Question about Gateway M350 Notebook
Laptop keeps beeping and not turning on
When i push the power button in my laptop it starts beeping with the "floppy disk" logo light on close to the power button. nothing appears on the screen and it keeps beeping
  • george banana Nov 22, 2006
    probably its the hard disk..since it happened that i dropped on the floor, though its on carpet and its not high at all..do u think its much better to bring it to comp usa or geek squad? if u know any places that is better pls tell.thank your proposed solution or problem.
    President:
  • 2,961 Answers
I think you may mean the Hard Disk light not floppy, although, if you have a floppy disc drive, check there's no floppy disc in it as it will stop the boot up. But if it's not the floppy, and the hard disc drive light stays on, possibly the hard drive is faulty, maybe damaged sectors. The other maybe is a possible memory fault, although the beep codes can only be identified if you know the motherboard make. Your rating are important.
Posted on Nov 22, 2006
  • andrew pester
    andrew pester Nov 22, 2006
    Changing your hard drive, should be relatively easy, if your familiar with pc's.
    If not take it to a repair shop in your area, although where is upto you as i cannot recommend any as i live in the UK.
Can i download a recovery disk for toshiba sattlite m105-s3041 for free?
It is rare that you can find that particular .iso as a download, but you can call Toshiba at 1-800-457-7777 and request a disk and they will mail you one. There's typically a fee, but it's not much.
Or.....
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
May 27, 2012 | Toshiba Computers & Internet
Describe your sony vaio PCG-C1VRX/K Problem: O/S not found...cannot enable usb/cd use to fix/load new O/S
What do I do if the message "Operating system not found" appears when my computer starts, and why won't Windows start? ? Make sure the computer does not have a "non-bootable" floppy disk in the floppy disk drive (if applicable). ? If a non-bootable floppy disk is in the drive: 1. Remove the floppy disk. 2. Restart the computer and confirm that the Microsoft® Windows® operating system starts properly. ? If Windows still does not start, follow these steps to initialize the BIOS: 1. If there is a disk in the floppy disk drive, then remove it. 2. Turn off the computer. 3. Remove any peripheral devices connected to the computer. 4. Restart the computer. Page 1475. Press F2 when the VAIO logo appears. The BIOS Setup window appears. 6. Press the Right Arrow key to select the Exit menu. 7. Press the Down Arrow key to select Get Default Values. The message Load default values for all SETUP items appears. 8. Press Enter. The Setup Confirmation window appears. 9. Select Yes, and press Enter. 10. Select Exit (Save Changes), and press Enter. The Setup Confirmation window appears again. 11. Select Yes, and press Enter. The computer restarts. What do I do if my computer stops responding? Why can't I turn off my computer? It is best to turn off your computer using the Turn Off Computer option on the Microsoft® Windows® Start menu, located on the taskbar. Using other methods, including those listed below, may result in loss of unsaved data. ? Click Start on the Windows® taskbar, select Turn Off Computer, and then click Turn Off. ? If your computer does not turn off, press the Ctrl+Alt+Delete keys simultaneously. When the Windows Task Manager dialog box appears, click Turn Off from the Shut Down menu. ? If your computer still does not turn off, press and hold the power button or slide and hold the power switch until the computer turns off. ? If your computer stops responding while playing a CD or DVD, press the Ctrl+Alt+Delete keys simultaneously. You can turn off the computer from the Windows Task Manager. Pressing the Ctrl+Alt+Delete keys simultaneously or turning off the computer with the power button or switch may cause loss of data. ? Remove the AC adapter and battery.
Dec 13, 2010 | Sony VAIO PCGK45 PC Notebook
No beeps, no video, fans working,
no the floppy disk is not faulty, it is normal and required that the floppy disk drive light blink to indicate that the drive is working. And about the power on the power button might be stuck inside that is why it keeps turning on immediately you connect to main power
Aug 03, 2010 | Intel D845PESV Motherboard
I have a dell inspiration 1100 and last night I was reinstalling Windows XP and all the drivers after installing the system drivers I got a diag>: I didn't know what promt to put in here so I shut the...
Since you have power on your laptop. I have this questions you need to answer: 1. have you seen Dell logo after turning on the computer? 2. After turning on the computer heard beeps? If all no do this
1. Turn off laptop remove batt and use ac adapter
2. While laptop is off press Fn key + Power button to run test check if you see display test in progress. If no, wait for 5 minutes to listen to beep codes. Once heard beeps keep pressing hold on N key. If fails turn off laptop
3. While laptop is off, press hold D key + power button. Check if you will see colors display whole screen. If no this will need to replace LCD call Dell.
If see colors whole screen replace motherboard call dell.
Oct 01, 2009 | Dell Inspiron 1100 Notebook
Booting problem
Is the cell still in there ? if the battery is bad, the PS will not provide the charge, plus running the computer .try your pc without the cell pack. Only the power supply connected
Hope this help. keep me posted if not
Jun 06, 2009 | Gateway Solo 9500 Notebook
Starting problem after hibernation
Do you hear a beep (POST Beep) within 2 sec when you power on the computer?
Apr 27, 2009 | Computers & Internet
PS3 Problem... I turned on my ps3 but nothing shows up on the television screen and controls wont even detect... PS3 shows that it is receiving power because the power light on ps3 is green. Can someone...
Turn the power off on the switch on the back, and then back on again. Hold down the power button, keep on holding it down after the first beep, but let go once another couple of beeps sound. It should then take at max a minute but then it should show a screen set up section.
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
My Acer Aspire 1710 failed to boot and no Acer logo
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Feb 01, 2009 | Acer Aspire 1710 Notebook
3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
Sep 10, 2008 | Frigidaire FEQ1442ES Electric Dryer
Computer Won't Boot (Anything?)
ok sounds like a bad power supply , i would get a new one
Jan 21, 2008 | Computers & Internet
Gateway M350 Notebook Logo
202 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
