Question about Mitsubishi WS-65809 65" Rear Projection Television
Red is out of alignment
I tried the convergence feature but the red lines wont go any higher in the top left bottom left and bottom right corners of the screen. the blue is fine. and also the hd picture scrambles on both cable hd signal and one from an xbox 360 is there any way for me to fix this problem at home? or do i need a very expensive tv repairman to come and fix it?
When i go to convergence and align the white cross with the blue its ok ,but when i try the red it doesnt line up and if l get it close enough it get misaligned only with the red ,green and blue fine
Posted on Nov 15, 2008
The vertical green convergence adjustment is broken
Either your convergence ic's are bad or the convergence digital module ( if your model has one ) . I would have it looked at by a service company.
Jan 16, 2010 | Hitachi Televison & Video
Mitsubishi WS55859, was getting 2 and 2 blink, replaced the pico fuses and convergence chip - 3 times, each fix worked better than the next but evenually failed - now have it working, trying to adjust...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Yellow arch on bottom left of screen
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 30, 2009 | Toshiba 43H70 43" Rear Projection...
Mitsubishi ws-65809 Convergence will not align correctly
You may also have a resistor burnt out for the convergence ICs.. They are all right in front of the ICs and will usually show browninsh if burnt up. If bad, replace the pair and maybe the ICs as well if they've failed again. If your new ICs fixed the lines so they'll move, then you may have problems with the centering magnets on the yokes of the crts. Dont move the yokes or magnets if you can help it, but look to see if some of the manufacturers glue broke free and let the magnet spin around the neck of the tube. If so, try to put it back where it was and then re-converge.
Dec 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
RED color wont converge with + PT-53WXD63
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 12, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
*Screen Looks 3-D
*Colors wont align
Problem #2
Nov 10, 2007 | Samsung PCL6215R 62" Rear Projection...
Converge problem
Sounds like convergence issue--replace Stk IC's mounted
on large heat sinks. Check power supply for open fuse device.
Re-check convergence alignment.
Aug 11, 2007 | Philips 60PP9352 60" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
