Sony TV This is not a question. I just wanted to thank you again for all your help on fixing our Sony TV. I installed the B board you recommended and the picture was perfect! You truly are a Guru! Thanks Mistersony!
  • 320 Answers
DeaconJ,
Thanks for the feedback. I always like to hear back from a "satisfied customer". Could I persuade you to rate the original question here:
http://www.fixya.com/support/t1221964-sony_klv_s32a10
I would appreciate a good rating. Thanks!
Posted on Nov 15, 2008
My sony bravo 52 inch model # KDL52W5100. HAS A DARK SHADOW IN MIDDLE AND BLURRY RIGHT SIDE. BUT THEN IT FIXES ITSELF AND 2 TO 3 DAYS DOES IT AGAIN
The part failing is called T con board , http://www.tvpartsinstock.com/sony-kdl-52vl150-kdl-52w5100-kdl-52w5150-t-con-board-lj94-02676j-15589084
, if your handy you can swap it out yourself . or pay a shop more then the TV is probably worth ( not recommended )
cost 65.00-70.00 they are a lot of screws and shielding to remove to get to the main PC board . Hope that helped a little
Feb 24, 2016 | Sony Televison & Video
Tv want come on and standby light blinking 9 times
I do not agree with given info by previous expert that has no idea how tv works.
9 times red light blinking shows problem with sound output chip in tv, please check following things to fix the issue or pass it to local tv repairman if you have no electronics stuff fix experience.
/- 19V line is shorted on A and B boards
IC708 is defective on A board
PS701 or PS702 (both are fuses) is blown on A board
Hope these info will help you.
Thanks.
Sep 10, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My sony bravia kdl32-130 has indicator led on but no pict or sound
Hi jeremyfid
I'm sorry for uninformative answers for your Sony Bravia tv, I'm Sony tech and can assist you to solve it.
Let me know exact model number of tv written at back and what you have been tried so far to fix the problem info.
Does tv show on-screen display in any input?
This will help me to diagnose problem.
Solution-1 and Solution-2 are totally unrelated and both guys have no idea about tv repair. I would recommend FY Admins to take off their TV Badge, they do not deserve TV Badge.
Aug 23, 2010 | Televison & Video
Sony 51 inch rear projection tv has convergence problem d board
what is it that you want FIXYA to do in this situation?
We do not recommend board swapping or DIY
Call a technician to get oit fixed these problems are not DIY as they require circuit diagram skill special tools to check voltage and ohmage and an understanding of High voltage safety.. Board swapping newver fixes it, only on a tempory basis at best and at greater expense in the long run. That is why we suggest not to DIY
Please rate our help++++Thanks for using FIXYA
Jun 25, 2010 | Sony KP-51WS510 51" Rear Projection...
No picture coming on
Six blink shutdown is a common problem with this televion one of two switch mode ps ic have failed. The repair may cost somwhere around 150.00 to 200.00 to fix from a technician. If you want the specifics, i can provide them.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The convergence is way off and will not adjust. Pulled and sent Sony the D board...new D board installed but did not fix the problem. Flash focus nor manual convergence will adjust. Have 3 images for...
Hi, thank you for visit fix ya.
Do you replace STKs ICs?.
If so, you need go to service menu tv.
With you tv off, press on your remote control:
display + 5 + vol+ + power.
You will go to service menu tv.
NOTE: Be Careful before you do this, because if you don't know step by step convergence adjustments.....YOU WILL MESSED UP YOU TV.
I recommended if you don't have electronics skill, take the tv near to tv shop.
Any question I will be here .
( I need model number tv, please)
Thank you
Jul 26, 2009 | Televison & Video
Sony KP46WT500
TV has problem of convergence out IC STK392-560 mounted on D board quantity 02 and need to be replaced both ICs.
Required ICs are available in Part Store for $38
Jun 11, 2009 | Sony KP-46WT520 46" Rear Projection...
The tv goes on stand by mode by itself. My 57' sony does not turn on but remains in stand by mode. Blinks 9x then stops, then starts all over again. What needs to be done?
9 blink in your Sony KP-57WS500 shows error / problem in Audio section.
1= +19 volts &-19 volts are shorted by any reason on A and B board.
2= IC708 is faulty on A board
3= PS701 & PS702 (fuse) are open on A board.
Above are possible reasons of 9 blinks.
If you have electronics knowledge and have tv repair skills then check as per above info. otherwise I recommend get help of TV tech person or contact nearest Sony service center.
Thank you.
Oct 05, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture very blurry with lines going accross screen
hi gud day! your problem has a solution. Just try to fix your tv from blurry picture. Pull the socket at hte back of the picture tube. remove the socket from pcb(printed circuit board) de solder the pins. then after that, if you see a 2 metal formed like a small mountain facing each other, try to clean those remove the rust (green color) using sander or any material you can use, just avoid using oil on that bcause it is sparking. then try to install it again and try to turn on your tv. if still not working replace that socket with a new one. you can buy it at any electronic supply store. and re install then on it again.. surely it will fix your tv without expensive components.
be sure unplugging the tv from ac souce before disassimbling...
thanks,
janex
Mar 31, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KV-32FS120
This is correct the TV does not have a G board and the statement that resoldering the parts is misleading. I fixed my daughters by resoldering the following: D647 Q605 C690 D645 D620 R691 Q691 I tested all the parts in the circuit they tested good. I am an Electrical/Electronic Engineer this fix will do you well. Locate the Q605 located on the main boar and all the above parts listed. Or just carefully heat each of the pads in the area and add a small amount of solder. Make sure they are shinny dull is a problem joint. Don't put too much heat on the pad it will lift. Use a 15 to 30 watt grounded soldering iron. (has a ground on the ac plug) Fix it and enjoy saving yourself a large fee. PS do not mess with the small surface mount parts, you will be asking for more problems. If this don't work relist and I will give you voltages to check....
Jul 29, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
Top Televison & Video Experts
