Home | Hoover | Nextra HNWL 3136 / HNWL 3136 S Front Loa... | Water not draing awa...
Hoover Nextra HNWL 3136 / HNWL 3136 S Front Load All-in-One Washer / Dryer
Problem for Hoover Nextra HNWL 3136 / HNWL 3136 S Front Load...
Water not draing away and machine is not spinning
By karl_pearce on Nov 15, 2008
the water will not drain away either when the final spin cycle has done or when you switch machine to drain, drum is full of water and door will not open.
Washing machine is a Hoover Nextra Optima A+A1300 hnl6136s we brought this machine over from the uk when we emigrated.
Best Solution
posted on Nov 15, 2008
Helpful)
pedropony2
Rank: Guru
Rating: 89%, 89 votes
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Was this helpful?
Yes
No
Popular Solutions for Hoover Nextra HNWL 3136 / HNWL
Questions and Unsolved Problems for Hoover Nextra HNWL 3136 / HNWL
Do you recommend Hoover Nextra HNWL 3136 / HNWL 3136 S Front Load All-in-One Washer / Dryer?
Answer
Answer
not drying,element gets hot but the drum doesn`t
Answer
Hoover Nextra washing machine - does first half of wash, then stops and the start and delay start... (More)
Answer
cannot locate reset button or thermostat. Could you please advise where it is. Thanks
Answer
how do you fit the spring in the door handle on my hoover nextra. I have split the door apart and... (More)
Answer
I have tried not putting too much softener in, so that it is not syphoning away.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover Nextra HNWL 3136 / HNWL...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14177
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
