Question about Dell E173FP 17" LCD Monitor
Power cord touched another cord and fried monitor
Hi, my boyfried says he was unplugging the cords from the computer and monitor to move it and the chrome part of the monitors cord accidentally touched the chrome part of another wires tip and he heard a zapping sound and now the monitor wont turn on. it sounds crazy that this small mistake could have fried the monitor. is this possible?
When I rebooted my computer, the monitor stayed blank. Do they just die?
Power off and unplug and make sure the cord from monitor to cpu is firmly connected or unplug and then replug the monitor cord. Also make sure the monitor power light is on.
Dec 31, 2009 | Samsung Syncmaster 940BW LCD Monitor
Shows chinese symbols and acts as if there is no signal.
Unplug the power cord and unplug the cable to the computer. wait 10 sec. plug in the computer cord then plug in the power cord
Oct 17, 2009 | Soyo DYLM2286 Monitor
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Fpd2275w monitor problem
Have you unplugged the power cord for 2 min. Try that, there are problems with these "locking" and unplugging sort of "reboots" them.
Jun 01, 2009 | Gateway FPD2275W LCD Monitor
No power
Check your power cord very carefully....especially the plug ins (square box)....could be the power supply itself. Regarding fuses; You can't see it inside the computer it is an electronic component. Got to go to store
Feb 27, 2009 | KDS 17S 17" Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Pilot
tell it to go in normal mode just say sthat when u boot up cuse u shut down inproperley ok might wann buy new video card make sure it pluged in to a hi end power strip ok
Jan 23, 2008 | Computers & Internet
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
37 people viewed this question
Alun Cox
