Dell e228wfp flat panel. periodically goes blank. when i power off the on promp " 1. Auto detect ( Analog signal )" is up . . . just for a moment then screen goes blank.
  • 3 more comments
  • rbrowning200 Dec 03, 2008
    I have the same problem. Mine started doing this after 4 months of use. I have it connected with the DVI connector to my DELL Precision m6300 Notebook and the highest resolution for the Monitor. Every 5 min the screen will go black, but I see the power button is still green and my laptop is running fine and it's working on the Laptop LCD. I have to turn off the monitor and turn it back on and it will say something alone the line of "Digital output " and work again for antoher 5 mins before it happens again! What's going on. I'm using a 19" Older Dell LCD Monitor and it's working fine. It's gotta be the Dell E228WFP Lcd monitor.
  • Prof Z Dec 04, 2008
    Ditto
  • z_yunfei Dec 11, 2008
    I bought it 4 months ago.
  • katshepsut Dec 12, 2008
    Mine's just started doing it too. Bought it in August this year...
  • Arbiter4 Mar 18, 2009
    Same issue as above. The E228WFPc is my secondary monitor attached to a laptop. By the end of the day it starts to exhibit this behavior. The attached LCD doesnt malfunction ruling out powersave or graphics card. Changing from DVI to VGA doesn't change the problem, and it only really starts manifesting at the end of the day (backing up the heat-related diagnosis). I can also still faintly see the image - definately the backlight.
This is a backlight problem. I can still see very faint images moving when mine goes black, i.e. while watching a movie. Anyone know how resolve this backlight problem. Probably a faulty hear sensor if it has one.
Posted on Jan 23, 2009
It's heat related and possibly a backlight issue - mine only does it when the monitor has been powered on for about 2 hours. If I turn it off for an hour, I can get another 2-hour stretch out of it. Happens in self-test mode, so that's the cruncher. It's taken 2 days and many laborious hours on the phone, but Dell is sending me a replacement monitor tomorrow. There are more people with the problem here: http://en.community.dell.com/forums/t/19245356.aspx. Hope you get yours replaced too...
Posted on Dec 16, 2008
    Problem Solver:
  • 15 Answers
You may have a loose connection. Check your power cables and vga/dvi cables (the one that connects your computer to the monitor). Make sure everything is in tightly.
Posted on Nov 15, 2008
Auto detect analog
Hi Jessica,
Dell E228WFPC/E228WFP does support displays with 1920x1080 set resolution via DVI connection while it is restricted to validated Dell brand displays:
  • The restriction applies to resolution higher than 1680x1050 via DVI connection.
  • No restriction with VGA connection, which supports up to 1920x1200.
If you use a DVI connection set your computer's resolution to 1680x1050.
http://downloads.dell.com/Manuals/all-products/esuprt_electronics/esuprt_Display/dell-e228wfp_User's%20Guide_en-us.pdf
Feb 19, 2014 | Dell Computers & Internet
Dropped keyboard. Now display on monitor says 1. Analog input in power save mode - press any key or move mouse to turn on. I have done both, neither works. I have turned off system and I see it rebooting...
the message Analog input in power save mode means that your monitor is not getting a signal from your computer.
Maybe you moved the video cable while reconnecting your keyboard? check both ends of your video cable.
If you have a DVI cable, then your monitor has to be switched to digial input.
I hope this helps.
Nov 10, 2017 | Dell UltraSharp 1708FP 17" LCD Flat Panel...
Dell228wfp on start up pwr on is green screen
Either the cable is not connected to the proper port or the display-source is not configured properly.Here's what you can try.
  • Ensure that you have connected the VGA/DVI cable in the correct port. If you have an extended graphics card in your computer, use a DVI cable(Digital input) else the VGA would be the only option available.
  • If the cable seems to be plugged at the right place, press the first button from the left on the front panel of your monitor (Button 1 shown in the front view: http://support.dell.com/support/edocs/monitors/E228WFP/En/ug/about.htm#Front_View), once. This toggles the digital mode to analog mode of your monitor, and vice versa.
  • If the first two steps do not work, its not an issue with the monitor. It could be a failing cable or a defective video card, or the system itself is not completing the POST.
Thanks,
Abhishek
Feb 06, 2010 | Dell E228WFP LCD Monitor
I have a dell flat screen monitor that keeps shutting down after about 10 min.. When it comes back I get the message: 1:auto detect analog. I've tried going into COntrol Panel and changing the...
Either a dodgy power supply that keeps getting cut off for brief moments, but long enough to disrupt the power.
Or
A graphics board problem. I've seen multiple compluters runnig 2 screens where the second screen whould randomly go black and come back with the detecting analogue/DVI signal. This was solved by switching to an Nvidia graphics card
Aug 19, 2009 | Dell Computers & Internet
My monitor shows "auto detection mode
make sure the video card is securly placed in the pci-e slot
Aug 19, 2009 | Dell E228WFP LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
ATI RAdeon HD2400 in Dell Optiplex 755.
From the AMD.Com website: Display Support
  • One Dual-Link DVI-I connector for high-resolution digital displays
  • ATI Radeon™ DVI-I to HDMI2 with 5.1 audio (adapter)
  • One VGA analog connector
  • HDTV Component (YPrPb) output (adapter)
  • Drive two displays simultaneously with independent resolutions and refresh rates4
  • TV output requires HDMI, component, S-video or composite cable (not included)
Two integrated DVI display outputs
  • Primary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI)1
  • Secondary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI only)1
  • Each includes a dual-link HDCP encoder with on-chip key storage for high resolution playback of protected content2
It does using dual link DVI. Is that the cable you are using?
Here is a link to the complete specs
Sep 15, 2008 | ATI RADEON HD 2400 PRO Graphic Card
Computers & Internet Logo
1,004 people viewed this question
David Payne
David Payne
