Question about Bernina Sewing Machines
Converting a bernina 1260 to a Bernina 1260 QPE. Is this possible
I have the regular bernina 1260 and have always wished a little that I had gotten the 1260 QPE. Do you know whether or not if I used the 2nd card designed for the 1260 QPE with my regurlar 1260 if it would convert my 1260 to QPE? In other works is this the only difference between these 2 models. If so, do you know where I find just the QPEs 2nd card. Thanks for your responses. Cheers.
- jlesa
  • 185 Answers
SOURCE: bernina deco 600
Sorry to inform you but your machine only sews 4" x 4" . The arm on the machine can only move 4 inches up and down and 4 inches left and right.
The size of the hoop does not affect this. If you have a multi position hoop you can sew multi 4 x 4 areas without re hooping.
Posted on Feb 28, 2008
  • 19 Answers
SOURCE: how do i oil my bernina 801?
Please do not oil anything with WD40, it is an alcohol based cleaner hense why it's flammable. No where on the container will it say anything about lubricating, it will merely dry out your machine. We use it, but only to clean metal parts... we then clean it off and let it evaporate for a day before applying oil.
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops. Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Posted on Jan 08, 2009
SOURCE: Bernina 180E or Janome MC10000?
I have the Janome 10001 and I love it. I have thousands of designs and they are easily accessible on-line and I can download the designs onto my flash card quickly and the cards were relatively easy to find.
I have just purchased a 180E Bernina. I have heard it is a much better machine and Bernina does have a wonderful reputation and is supposed to be the best there is. I have found that the dealers near London Ontario are not customer service oriented. I attended a store and am still waiting for someone to phone me back with information. I did email Bernina on-line and they have been exceptionally helpful and willing to offer suggestions, and information and solutions. The dealer just north of London was not even interested in helping me at all and basically blew me off. I think once you find a reliable dealer you are ok. If you get either of these machines, email me and I can help you with whatever you need to get up and running. (sews@teksavvy.com)
I am currently moving so have not got the Bernina set up right now. ONce I get it going and use it for a while I can give you a better idea of which one is better. I might just keep both but not sure.
Posted on May 21, 2009
mohammed387
  • 1952 Answers
SOURCE: Bernina 1090 only sewing backwards
1.Turn the bobbin winder off.
2.You have to reverse the wires on the carbon brushes.
3.Make sure that you have the needle in correctly- with the flat side to the back. Those machines rarely go out of time.
Posted on Jul 22, 2009
  • 5 Answers
SOURCE: using a bernina gold latch bobbin case on the Bernina 435 machine
There isn't a Bernina 435. If you are referring to the 430 than the gold latch bobbin case will not work in that machine. If you are talking about the Bernina 450 the gold latch will work in that machine, with or without the embroidery module.
Posted on Aug 15, 2009
Is it possible for the consumer to download firmware for bernina 730
Hello, Charlotte -
The Bernina 730 sewing machine was manufactured between 1963 and 1982, before Bernina came out with their first computerized sewing machine, the 1130 model.
Are you asking about the Bernina Artista 730 sewing machine, instead? If so, the answer is MAYBE.
I did find a brochure for the Bernina Artisa 730E model, which has a Microsoft Windows operating system built in and the myartista portal (online.) This is the link to the brochure (PDF document):
https://www.manualslib.com/manual/15724/Bernina-Artista-730e.html?page=2#manual
You may find this information on Bernina software products and which versions of Microsoft Windows software they are compatible with instructive:
https://www.bernina.com/en-US/Support-US/Software/Software-Compatibility/Bernina-Software-Compatibility
Best wishes.
Feb 03, 2018 | Bernina Sewing Machines
Bernina 1230 manual- How do you raise the feed dogs?
Perhaps the manual for the 1260 will help (pg 5, item 18):
BERNINA Sewing Systems
Sep 05, 2017 | Bernina Sewing Machines
How do you thread the bernina 1230
You can probably use the manual for the 1260. Sewing machines basically thread alike from one model to the next.
One thing to remember: ALWAYS RAISE the presser foot when threading the top thread! This will help prevent those dreaded thread nests under the fabric.
BERNINA Sewing Systems (in the Out of Print section)
Jul 25, 2017 | Bernina Sewing Machines
Is the Bernina 1230 a low shank or high shank machine?
BEWARE! Bernina machines take a special Bernina-only foot, and even the older Bernina mechanical feet will not fit the newer Berninas, and vice versa.
For the most part, your 1260 uses the old style presser foot--BUT be sure to check as there are some old style that will NOT work on your machine. (Be sure to CONFIRM whether it will work on your machine as I believe the 1260 has some specifics that will not take all old style.) Red marked presser feet are only new style (ie computerized machines). The difference is in how the presser foot is designed at the top where it attaches to the machine. Your Bernina dealer generally carries both the old and new style. BEFORE you buy, be sure to ask whether you are getting the right foot for the 1260!
Look at the top of these presser feet so you can recognize what you need. You are probably safe buying the presser feet that have the 2 pegs at the top (if it has solid peg across the top, it may not work):
http://www.sewingpartsonline.com/bernina-1260-sewing-machine-parts.aspx#filter:ptype_gmcfeed_1:$2520Presser$2520Feet
Bernina Presser Feet (presser foot guide)
You can use snap-on feet BUT you still need a Bernina Adapter in order to do so.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjY-NSbrLvUAhUr1oMKHVIDAsYQFghUMAA&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FProducts-US%2FBERNINA-products%2FAccessories%2FPresser-feet&usg=AFQjCNFMl-Fd3gweu5nM7Y9UqKmdz-fR7Q
Jun 13, 2017 | Bernina Sewing Machines
Can I add a BSR to a Bernina 1260?
Not really. The Bernina BSR units need to be attached electronically to the machine to activate the "electronic eye." Your 1260 is an earlier mechanical-electronic machine that does not have that electronic-attachment capability, ie there is no where to plug a BSR unit into your machine. However, with practice (both with pencil on paper and then transferring that muscle memory to the machine), you should be able to learn to free motion quilt on your 1260. It just takes practice and patience.
BERNINA Stitch Regulator BSR
https://www.qnntv.com/courses/improve-freehand-quilting-designs-using-muscle-memory
Apr 01, 2017 | Bernina Sewing Machines
How do I make a new buttonhole on my 1260? B
Hi Karen,
Sew two parallel lines of overlock stitches very close together. Then see overlock stitches accros the ends of the first lot of stitches to close them off. Finally, carefully cut the fabric between the first set of stitches. Try this out several times on some scrap fabric. You'll need to get the spacings sorted out.
Jul 19, 2015 | Sewing Machines
Sewing Machines Logo
166 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
