Question about Intel Motherboard
Get TV channels
How can i get TV channels through my PC
    Brigadier General:
  • 6,966 Answers
The usual procedure would be with the installation of a TV Tuner card either by:
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 15, 2008
On my 7" wide screen model TL7001-TP-ASC with ATSC Tuner. When I change the channel it wont tell me what channel the tv is on and the tv guide wont show. The tv does not show no numbers or letters
LG LED TV won't show program information or channel name ...
www.tomsguide.com/.../54774-4-show-program-information-channel-na...
Oct 18, 2011 - 17 posts - ‎7 authors
I will get the picture/sound (up to 1080i) but i can't get the TV to display the information (What I'm watching and the channel's name). It used to ...
ChanSort download ' SourceForge.net
sourceforge.net > Browse > Multimedia
Rating: 4.5 - ‎23 votes - ‎Free - ‎Windows
Jun 5, 2015 - ChanSort Channel List Editor for Samsung, LG, Toshiba and Panasonic ... ChanSort allows you to organize your TV's channel lists on your PC.
Jan 13, 2016 | Televison & Video
JVC TV LT-42X579 LCD TV 42 in.Does this TV have a Lithium battery for maintaining memory, similar to PC computers?
No. It has no such battery inside. Its memory IC is non-volatile type, and need no back-up electric charge to retain the data, even after it is switched OFF. http://electronicshelponline.blogspot.com/
Sep 18, 2014 | JVC LT-42X579 42 in. LCD TV
I have a Toshiba TV/VCR/DVD combo, remote WC-FN2. I can turn the TV on,change volume but can not change channels. Help! Thanks,
Some tv remotes will do this if the TV is programmed to skip all but one channel (or the last scan for channels had only one active channel - like a tv connected to a set top box (3,4,60)).
See if you can navigate to other channels by typing in a channel number. Also check if the Tuner is the current source of the video signal by pressing the Source or Input button. If you have a menu button on the TV or the remote, try rescanning channels or editing the channel list.
I hope this helps.
Sep 23, 2010 | Computers & Internet
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
Need help in getting my pc connected to my TV.
You need a AV card to get output on TV. One of the company is Aver Media. contact any hardware vendor and ask Aver Media. On the card there is one output channel. You will get communication channel along with the card.
Aug 08, 2009 | KWorld PC to TV (0872880887527) Video...
No channels found with automatic channel search
You may need a new antenna.  Go to www.antenna.com for info and help.
May 30, 2009 | RCA Analog (RCA) to Digital (VGA)...
I have some channels lock in which i can't pick up. How do i unlock them?
Channels Lock? is this for the TV? this is under the Computer section so I am going to asume you are trying to watch TV from your PC and some channels are locked and you cannot watch them? if you are normally suppose to get them and you are using a tv tuner from cable (for example) you should be able to modify this in the tv tuner settings.
Apr 13, 2009 | Computers & Internet
I just brought i tv tuner card that plugs in by bluetooth to my pc. I plugged my tv cord from the wall into it, then installed it by the disk that comes with it. Then it says to scan frequency for tv...
hi did you setup the device with your correct freq, if yes you should be able to set the channel manual if you know the right info search online if dont know them take off your own equipment
Nov 23, 2008 | Computers & Internet
Channels won't come in on my media center
Try making changes on the Region settings NTSC/PAL and Resolution.
Sep 20, 2007 | HP Media Center PC 873n (P9875A#ABA) PC...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
