetrate the wood deep enough. All staples are not made the same. So again trial and error may be the quickest route. Fortunately you can purchase small boxes for your testing.
The manual for this stapler is here:
(Page 2 talks about the staples to use.)
Black Decker 9701 Instruction Manual Page 2
Good luck and hope this helps!
Jan 04, 2015 | Arrow Tools & Hardware - Others
How to put the spring back in the handle of Arrow T50 Stapler?
Ref. recocking the spring handle in your Arrow T 50 Stapler
1. secure the stapler in a vise. You need three hands to recock the handle spring.
2. Using a notched tack lifter hand tool, with one hand holding the handle so as to expose the spring, place the notched tool against the spring arm and force it to the rear. it will now be under tension.
3. Wiggle the handle into position so that you can quickly insert the clevis pin. Once secured, let go your handle that is now under tension. Replace clevis ring.
4. Dry fire to test.
Sep 18, 2014 | Arrow Staple T50 3/8"" Monel stainless...
How do I load JT21 staples into a Arrow JT27 Stapler gun?
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Nov 07, 2010 | Arrow T50P ARROW STAPLE GUN
MY SEARS 9.6 VOLT NARROW CROWN STAPLER WILL FIRE ONE TIME OR TWO, THEN QUIT. IF I PULL THE BATTERY BACK FROM ITS LOCKED POSITION ABOUT 1/4" IT WILL FIRE EVERY TIME. GOT ANY IDEAS? I LIKE THIS STAPLER...
The terminals on the battery or on the stapler must be damaged (bent or corroded). It's probably the stapler if the battery charges fine. Does it do the same thing with another battery, or just one? Assuming it's the stapler, and you don't want to mess around with the terminals you could tape a spacer on the stapler to keep the battery 1/4 inch out. You would probably have to tape the battery in place though. If the problem is corroded terminals, I have found that a little wire brush attachment in a Dremel works great. Not a brush like a disc, but a brush that looks like the kind used for paint stenciling.
May 21, 2010 | Arrow & Professional Cordless Staple Gun
Instruction book for Arrow ETF50P staple gun . lost the instructions and can't figure out how to insert the staples in the gun
Look at the rear of the stapler. Push in then down on the stapler tensioner to release it from the rear of the gun. Slide the tensioner out. Next slide the new staples over the rail and into the gun with points down. Slide the spring tensioner back in and connect it to the stapler by maneuvering its clip down and then up.
Apr 19, 2010 | Arrow No.ETF50PBN Extra Heavy Duty...
My craftsman easy fire stapler diagram
Mine stopped working last night. I took it apart and was able to reassemble it properly.
When both sides are rejoined the tip of the spring has to be inserted in the hole on the corresponding side (note red arrows on both pics)
This is a great stapler when it's working.
Nov 22, 2009 | Tools & Hardware - Others
Double or triple firing
Great, Sami! Could you please rate my assistance. Thank you.
Charlie
Aug 19, 2009 | Electric Stanley Tre500 Staple Gun /...
Firing Blanks
No it is not operator error. This is the worst stapler made. I had one, it did the same thing, I brought it back and bought an arrow stapler, works great.
Jun 23, 2009 | Black & Decker 5700 Powershot Forward...
Brad nails not in all the way
There are no adjustments on any electric stapler / brad nailer that I've heard of , only the pnumatics. The electric staplers/brad nailers only work well in softer woods
May 26, 2009 | Arrow ET200 Electric Brad Nail Gun
Arrow 8000 Power Shot Pro Staple & Nail Gun Logo
509 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
