Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Kenmore washer stopped full of water, will not click etc
Washer filled with water, when checked it had stopped, full of water and clothes, will not click when dial is turned will not respond. Cannot afford repair man . Please help
  • 3 more comments
  • ftwife1 Nov 15, 2008
    We appericate the effort. we did check out the lid switch and that was not the problem. We are on Social Security and thus will not be able to have a repairman out. Not a good thing to have happen, espically in today's economy. We were hoping it was just something simple, or just a fluke. again. thanks for the effort.
  • Anonymous Nov 21, 2008
    same problem wont gert rid of water and spin
  • help me 10 Nov 22, 2008
    Washer fills then will not go thru cycle, usually after opening and shutting lid numberous times and resetting dial it will then go thru and finish load however just recently if we can get to start it will again stop on rinse full of dirty water!!! What do we do cannot afford a repairman!! This problem was intermitten and now occurs every time we do a load.
  • Anonymous Dec 02, 2008
    not sure what the problem is but mine is the same. Full of water but won't do anything. Will check the switches with a volt meter when i get home
  • Anonymous Dec 06, 2008
    washing machine fills and agitates but will not emply water and spin
The lid switch housing had broken on m washer so that the switch was just hanging there.....when the lid was closed it did not press on the switch. I am just going to tape the switch in the on position and put up inside the washer housing.
CHECK YOUR LID SWITCH!
Posted on Dec 07, 2008
    Genius:
  • 1,028 Answers
Possible bad lid switch..if switch cks ok ck for wiring connection on motor
Posted on Nov 15, 2008
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washer Heavy Duty (70 Series) 1985-1989
behind the knob that you use to set the water level is the level control it should have a n adjustting screw to set the water level(you can set it where you want)
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Washer stopped in first rinse cycle
do you hear a clicking noise when you close the lid if not check your lid switch
Dec 30, 2008 | Roper RAB2121KW Top Load Washer
Kenmore washer not draining water
check for defective lid switch or switch just out of adjustment.
Aug 24, 2008 | Washing Machines
Washer wont fill
It sounds like your washer is not getting enough water to start. If your washing machine is filling too slowly, then you probably have a clogged screen on the back of your washer. To check this: Turn off the water supplies(both hot and cold). Remove the hoses at the back of the washer. Check the screens for debris(i.e. rust, dirt, scale, etc.) The screens will be pushed into the back of the washer where the water enters the washer. Debris can come from a variety of places: #1 Deposits coming off the sides of your pipes.(Older homes) #2 Repairs done to your plumbing lines, or the cities lines.
If these screens are clear of debris, I would then check the water flow out of the hoses. Take each hose with the end pointing into a bucket, and turn on the water to allow a full flow. This will also flush each line of debris. There could also be a number of reasons that there would not be full flow out of the supply lines: #1 Debris stopping up the line at the shut-off is one of the main causes.
If you have debris stopping up your screens and shut-offs, it will most likely stop up your aerators on your faucets, and your shower heads too. It is also suggested that you check these.
If you are getting debris in all these items, I would recommend that your lines get flushed. You can do this, but many times it is easier to have a plumber do this. If you do not know what you are doing, it can get very wet, and time consuming.
Please rate this solution
Feb 15, 2008 | Kenmore 45981 Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
165 people viewed this question
Dan Webster
Dan Webster
Sal De
