Question about Compaq 56K Modem
Dialup 56k modem not responding.help says harware failure
My dialup connection was functioning well two weeks back.recently it fails.help denots hardware failure in the modem/ connection termination.server says connection isnot terminated.user name,password correct. can login.
  • nimalkantha7 Nov 17, 2008
    answers 2 parathan84 question.
    56 k micronet fax modem,only the power supply light is on,error message -hardware failure in the modem,connection failure.
  • 113 Answers
Whts the name of the modem and the light status and , whts the error message u get when u try to connect to the internet
Posted on Nov 15, 2008
Why has my modem stopped fitting into the USB ports of my laptop so that the laptop shows no connection when I try to engage my dialup services.
end connector that goes into usb on laptop not working , need to have a spare to check and see if that is problem if not you might need a better modem or a better network card in laptop
Aug 15, 2014 | Zoom Computers & Internet
I have an older micron millenia modem problem
Try updating your modem driver.are you on dialup? or cable or dsl? Do you have an ethernet card or just a regular 56k modem I need more info to give you the best answer Thanks
Jul 25, 2010 | Computers & Internet
TRENDnet TFM-560U dialup modem disconnects after 15-20 minutes?
Make sure you don't have you modem properties in control panel set to auto time out or you mail set to disconnect after download.
Dec 16, 2009 | Trendware 56K USB Fax Modem High Speed...
I'm looking for more information about the modem negociation sequence during a connect. I have two USR 56k external modems that attempt to connect, but ultimately fail after doing a very long series of...
http://support.usr.com/support/5686/5686-files/568602-ig.pdf
setup instructions
check if phone line cord in the proper hole and the settings are correct
the tones or just the way the modems host and client get in sync
to talk at the proper the speed, parity so they can understand each other
Jul 10, 2017 | U.S. Robotics (005686-02) (00568602) Modem
Acer aspire 9410, cannot connect to the internet using dial-up
You have two different devices here. A modem and a wireless network adapter. Two totally different devices. It sounds like the modem quit working but the wireless network adapter still functions. I'm assuming that the modem is built it. If you absolutely have to have it you could buy a PCMCIA modem if your laptop has a PCMCIA slot to plug it into. You could also have a corrupted modem driver.
Oct 01, 2009 | Acer Aspire One PC Notebook
Difficulty making an internet connection
thirddaylw, go into the modem settings and make the speed a constant or a lower speed that what is currently set and see if it allows you to connect thereafter.
May 22, 2009 | Psion Gold Card Global 56k plus ISDN...
The modem is extremely slow-most downloads are far too slow
Dialup phone lines usually only transmit a minimum of 8 Baud. NetZero's high speed (5X) faster is done by caching pages you have already visited, not actially running internet but loading pages faster on your computer. Check your modem setting, 56k, 112K are normal speed setting to connect. Check your actual connection speed, 28.8 is probably all that you are getting on dialup.
Feb 01, 2009 | Hiro (H50113) Analog Modem
Agere All 56K Modem
I have checked the telephone line, it is working alright and it is sure that I have plugged the line into IN port.
Oct 19, 2008 | Agere All 56K Modems: 56K V.92 Lucent/...
Missing modem
what is XE3 circa 2002, 15 years young. wow.
XP is now 3 years dead, at microsoft.
why not at least upgrade to Win7. be wise to do that.
XP must have SP3, if not it will fail, and even with it it fail.
lots of USB devices for example will fail. here.
dial up, you dont run DSL.
ive not see dial up in 20 years. why dial up.?
if compelled to use dial up, you need a modem that XP understands
most of them it does not. nor will it ever,
there are 2 classes of modem. (DIAL up to POTS)
1: software modem (99% software, and a box) they SUX. all do.
2: hardware modem, best is USB. by
and A good dial up program,. windows dial up software stinks.
https://www.cdw.com/shop/products/Hayes-ACCURA-World-Approved-V.92-56K-External-USB-Mini-Modem/1651998.aspx
i see this is HP supported (was) modem
Agere systems soft PCI
it needs the HP.com driver to run that modem
does the number you dial buy hand (using a POTS phone)
dial up and answer and squeal? if not its hopeless that number
you need to pay for superscription service, and with a pass word.
LIKE HERE
http://www.earthlink.net/dialup/
THE PROBLEM IS HP NO LONGER SUPPORTS YOUR PC
SO THERE ARE NO DRIVERS. now.
why not get 10 year or newer PC, or get DSL to home
or cable modem with only 1 channel active, (slow like dialup)
for cheap. (im using 16channel now, as i type)
or buy a new modem and connect it and use the new modems
disk to install a nice dialer for you.
but finding one is not easy now.
the best modems, are Hayes, there hardware modems are like rock. i used them back in the ARPnet days and on amocat.
Apr 20, 2017 | HP XE3 SYSTEM BOARD WITH MODEM & LAN HP...
Is there any way to increase download speed on my dialup connection? Phil
making sure you have the latest drivers for the dialup modem is about the most you can do. not sure if you've considered dsl or cable internet, but its cheaper than paying for dialup service and a phone line. (unless you don't have a cell phone and need the home phone line.)
Jun 27, 2008 | Acer Computers & Internet
Compaq 56K Modem Logo
266 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
