Question about Clarion OHMD74 Car DVD Player
There is no sound in my equipment
There is image, but no sound (in the phone and in the FM radio) when I put DVD or CD. Is there a kind of "mute" in the equipment, or is it damaged? Thanks
  • Anonymous Jun 22, 2008
    When
Some dvd player only work with infrared headphones try those
Posted on Oct 23, 2008
The DVD was damaged. It had to be fixed by Clarion.
Posted on Feb 27, 2007
I have the same problem -- just bought a used minivan and can't get any audio with the DVD player. Were you able to find a solution? Any help would be appreciated! Thanks
Posted on Feb 23, 2007
How can I get sound from my radio
If a cable speaker is shorted to ground or (in your case) the short was on the casing the radio mutes the output to save the amp. So
remove all cables and put them back to the radio & connect the speakers one by one to see if it works or mutes again
Sep 30, 2016 | Jensen Jta-475 Cd Player /turntable...
I have an LG fb163 everything seems to function but no sound in the speakers
check mute button, source knob/button, speaker selection knob/button while its playing a cd or FM radio. Also if you have connected headphones the speakers would mute. Check the speaker connections. If the speakers are powered you need to connect them to a power source. If all these fail to produce sound consult a technician.
Oct 30, 2014 | LG FB163 DVD/DivX USB Micro system Shelf...
Dvd not playing over the radio
If you have a DVD player AND an FM Modulator then this is not a OEM part, meaning it's not in your service manual. An Original Equipment Manufacturer part wouldn't require an FM modulator. This is an aftermarket part, hardwired into your vehicle and the fuse should be located under your dash near the main power harness coming from the ignition.
Feb 09, 2013 | Car Audio & Video
When i put the fm radio it display auto muting and doesnt have sound, this only happens with the radio because the dvd sounds ok
"Auto Muting" in the context of FM means the output will be muted if the signal is so weak it would result in mostly noise anyway. Interstation radio noise can be annoying and dangerous at high volumes.
Aug 14, 2011 | JVC TH-M303 System
Trying to hook up speakers to Pyle Pro PD1000 stereo receiver w/built-in DVD/CD player. I believe that I have speaker wires hooked up correctly but when I play CD no sound. I can actually hearing sounds...
I went thru user manual..there is no special way of wiring speakers..
pls check carefully the speaker connections again and the "speaker selector" too..
what about "MUTE" button ? it should be "OFF" ...
and try to test it on FM radio first ..
just in case ,if you need the soft USER MANUAL pls visit the URL below..
1000 Watt AM-FM Receiver w/ Built-in DVD/MP3/USB
http://www.pyleaudio.com/sku/PD1000A/1000-Watt-AM-FM-Receiver-w-Built-in-DVDMP3USB
Jul 10, 2011 | Audio Players & Recorders
Hi my name is james im having trouble with my audio coming out the speakers what should i do
1. Do you have power to the unit. I assume yes.
2. Ensure the fader and balance is set to neutral to ensure you have output going to all the speakers.
3. Ensure the speakers are connected.
4. Ensure the speakers are not out of phase, if they are they will cancel each other out, and sound muted
5. Always test new model head units with a cd. not fm radio. Using fm radio on some head units will mute the sound if the station is not coming in clear enough.
6. Set your volume up a little, like on 15 or 20 (using the digital 40 level radios) (halfway in plain language)
7. Ensure the mute isnt on
8. If running through and amplifer, ensure the power, ground, remote, gain and phase are all correct.
9. Ensure rca input is going into the correct place on the amp
10. Ensure speaker output is actually connected to speakers.
hope this helps
Aug 08, 2010 | Pioneer AVIC-D3 Car DVD Player
No Sound for AM/FM Radio
Ensure that the antenna is still attached. It will auto-mute if no signal is attainable.
Sep 12, 2007 | Onkyo DR-C500 Multi-disc DVD Player
Surround sound
It must be about the sound quality need of your amplifier. The sound processor simply needs to get clear signals from sources such as fm/am receiver, dvd/cd players etc. in order to manage'em to give you the optimum surround sound. If the fm receiver has an "FM MUTE" option, I recommend that you turn it on. By doing so, you'll receive only good quality fm stations, furthermore your amplifier will let you get surround sound. The second issue you mentioned has its own answer inside. Use a "new" cd player, you can get optical cables, digital coax cables to improve the performance if you like..
Jun 07, 2007 | Onkyo HT-SR800 System
Jensen vm9311 AM/FM/CD/DVD
you are mising to power on the factory amp.
Apr 25, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Clarion OHMD74 Car DVD Player Logo
386 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
