Question about Kenmore 22422 Top Load Washer
Started a new load of wash and water never shut off flooding room
A new load of wash was started. A few minutes later the laundry room was filled with water. The water did not shut off and the washer over filled. We have a top loading Kenmore 110 20802 (8.5 years old).
  • Anonymous Nov 24, 2008
    any solution would be great not in the market for a new washer
  • Anonymous Dec 04, 2008
    I had the same problem, the hose had come off the back. Thanks a bunch!
  • Kenmore Master
  • 2,651 Answers
You can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Posted on Nov 26, 2008
Water sensor not working. Started a load of Laundry and the water did not shut off therefore flooding my whole Laundry room. How can I fix this myself?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug or turn off circuit breaker ,if the water continues to fill, that valve is sticking,it is what to replaced
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps
Jul 31, 2011 | GE Spacemaker Washer and Dryer Electric...
How do you stop the cycle immediately after starting (found a sock that needs to be added in the washer) and then re-start wash cycle
You can only add items to the wash for a few minutes after that washer starts. If you found something you want to add you have to restart the cycle. This is a safety feature added to the front load. After the washer is full of water it doesnt allow the door to open so the water in the machine doesnt flood you laundry room.
Jul 15, 2011 | Asko W6021 Front Load Washer
Water was overflowing over the top and flooding the laundry room
If it was left in the reset position then it could absolutely pushed the diaphragm in the air switch to a point that the contactor couldn't reach it. Set it on a large load, let it fill and watch it. If it starts to overflow, pull the plug out, if it continues filling, you need a new water valve on the washing machine and if it stops then you need a new level switch
Jun 16, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Water not shutting off to begin wash cycle flooded room
Probably one of the water cut off solenoids not shutting off.
Do you use both hot AND cold water?
Try using only cold water first. If that works, maybe hot water solenoid is faulty.
Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
Jun 01, 2009 | Washing Machines
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Washer fills till flooded
change the fill valve located where the hoses hook up
Dec 29, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
181 people viewed this question
Sal De
 Brian Main
Brian Main
