Question about HP Compaq Presario R4000 Notebook
Computer will not turn on
The power cord is torn a little not much.....i think i heard from a friend it could be the motherboard? its like it will not charge!! the model is compaq presario r4000!! HELP ME....how much would it cost for a mother board? can they be installed eaisly by me?
  • HP Master
  • 32,281 Answers
You need to check the power cord, borrow, beg or steal one to test. If the laptop does not charge with a different power cord then the problem is elsewhere eg. a faulty power pack or even a faulty connector that plugs into the laptop (borrow a multi-meter to check the voltage of your power pack), also borrow a power pack to test your laptop, before you buy or send it away for a quote/repair.
If you determine that the laptop is faulty, then the cost of replacing a motherboard would not be worth it, even if you found one, it would most likely be a second hand one and how would you know it works, also if you are not technically minded you will it difficult to swap motherboards and it may not work when you put it together.
I suggest you put your money towards a new laptop, it will be faster and better.
Posted on Nov 15, 2008
My ear piece is not working, when I put it on charge the light does not show it is charging what can I do ?
When there is no light, while connected to the charger, it is NOT charging. You should checK the charger and the power cord. Eventually check the connector in the headset.
Perhaps you even can borrow for a few moments a charger from a friend? if another charges connected the light goes on, you need another charger. If nothing changes I think the little battery inside is defect. Don't bother buying and replacing the battery, when it almost costs the same as a new headset.
Jul 28, 2014 | Jabra Neonode N2 / N 2 MOBILE/CELL PHONE...
How do i find a manual or the secret menu?
I don't think a monitor setting is causing Windows to not appear.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 24, 2014 | Likom Computers & Internet
No power to computer moniter
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Jan 18, 2014 | ViewSonic Computers & Internet
Monitor will not turn on after extended periods
Aug 16, 2013 | ViewSonic Computers & Internet
Is not charging battery
If the laptop works with the AC Adapter Power Cord ok without any problems except the battery is not charging, then the battery is dead. Batteries only have a useful life, then they have to be replaced.
If the laptop does not work with the AC Adapter Power Cord then either the Power Cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of these is bad, a good battery will not charge.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | HEWLETT-PACKARD Hewlett Packard 413671-001...
I always get plugged in not charging when i charge my laptop even when it is not fully charged
If the laptop works fine off the power cord without any problems then your power cord is ok, but if the battery is not charging then the battery is probably dead and needs to be replaced. Batteries only have a useful life, and when it's over they have to be replaced.
If the laptop does not work with the power cord then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop. If either of them is bad the battery will not charge.
Check your DC Power Jack which is where the power cord plugs into the computer. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Computers & Internet
My Eee 4g surf netbook won't charge at all. Upon turning it on, it runs for a second, then shuts off due to a lack of battery power. The charge cable's light is also not turning, so that may
I think your DC Power Jack is bad. The DC Power Jack is where the power cord plugs into the laptop. If it is bad, then a good power cord cannot charge the battery, nor can the laptop turn on once the battery is drained.
You say it smelled burnt, that might mean it took a power surge. I always tell people that before your plug the power cord into the electrical outlet on the wall to remove the other end of the cord from the laptop. That way if you get a power surge you will only damage the power cord and not the dc power jack or motherboard.
Anyway, take an ink pen and push it into the dc power jack and see if there is some movement. The little pin or the casing of the jack should not wiggle.
The DC Jack is soldered onto the motherboard. To replace it you will have to take the laptop apart, desolder the old dc jack and solder a new jack onto the board. Sometimes the DC Jack sits in a slot rather than being soldered. The palmrest and bottom case helps to keep it in place. This type of DC Jack usually has a cable harness that plugs into the motherboard.
Apr 02, 2012 | ASUS Eee 4G Notebook
Hello, I have a problem with my eee 100H5 netbook. I was using it connected to the power outlet, when it randomly shut off. It cannot be restarted and is unresponsive to the power cord, meaning that the...
Unplug the computer and take out the battery.
Hold the power button for ten seconds.
Leave the battery out and plug in the power cord.
Press the power button.
If the computer turns on, put the battery and everything should now work.
This has solved every "laptop not turning on problem" for me and my friends.
sublimedjg
Jun 23, 2011 | ASUS Eee PC 1000HE Netbook
I have a new replacement battery, yet when plugged into AC power is not charging...HELP!!!!
Are you waiting at least 5 minutes before you think you have a problem. A new battery will have resistance to its first charge then it will start charging, that is of course providing there is nothing wrong with the charge part of the motherboard.
Jun 20, 2011 | Dell Vostro 1500 Notebook
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
Computers & Internet Logo
108 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
