Question about LG LDF6810 Built-in Dishwasher
''IE'' error code on my LG dishwahser
What does "IE" error code on my LG Dishwasher mean? How can this be fixed, and can I fix it on my own. Thank you
    New Friend:
    Problem Solver:
  • 6 Answers
LIKELY NEEDS FLOAT ASSYEMBLY REPLACED
Posted on Feb 07, 2013
  • 38 Answers
According to the owner's manual it's a 'water input error'. You have to check for a kink or clog to the water hose running to your machine.
Posted on Nov 15, 2008
What does code Uo mean on the dishwaher
It is a Vent problem. The vent aids drying at the end of the cycle.
Frigidaire Diswasher ER UO Error code [FIXED] - Appliance Repair ...
forum.partsdr.com > Forum > Appliance Repair Help > Dishwasher Repair
May 25, 2012 - 20 posts - ‎3 authors
The ER UO error code means "Vent Open". On the top back right corner of the dishwasher tub, there is a vent and fan that opens to help dry the ...
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-ho... Feb 18, 2016 - The error code will display where the usual numbers are on the display screen. .... Do you have an error code on your Frigidaire dishwasher and need ..... Can you tell me what do you mean by "knockout plug has been removed"? ... Frigidaire dishwasher manual says UO error code is vent assembly error.
Diagnose UO Error Code - Dishwasher - YouTube
? 3:15
https://www.youtube.com/watch?v=pvJTiTd35vI
Dec 22, 2016 - Uploaded by Byrd Appliance Specialists
Byrd Appliance Specialists 3825 Gilbert Dr., Ste. 342 Shreveport, LA 71104 www.byrdas.com 318-459-8745 ...
My Samsung washing machine is showing a UE code during a spin ...
www.samsung.com/uk/support/skp/faq/1025292 Jul 5, 2016 - Your appliance will display a UE code when it has detected an unbalanced load and has stopped the ... If the door remains locked and the machine is displaying UE error, please run a drain program. ... What does this mean?
LG Help Library: Error Codes - Dishwasher ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library May 10, 2017 - An error code on the display of the dishwasher can usually be resolved by performing a few simple troubleshooting steps.
LG Help Library: UE Error Code - Top Load Washer ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library Sep 1, 2017 - After 3 attempts to balance, the uE will change to UE, meaning the unit was unable to rebalance the load and requires assistance. To determine ... What does code UE mean on the dishwasher Google Search
Oct 31, 2017 | Dishwashers
LDS5811BB LG dishwasher IE code. What does this mean?
WATER INLET ERROR Water has not reached to the pre-set level within 8 min. since inlet valve operated, or water has not reached to the normal level within 25 min. stop cock turned off, faulty inlet valve.
Sep 19, 2014 | LG Dishwashers
How to fix lg dishwasher that has code le
I think you may be getting IE code which relates to water inlet problems. Either the water pressure is low or the inlet valve may not be working properly.
Refer page 21 in the user manual which can be dowloaded from this site
Product Support
But if it is LE code then see this page for suggested fix.
LG Help Product Support and Troubleshooting LG USA
Jul 30, 2014 | LG LDF6810ST Stainless Steel Built-in...
I`ve got a lg dishwasher Model: LD2131 SH. The display gives me a code error IE . What does this mean.
Hello
This means the unit isn't detecting water coming in the unit. If there is definitely water getting to the dishwasher, then you will need to replace the flow meter which is the part that detects the water entering the dishwasher when the valve opens.
Aug 22, 2011 | LG Dishwashers
My LG direct drive dishwasher is giving me an IE or 13 error
Hi, according to the owner's manual on mine, "IE ERROR" means it's a 'water input error'. You have to check for a kink or clog to the water hose running to your machine. Once you unclog the water hose, you error code will disappear.
Jun 21, 2011 | LG Dishwashers
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
AE displayed on LG dishwasher
Please look one more time. The LG LDS 5811 dishwasher error codes are:
IE Error
OE Error
FE Error
E1 Error
HE Error
tE Error
It would also be helpful to know what happens when this error code displays. Please post back here, OK?
Thanks.
Apr 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
IE error code, machine keeps on draining
It sounds like the flood switch in the bottom of the washer is activated. check for water in the base as the machine if maybe leaking. This is a Dishwasher?
Feb 24, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Model No- LD-12AW2 LE Error showing what does this mean
LE error code means that there is a problem with the motor.  One thing to check is to remove the front door panel and check the wiring harness to see if there are any broken wires.  If there is, repair the wire connections and see if the dishwasher returns to normal.  If not, then the motor assembly will need to be replaced.
Apr 20, 2008 | LG 24 in. LD-12BW5 Free-standing...
LG LDF6810 Built-in Dishwasher Logo
1,443 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
