Bought used laptop. It worked at first, but now will not turn on. The lights come on, but quickly go off again. I've tried taking the battery out and putting it back in, but still wont' come on.
  • Anonymous Nov 15, 2008
    Have a compaq presario V6000 and it will not come on for some odd reason. The on light will come on for 2 second and go off. Help!!!!!
    Problem Solver:
  • 5 Answers
I have run into this problem before. It sounds like your laptop battery is dead.
You may have to purchase a new one.
Does the unit turn on with the power adapter?
Posted on Nov 15, 2008
MSI hard drive a6200 462US not working
Have you tried to open system restore/recovery at boot? Do you have a repair disk? Is the HDD light blinking? If no remove HDD, test, replace if necessary. Take a look at this: http://www.sevenforums.com/tutorials/3413-repair-install.html
Dec 04, 2012 | Computers & Internet
I have a HP laptop that won't power up. I put in a new battery, and bought a new AC adapter. Now lights nothing. It was running than just quick and I haven't been able to get it to come back o
Hi There,
If you've got a multimeter - test your AC adapter to see if it is outputting the correct voltage for your laptop. If it is, Then you've got an HP boat anchor. Unfortunately HP laptops are known for their overheating issues, and if this is the case, a lawsuit filed against said manufacturer means you may be able to be compensated for your loss.
Jul 18, 2012 | Computers & Internet
Samsung R480 Will not charge or turn on but indicator lights flash or stay on.
Swap out the ram one at a time testing to see if you can power up, making sure there is one in the memory slot at all times, if this works the piece in your hand is defective, no difference! the motherboard has major issues.
Jul 10, 2012 | Samsung R480 Notebook
My computer won't turn on
If you tried turning the laptop on with NO battery but plugged into the mains and you get no response, even no little lights flickering then its possible that something to do with the motherboard (obviously, you might think) but get someone too look inside it if you can, something might be fried.
its a bit hard not actually seeing the machine
May 09, 2012 | HP Computers & Internet
Hi, I've had my Acer aspire laptop for a few years now, but I haven't used it for over a year (Because I got a desktop). So when I've come to turn it on today, It won't work. The screen...
Start with pulling the battery and power, then hold the power button in for about 30-40 seconds. Then plug the power back in (still no battery). Try to power up the computer. If it boots, shut it down and put the battery in and try again. If it boots the issue was cleared. If it boots with the power cord but not with the battery added, you have a battery issue.
Hope this helps
Sep 01, 2011 | Computers & Internet
Computer will not turn on. when power button is pushed, battery and power cord lights flash on and off. Plugging in does not help. How can I make my computer work again?
Try doing this:
1. Remove the battery and unplug the computer.
2. While there is no power connected, press and hold the power button for 30 seconds
3. Plug the computer back in, but don't insert the battery yet
4. See if it will turn on now, and if it does, insert the battery again.
Sometimes this works to drain some residual power that is still inside the machine. I've done this on a couple of machines and it has resulted in them starting up fine. If this doesn't work, you may have a more serious problem and need to have it looked at by a technician.
Aug 25, 2011 | Lenovo ThinkPad T61 Notebook
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My wife bought me a labtop and it seemed to work fine at first then it started turning off or the power light in the front statted blinking and then turned off but it was pluged in and still had over half...
Hmm... its seems like enough to take it back and get a replacement, especially if you just bought it. There are multiple things that could be wrong. It sounds like it could possibly be having an overheating problem, or a bad battery. My suggestion would be to take the battery out (if your laptop allows), and try running on just AC power. If it works, then you know its the battery, if not, then you may have over problems. Here is a site with some steps to follow to help determine your specific problem. But other than that, I would recommend that you take it back, and get a replacement, even if its just the battery. After all, if you just bought it, its wise to make god use of the warranty on it.
Feb 24, 2010 | Computers & Internet
Easynote r1004 wont power on
The battery is too low and the power supply can't charge the battery and also power the laptop at the same time.
Try this:
1. Remove the battery from the laptop
2. Plug in the power cord and turn ON the laptop.
3. It should work ok.
4. After the laptop is "stable" (what 5 minutes?), you can put the battery back into the laptop while it is ON.
5. Leave the laptop ON so the battery can get charged.
6. Lower / close the lid so that the screen will turn OFFand not take up power from recharging the battery.
If this doesn't work for you, try these steps again, maybe wait a few minutes between steps.
This WILL work!
Hope this helps!
Sep 03, 2009 | Toshiba A15-S1292 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
