Question about Panasonic KX-TG1033S Cordless Phone
On incoming landline call the phone only rings once
I have a Panasonic DECT 6.0 system, but when I receive an incoming call it only rings once before the call gets dropped. There are no other connection (fax, etc) attached to the line
SOURCE: Uniden DECT 6.0 2080-2 rings for no reason
These DECT 6.0 phones work on 1.9 Ghz frequency and should not have any interference other than from another DECT 6.0 phone that can be within 150 ft of your phone. That means that somebody, a neighbor that has a DECT 6.0 phone close by is causing this problem. It also means that they are also getting these phantom phone rings. The best solution? Go to a 5.8 Ghz phone and your problem should go away.
Posted on Apr 24, 2008
SOURCE: model 28112ee2-4 dect 6.0
SOLUTION: My handsets stopped ringing after power was stopped to the main base, too. I put one on the main base and that one started working but the others still didn't work. So I put the other phones on the main base while I called from my cell and let it ring. The other phones started to ring and work again.
Posted on Oct 18, 2008
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
SOURCE: landline phone does not ring out when there is an incoming call
incoming calls ringer on corded land line phone no longer works
Posted on Mar 11, 2010
SOURCE: My landline phone won't ring, but I can get and make calls!!
My experience with an old (100+) and newer house is that it is important to make sure your telephone wires coming into the house, and the junction block where all the wires connect, stay clean and dry. If the wires can get damp or dirty, then when that 90 volts of ringing voltage come down the line, it may find a low impedance path. At my old house I had to make sure the outside wires didn't touch the ground or get damp. In my newer house, I discovered the wiring block was near a dryer vent where it got a ton of fuzz on it, plus the moisture, so eventually our phones stopped ringing even though we could make calls and our DSL was not affected. When we exposed and cleaned up the wiring block so that the phone company tech could re-visit us to troubleshoot things, suddenly it started working again.
Posted on Mar 19, 2010
My panasonic landline dect 6.0 goes straight to answerphone instead of ringing. You advice would be appreciated. Thanks. Joy
when you pick up a handset can you hear a dialling tone? If you can that mean the line is ok - so the problem could be the phone settings or at worst phone fault - suggest you reset the phone as it might be programmed to go straight to ansaphone
Jan 10, 2018 | Panasonic Lands Phones
Panasonic DECT 6.0 cordless phones system has begun dropping calls after first ring also won't take messages
Firstly, disconnect all devices / base unit from your landline. Then, using a mobile phone, dial your landline number. Does the ringing tone in the earpiece continue or does it stop after one ring? If it stops then you have a line problem which you need to report to your service provider.
Apr 27, 2017 | Panasonic Lands Phones
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
Cant hear incoming calls on my corded audiosonic landline telephone
Is your sp-phone working? if not, then you need to replace
the speaker unit. if it is working, then check if :
1- ringer switch set to off.
2-System programming is set to no ring for your extension.
Nov 04, 2013 | Panasonic KX-T7730 Corded Phone
How do i turn off the silent mode which will not let me hear the phone ring
I have a Panasonic DECT 6.0 which is probably similar. Try the menu that sets the landline ringer volume. On mine, this is MENU #160, then use the up/down keys to set the volume. There may be a MUTE option somewhere there.
Oct 18, 2012 | Uniden DECT 6.0 Cordless Phone ID
Not receiving incoming calls was talking to my
I used to have this exact model. More than likely, your battery has become "unrechargable". I used to buy replacement handset batteries from ebay every 6 or 7 months. After 3 years, I finally got rid of the phone and purchased a nice Panasonic (just cheaper these days!)
The replacement batteries usually sell for $3 or $4 on ebay. Here's a link of one that's one now: http://cgi.ebay.com/Battery-V-TECH-IP8300-DECT-6-0-89-1326-Cordless-Pho-/330486596555?pt=LH_DefaultDomain_0&hash=item4cf28943cb
Thank you and good luck!
Mar 21, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Landline phone does not ring out when there is an incoming call
Nov 02, 2009 | Lands Phones
Apr 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
Mar 13, 2008 | Panasonic KX-TGA101S Cordless Handset
Panasonic KX-TG1033S Cordless Phone Logo
467 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
