Question about Epson Stylus CX4400 All-In-One InkJet Printer
Paper does not feed into the printer
There is paper in the printer and when it is told to copy it acts like it is but the paper is not going thru the printer I have had this printer since April of 2008
    Genius:
  • 1,447 Answers
Hi
try loading single and multi sheets of paper, then press on copy. check for obstruction inside the printer. If all fails call Epson for replacement printer.
Hope this helps
Posted on Nov 15, 2008
Copies nothing but solid black paper
Printing from system is OK? Do scan and check.not proper ? check CCD unit & cable..
Suspecting 80% CCD unit(Unit under flat bed glass moves while scan or copy with lamp)
20% cable(flat ribbon cable connected between CCD unit & Formatter) see the snap shot for easy recognition of CCD7_15_2012_3_12_34_am.jpg
Jul 13, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Cannnot copy a double sided document to cardstock
This is normal. The cardstock is fed from the manual feed or bypass tray and when selected the duplex option goes away. Many manufacturers do this....meaning they do not allow duplexing from the bypass tray. For the same reason they do limit automatic duplexing to standard or near standard papers. Cardstock is specifically excluded from duplexing obviously due to it's thick nature and when duplexing the paper has to be turned over and go thru paper paths that are not suitable for thick paper. If you must make a 2 sided copy using cardstock you will have to run the sheet thru the machine 2 times, also known as manual duplex.
Hope this helps.
Apr 12, 2010 | Copystar - CS-3035 Printer
Our HP laserjet M1522n has a vertical line going through the paper when using the top feed. the line doesn't appear on copies made thru the computer or on the flatbed, only thru the self feed. any one??...
If you open your "self feed" cover, you should be able to see the scan glass that originals pass over to copy. Clean that glass thoroughly. There is some dirt or whiteout (liquid paper) on it which causes the shadow or line on copies. Let me know.
Oct 15, 2009 | HP LaserJet M1522n MultiFunction Printer
When I try to print docs from the web, the printer feed the paper but it get stuck after pulling eigth of the page. Copies are OK to print without problem
Clean the paper feed tray
and adjust the tray
Clean the paper feed tray with damp cl;oth
reset the printer to factory default settings if still does not work
....Go thru the manuals how take printer back to factory default settings
Sep 15, 2009 | Canon PIXMA MP460 All-In-One InkJet...
PAPERS WONT FEED THRU TOP FEEDER
im having the same problem was working fine then quit feeding
Mar 31, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
Paper feeder is not straight
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Doesn't print!
u sure litte thing on new ink is off platci cover that protects them download the latest driver ok from kodak website try it again thx nick
Jun 16, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Epson Stylus CX4400 All-In-One InkJet Printer Logo
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
