Question about Dishwashers
ASEA CYLINDA 1200 Dish Washer Electric Motor Wiring Connections
I removed the electric motor/pump to rectify the seized pump. Not sure now how to connect the electrical wires from the pump to the switch (?) - yellow cylinder in shape behind the electric motor with 4 connection points on the top (it appears that two blue wires were comnnected to two points in line). There is also a 3 points plug connecting into the electric motor plug and the blue wire came out of the plug. Not sure which points connect to which wire. When I switched on the machine, I believe the pump was pumping out rather than pumping water into the machine. It may be because I have my wires crossed. Don't know. If I saw a wiring diagram for the machine, that would help. Thanks.
WAL
A neighbour called around and he popped the right wire in the right place and we were in business. Not sure what he did and he is not sure either. Thankyou Wal.
Posted on Nov 16, 2008
A neighbour happened to call in and popped the right wire in the right place and presto we were in business. Not sure what he did but it worked. thankyou. wal
Need a timer motor for asea cylinda 1200 dishwasher.
Standard appliance parts, Appliance parts incorporated, even Sears will have parts available generally.
Nov 09, 2015 | Dishwashers
Will an electric motor with more horsepower and more rpm hurt a compressor pump?
Electric motors seem to turn around 1125 rpm or 3600 rpm. The pulley size on the motor and pump must be adjusted to achieve the desired result without overheating /loading the motor. I have seen pumps turning from 800 to 1200 rpm using different pulley size on motor, motor hp and motor rpm. Some brands will turn same pump from 1200 to 3600 rpm depending on if was electric or gas motor. This will certainly shorten the life of the pump but will most likely work. Most turn an average of 1200 rpm for good balance of long life and good supply of air. Pump rpm is usually limited to the power of the motor. Cost effective match of 1.5 hp motor will turn pump about 1000 - 1200 rpm for about 5cfm. Rol Air 2hp motor turns 2 cyl pump about 1100 rpm for 10 cfm. Good luck
Mar 17, 2015 | Campbell Hausfeld Tank Air Compressor, 1...
GE Model WCVH6800J Error Code 04. I do not have list of codes for this model, so I need translation.
TROUBLESHOOTING CHART
Codes Description Action
22,23 Fill problems
• Ensure manual water valves are fully open.
• Check if water strainers on solenoid valve assembly are clogged.
• Check for obstructions inside inlet water hoses.
• Ensure solenoid valves do not leak when the valves are de-energized and the washer is powered down. • Measure coil resistance for both valves; if outside range (1000-1250 ohms at room temp.), replace solenoid valve
assembly.
IF ABOVE STEPS DO NOT CLEAR THE PROBLEM, OR FOR ERROR CODE 23:
• Replace solenoid valve assembly.
30, 31 Drain problems
• Ensure pump strainer is clean and free of debris.
• Check for obstruction inside the drain hose.
• Check pump impeller blades and bearing; if evidence of blade damage or seized bearings are present, replace the pump.
• Check electrical connections at the pump motor and harness.
• Measure pump motor resistance; if outside range (9-14 ohms at room temp.), replace the pump.
38,39 Dispenser problems
• Check for obstruction in dispenser mechanism and linkages.
• Check electrical connections at dispenser motor feedback switch and in the harness.
IF ABOVE STEPS DO NOT CLEAR THE PROBLEM:
• Replace dispenser motor assembly.
42,45, 49 Motor Drive operation above design limits
• Ensure all 4 shipping bolts have been properly removed.
• Remove all foreign objects that may be lodged between inner and outer basket.
• Look for signs of seized bearing(s) on basket and drum motor, replace components as necessary.
• Inspect condition and mounting of door gasket, replace and re-mount as necessary.
• Ensure inner basket (drum) can rotate freely.
• Replace motor drive or drum motor.
43,4A, 4B,4C, Motor Drive internal problems
4E,4F, 50,52,
53,54
• Measure AC outlet voltage, ensure correct range (102V to 132V AC).
• Check electrical connections at the drum motor, motor drive.
• Check harness integrity between main control and motor drive.
• Unplug the unit, wait 30 seconds, restart the unit.
• If the fault persists and re-appears -replace the motor drive.
problems
57,58,71 Main Control internal problems
• Unplug the unit, wait 30 seconds, re-start the unit.
• If the fault persists and re-appears -replace the main control.
60,61,63,64, DOOR LOCK assembly problems
• Check integrity of wiring and connections between main control and DOOR LOCK mechanism.
• Investigate DOOR-LOCK mechanism, check door microswitch operation, lock and unlock solenoid continuity, contact integrity;
replace DOOR LOCK mechanism if necessary.
• Replace the main control.
65 Water Level Sensor problems
• Check integrity of wiring and connections between main control and Water Level Sensor.
• Check integrity of Water Level Sensor, replace if necessary.
66,67 Water Temperature Sensor problems
• Check integrity of wiring and connections between main control and HeaterfThermistor Assembly.
• Using ohmmeter, measure Thermistor resistance; if outside expected range, replace HeaterfThermistor Assembly.
70 "Stuck" key
• Press each key. There should be mechanical "click" feedback with every press.
• Enter Service mode, use 104 test to check key operation. Press every key. Every keypress should generate audible
"beep." Press "Power" key last to avoid premature exit from t04 test.
• Separate control and control housing from the front panel; clean and remove all foreign matter and debris from keys,
front panel and control housing, re-assemble. Ensure all keys can be operated freely without "sticking."
IF ABOVE STEP DOES NOT CLEAR THE PROBLEM:
62 System Contact Failure
• Check integrity of wiring and connections, look for insulation breakdown and short circuit conditions on the harness, replace
harness if necessary.
• Check integrity and electrical connections of all loads (heater, pump, pressure switch, door lock, solenoid valves,
dispenser motor), replace respective components if necessary.
Jun 23, 2011 | General Electric WCVH6800J Front Load...
Washer will fill with water and drain, but it will not agitate spin or move the drum period. The lid switch seems to be working.
the pump is electric. separate from motor
to operate machine. Perhaps you motor is fried? remove belt from motor if motor works
transmission seized , rebuilt from Dasa Mfg
1-866-327-2634 required.
May 26, 2010 | GE WJRR4170E Top Load Washer
I have a creda excel 1200 the other day the water started to come out of the door and it tripped the electric,anyway i now managed to drain some of the water out of the machine but now its still tripping...
Remove back from machine, dissconnect motor plug from motor, then turn machine on, if electric trips then you know motor is ok so place plug back into it, then do pump, and so on untile something is disconnected and fuse wont trip. Make sure you do not have machine connected to power supply while removing wires, also that wires do not come into contact with anything when disconnected. And dont remove Any earth wires
Feb 11, 2010 | Creda W120VW Front Load Washer
Asea skandia cylinda 1200 manual
Dear Sir!
After almost 27 years since when I bought dishwasher machine type Cylinder 1100(during my post graduate of doctor engineer training - work in Finland haveproblem with manual programmatic. Because we have no chance to find in Poland,I would like to ask about possibility to buy and import it. If in case when itis similar like at Cylinda 1200 so I could update it. In the same time I coulduse and connect by adapting existing electric wirings. Please be so kind and help me solvingproblems. I am very satifited from good product done by your company. It is forme and my wife very urgent. Other way I will have only way to make all work inkitchen me. If you decide, please present quotation and all information fortransferring many. Best Regards
dr eng. Roman Lamentowicz.
roman@krola.com.pl
+48 602 211 746
Oct 16, 2009 | Dishwashers
Removing a built in Asea Skandia cylinda 1200
Its normal to have the water supply from under sink to dishwasher 3/8 soft copper. If there is a water stop under sink for dishwasher go ahead and shut it off. If not you will have to shut water off at main. Now you can unscrew supply at dishwasher, it's close to the front on left side. Its a 3/8 compression nut, you can use a small cresent wrench.
Sep 30, 2009 | Dishwashers
User Manual of Asea Cylinda 1200 Dishwasher
One of these was in my house when I moved in, still have the manual. Very efficient dishwasher.
A is a prewash (machine will stop after it). Manual says it's meant to rinse stuff while you wait until you've filled the machine to run a full wash.
D is economy wash. Water is heated according to the switch you select on the front.
C is a prewash that will continue on to D (normal cycle). Water is at incoming temp.
B is another prewash that will continue on the C etc (heavy cycle). Like C, water is at incoming temp.
E is dry cycle. Heating element is on/off depending on switch on the front (dunno why you'd turn it off..)
While turning the dial, push it in and it will stop exactly at the start of theach cycle.
Mine has stopped emptying, think the pump has died, looking for a replacement..
Apr 25, 2008 | Dishwashers
Need a manual for a asea cylinda 12000 washing machine can you help please
Dear sooty388,
Have you found a manual for you Asea?
I need one too.
If you would, please reply at this email address.
Kind Regards,
Dhugal Bissett.
Melbourne.
Apr 14, 2008 | Zanussi FJS1225W Front Load Washer
Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Apr 02, 2008 | Asko Washing Machines
Dishwashers Logo
615 people viewed this question
Top Dishwashers Experts
