Power light flashes continually - Computers & Internet
  • EAGLCOACH Feb 28, 2009
    I HAVE A HP Media Center m1264n - 3.0Ghz 1024MB PC Desktop AND THE POWER WILL NOT TURN ON. THE LIGHT ON THE BACK POWER SUPPLY BLINKS WHEN PLUGGED IN. THE BUTTON WORKS FINE AND ALL CONNECTIONS SEEM TO BE GOOD.
    PC WAS WORKING FINE UNTIL I HAD TO MOVE IT THE OTHER DAY.
  • Shaun Plencner
    Shaun Plencner May 11, 2010
    what type of pc and what the operating system Looking forward to helping u Shaun
  • 4,806 Answers
I need more information please
Posted on Nov 15, 2008
Error p1500
The printers first error code show all lights flashing:
Flashing Ready'Data
Flashing Toner Low
Flashing Load'Remove Paper
Flashing Paper Jam
Flashing Error
Flashing Press Continue
By pressing continue twice to get to second error codes the lights show:
Flashing Ready'Data
Off Toner Low
Flashing Paper Jam
Flashing Error
Pressing continue twice more shows:
Off Ready'Data
Flashing Toner Low
Off Load'Remove Paper
Off Paper Jam
Off Error
Off Press Continue
Pressing continue twice more brings back to all lights flashing
The computers ( I have tired more than one with diff USB and A parallel cables) do not see the printer as being attached. My toner is half full. I checked the internal power board in base of printer and the fuse is good. The error should not have anything to do with being connected to a computer or not because when it was working and not connect to a computer it would not blink all the indicator lights (If I remember correctly, just the Press Continue light would be lite).
Information I have found so far:
  1. http://support.dell.com/support/edocs/systems/p1500/en/index.htm#online_documentation
o Under PDF Documents Owner's Manual(English) (.pdf) (1.33 MB) shows very little about the indicator lights.
o Under HTML Documents User's Guide shows more information about the indicator lights but mentions nothing about the secondary error codes.
  1. The Lexmark E321/E323/E220 are very close cousins to the P1500 and on Lexmark's website the manuals have more info on secondary codes but nothing that matches my error.
Information I am guessing could be the problem:
  1. The fuser has gone out (need to know how to check) Why else would they sell the fuser if it didn't go out regularly Part Number: 56P1053
  2. Clutch Assembly I'm not sure of the accuracy of the info on this page.
Mar 12, 2014 | Canon Office Equipment & Supplies
What is the difference between the flash and continuous lighting, why not using continuous lighting for photography?
Two main reasons flash is used over continuous lighting.
Power. Lighting a scene for minutes uses much more power than lighting it for a fraction of a second. You may have noticed that most continuous lights need to be plugged in to a power supply, while most flash units work with small batteries. It may not make much difference if you're shooting indoors in a studio, but if you're out in the field and have to move around, it can get difficult lugging all that gear around.
Duration. A flash unit provides a very brief flash of light while a continuous unit is, well, continuous. A flash can freeze action much better than just using the camera's shutter. Try it yourself sometime: turn on the lights in the bathroom (and/or bring in your continuous light units) and take some pictures of a dripping faucet. Now turn off the lights and take some flash pictures of the same thing. See the difference?
Dec 17, 2013 | Photogenic DigiLight Continuous 500 watt...
TV turns itself off and power light flashes green
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
