Question about Panasonic Panafax UF-333 Plain Paper Inkjet Fax
Panafax UF-333 No Print Cartridge Error
I am having problems with a Panafax UF-333, after the old cartridge was changed I'm getting a (014 - No Print Cartridge) error - is there anything I can try??
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 171 Answers
Pls check in foll order: A.replace with another cartridge. B clean the contact points on the cartridge and the cartridge holder. c.check wheteher the carriage is stuck or too hard ,then oil the rod a bit. D.Please check whether the plastic portion of the carriage wher the cartridge rests may not have broken ? E.The carriage cable may have got cut . f.the carriage sensor might have gone,Please replace the carrriage cable with sensor.. Happy Faxing Omnipresent
Posted on Sep 26, 2007
Code 015 Problem
Press
Function
7
tel/dial slowly 4 times
1 for off
stop
stop
Aug 11, 2009 | Panasonic Panafax UF-333 Plain Paper...
ERROR CODES 016 AND 010
Unplug
move ink cartridge to center
remove ink cartridge
knock off the mountain off dried ink where the ink cartridge normally sits
plug back in
press function 7
tel/dial key slowly 4 times
set
91
set
1 (for off)
set
stop
look in the bottom of the paper tray and push backstop flush up to the paper
Jan 03, 2009 | Panasonic Panafax UF-333 Plain Paper...
We have a Panasonic Panafax UF-790
It could be a refilled Kyocera KM-F650 cartridge in a Panasonic UG-5510 box.
They look identical, but are configured differently.
You need to try another cartridge as it appears it is not a machine problem.
Dec 30, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
I am receiving an error msg on my Panansic, Panafax UF-333 machine. The msg is a code=316, error msg. What does that mean and how can I fix it?
Unplug the machine and move the ink cartridge to the all the way to the left.
Take a letter opener and knock off the column of dried ink that has built up where the cartridge was sitting.
If this does not fix it, the main board is defective.
Dec 03, 2008 | Panasonic Panafax UF-333 Plain Paper...
Panafax UF-333
Can't change mode TEL to FAX.
Apr 18, 2008 | Panasonic Panafax UF-333 Plain Paper...
Changing cartridge
The cartridge is probably not seating correctly in the machine. These cartridges are made with a plastic flashing on the drum shield that mates with a sensor actuator in the machine. Problem is, Panasonic made the same machine with sensor actuators in slightly different places for machines made in different parts of the world. This is so you couldn't use cartridges made in different places or for similar print engines such as HP or Lexmark, which are cheaper. You will have to fiddle with this so that the actuator is tripped, I usually remove the drum guard complete with springs and defeat the actuator with a rolled up ball of paper.
Feb 15, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Printer error 054
That's because you need to take out cartridge and put it back! See is there any jamed paper inside!!! Error 054 is about cartridge!! Can't read that cartridge is inside the printer!!!
Feb 07, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Paper Jams
Try changing out the toner cartridge if cleaning rollers didn't work.
Jan 07, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Panasonic Panafax UF-333 Plain Paper Inkjet Fax Logo
181 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
