Question about GPS
Map update error problem with Magellan 4250
Trying to download from CD, map update for Magellan 4250, I did the software update some time age to 4.60...When I try downloading, I get 1 of 2 messages...."data transfer failure" or "failed to read source file" ..has anyone had this problem? I am using Vista and have a Maestro 4250 with firmware 4.60 downloaded (hardware -3; product ID 746)
I am attempting to upgrade to 31 from Basemap and detailed 29 (AAA date 21)
In the step
Magellan_Maestro_4250_4_60_rel1copy_group_GS499_MX_3bin
I get a failure window:
Magellan Update Wizard 4.2.2.4
FAILED TO READ SOURCE FILE
  • 4 more comments
  • JoeR1234 Nov 16, 2008
    i am having the same problem. Wizard 4.2.2.7 Failed to read source.
  • Anonymous Nov 17, 2008
    same thing
  • JoeR1234 Nov 29, 2008
    I called tech support and they are making me send it in. I tried it on XP and vista and it didn't work,
  • Roadman2252 Dec 03, 2008
    My Magellan 4250 freezes up at the opening logo screen. What's the fix?
  • aichen888 Dec 27, 2008
    after trying to load the new map.
  • bobandrobinp Jan 18, 2009
    Magellen had me send in the GPS...they
I had the same issue and Tech support sucked. Make sure your firewalls are off, then restart the software and go through the steps. When it errors again, click finish and exit the software, restart the gps, and restart the software to do the install again. Had to do this 3 times and it got a little further every time until it finally went to installing, then it was fine.
Posted on Jan 20, 2009
I was able to get the update to work using Windows XP (not sure which service pack) but not with Vista Home. It looks like it needed to create and use drive E when transferring over the files.
Posted on Jan 18, 2009
I called tech support and they said that the update requires XP SP1 or SP2, NOT SP3. I have not tried it yet, but they told me it was a problem with not being compatible with XP service pack 3
Posted on Nov 29, 2008
How can i download philippine map on my magellan roadmate tnxs
When available, map updates can be purchased from the Magellan website. For the latest map update please visit our software page by Clicking Here
2010 Spring Map Update has been released. Please refer to the map's product page for unit compatibility and installation instructions. You may need to install Magellan's Content Manager on your PC in order to download the latest maps for your unit. To install the Content Manager please click here
*For specific map update installation instructions please see the installation instructions included with your map update version.
Hope helps.
Apr 09, 2011 | Magellan RoadMate 1440 Car GPS Receiver
Hey I want to updating maps or software for magellan maestro 4250, but i can not found the right software for it,so pleas can you help me,thank you.
Hi muntaserabou
you can get the latest firmware 4.86 for your 4250 HERE and the
2010 Map update for it HERE
Nov 27, 2010 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Apr 21, 2009 | Magellan Maestro 4250 GPS
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
Magellan just stays on Magellan blue screen
Feb 18, 2009 | Magellan Maestro 4250 GPS
Software update
Here's a link to the website for your unit. If you click on the 3rd line under "facts" it will take you to a page where you can register to receive map updates. Good luck. If this helps you plz rate this. Thank you kindly.
http://www.magellangps.com/support/product.asp?prodid=1958
Jan 31, 2009 | Magellan Maestro 4250 GPS
I had the same problem until I plugged the usb cable into the back port of my computer. Then it worked. Something about using a higher speed usb port.
Oct 23, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan maestro 4040 or 4250 going to europe
I bought a Garmin 750 on compusa website for 230 and it supports European maps
May 12, 2008 | Magellan Maestro 4040 GPS Receiver
Maestro 4250
Maestro 4250 is frozen. HELP ;-(
Dec 26, 2007 | Magellan Maestro 4040 GPS Receiver
GPS Logo
1,044 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
