Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony KV36 HS500 6-Blink problem
I've seen a lot of people discussing this problem on their forums-- it's the issue where a television has a self-diagnosing system that includes a blink (commonly the Sony models) that flashes whenever the tv detects that it may have an error.
My television is a Sony KV36 HS500 model, and it has a 6-blink to tell me if there's an error or not. Recently, the blink has begun flashing and it isn't possible for me to turn on my television. After looking at several discussions, I would think that the problem is somewhere inside the D-board of the television. The locations of the ICs are 8002 and 6501; I replaced both of them-- the tv worked once, but never again after I turned it off once.
Sometimes, when I attempt to power the tv on, it may come to work after 30-50 tries at the power button. When I turn it off afterwards, the 6-blink turns on again and the tv cannnot be turned on anymore.
Help? Does anyone know what might be the problem here?
  • lklimek Feb 07, 2009
    I have the sameproblem with a SONY WEGA KV-36HS510.  Standby light flashes 6 times quickly, then 4 time at a longer duration.  TV will not power up.  Once in a while if I keep the power plug unplugged for about 12 hours it will then power up, but this doesn't happen very often.
    Any suggestions?
  • rmazda6 Feb 23, 2009
    i have a sony kv-36hs500 i paid good money for this set about 5 years ago, thinking a tube type woud out last the others "WRONG"mine has the same problem.flashed a 4 once then a 6 now a solid 7 ,it wont turn on you would think whit this many pepole having this no turn on issue sony would do somthing just dont want to pay too much to find out i can buy a new set cheaper
    Problem Solver:
  • 12 Answers
Check for C515 & 516 and the jungle IC
Posted on Nov 15, 2008
Steady blink in standby mode on sony kp-57ws520
Google first the model number to find the full service manual with error codes and schematics and parts lists--I have seen it out there--problem suggests a power supply issue and that board (far left as seen from rear?) has voltages marked right on the board for most of the major plugs----you should be able to remove the board with power cord attached and do static voltage and resistance checks that way.
Nov 05, 2012 | Sony KP-57WS520 57" Rear Projection...
TV won't turn on.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 775 posts to different brand TVs now.
Sep 18, 2012 | Mitsubishi WS-65819 TV
Have a 4 blink error on a Sony KV36FS120
Yes, there's a posibility that IC561 is partially faulty but on the symptoms you've described, I would advice you to replaced first C539(470uf/25V) and C561 (47uf). I've suspected that these filter electrolytic capacitor is already leaky or dried up...
Dec 08, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDL-32V2500 : It comes on and after few seconds the red light blinks 4 times, then stops and then starts blinking all over again.
This is sort of a generic answer but I found this info about Sony blink codes. Hope it helps!
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Mar 05, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
KV36 HS500 7 BLINK PROBLEM
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Hope that helps.
Nov 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Not a problem - just clarification
They are the same part. Sony reffers to it as the optical block, while other manufacturers call it the light engine.
May 16, 2009 | Sony KDF-E42A10 42 in. LCD Television
Mitsubishi Convergence Problem
you need to replace the convergence board but it will cost you around $200 to fix the board and components associated with it .......
Have you tried adjusting the convergence settings ........
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
the lamp thermal sensor is probably bad...you ma also have a lot of dust around the lamp fan..there is a service kit for this problem.
a1137954a..you must clean all the dust from the fan above the lamp or replace it.
Nov 28, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
190 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
