Question about Texas Instruments TI-89 Calculator
Calculator is frozen
I was trying to load an assembly game on my calculator, the game started and then the screen said free up more RAM. I tried to exit and the screen went to the main apps menu and will not change. The cursor is frozen and taking out the batteries and putting them in had no effect. Everything is forzen except the clock which is still running. Please help in any way you can. thanks.
Well, not a long time ago I have had a similar trouble regarding to my Texas Instruments Calculator Voyage 200. It was forzen too doing some calculus. Also, one friend had a similar problem regarding to the fozen calculator... I fixed it by reading in the manual that it can be reset!!!...There is a combination of keys that you can press to reset the calculator...this obligates the calculator to load the OS from the EPROM memory where is this basic sofware!!!... If I do not remember wrong the keys are: 2nd + Lock + on/off keys!!! But try to look for the manual and in some part of it is those key combination!!! Good Luck!
Posted on Nov 29, 2006
Keep the on key pushed while you take out a battery and then put it again. iy fix your problem!
Posted on Feb 04, 2007
  • kenyanbred Dec 15, 2010
    It worked Thanksss Soo much!
For a long time, I was resetting my calculator (TI-89 Titanium) upon encountering an assembly-program error, by taking out all the alkaline (AAA) batteries, replacing them with a single, almost dead battery, taking out the backup battery, putting it back in place, and then putting the good alkaline batteries back in. Recently, however, I found out about another method, which is much less involved (for one thing, it doesn't require a screwdriver, unlike my previous method, for which one is required in order to remove the battery cover for the backup battery, as the battery cover is screwed down). After some searching, I found in TI's official guidebook for my calculator (Part 2, the electronic version of the guidebook) where it says exactly what to do if the "TI-89 Titanium appears to be 'locked up' and will not respond to keyboard input. "The following action clears RAM. This erases all [unarchived] data, programs, and user-defined variables, functions, or folders. "Press and hold [left arrow key], [right arrow key], and [Second key]. Then press and release [ON]. "The following action clears RAM _and_ Flash ROM. This erases all data, programs, user-defined variables, functions, folders, Flash applications, and the user data archive. "1. Remove one of the four AAA batteries. "2. Press and hold [(-)] and [)] as you reinstall the battery. "3. Continue holding [(-)] and [)] for five seconds before releasing." (From page 952 in Appendix B: Technical Reference)
Posted on Jun 12, 2007
Posted on Aug 28, 2010
ERR: ARCHIVED
When you unarchive a program, you extract it from archive memory and load it into the RAM or working memory. However that is limited. Depending on the other data or junk that clutter the RAM, there may not be enough RAM left to load another archived program.
Clear the RAM , delete what you do not need or transfer it to a computer as backup.
Feb 03, 2012 | Texas Instruments Office Equipment &...
After I install the game and start it after creating any character it goes to the loading screen map thingy and when it's done loading it stays at the loading screen for a couple seconds then the game...
Hello
The error means that the game has stopped working.Usually when a game crashes its beacause of. 1 not enough memory,try to free up some space on your hard drive by deleting any junk you dont want.
2 Graphics driver or video card,not supported for the game or you need to update the drivers to the most current.
3 Ram, not enough memory to run the game.
4 If running in win 7 or vista try running the game as administrator or in compatibility mode.
Feb 20, 2011 | Namco Mage Knight: Apocalypse for Windows
Same as last time
Be reasonable in what you say especially when you seem to infer a blinding truth. If your screen were broken you would not be able to "FIX" it through a connection to another calculator.
I know. Sooner or later you will post another similar question so better learn what the real problem is.
Casino swamps your memory and messes up you calculator. If no more memory is available you cannot get any response from any key.
Play Casino as much as you want. Stop the game before you win that fateful 120000 dollars. Reset the Ram and play again.
Reinstalling the OS by connecting the calculator to another unit effectively reset the RAM and kicks casino out of memory.
To reset the RAM before the calculator is completely frozen, press [2nd][MEM][7:Reset][1:All Ram][2:Reset] [ENTER]
Calculator answers with Ram Cleared. Press the [CLEAR] button to erase that message.
Jan 06, 2010 | Texas Instruments TI-84 Plus Silver...
Freezin up
I had this same problem and the fix is really, really easy.
blow really hard into the I/O port on the top of your calculator, and it should be as good as new!
Sep 15, 2009 | Texas Instruments TI-84 Plus Silver...
Loading oblivion
DO ALL OTHER GAMES WORK? WHEN THIS HAPPENS YOU SHOULD TRY ANOTHER GAME. SOMETIMES THE CONSOLE IS STARTING TO SHOW SIGHS OF BREAKING DOWN. THIS MY TAKE WEEKS TO ACTAULLY FIND THE BREAKDOWN. ALSO CHECK THE READ SIDE OF THE DISC FOR WAVY RAINBOWS. IF IT DOES, GOTO XBOX.COM IN THE SUPPORT SECTION CHOOSE DISC REPLASEMENT PROGRAM. REPORT THIS TO XBOX. ITS FREE. HAPPY GAMING AND HOPE TO SEE YOU IN GEARS OF WAR TWO..
Jul 04, 2009 | Video Game Consoles & Games
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
Cannot find ram option when downloading apps!!
Hope you had your data backed up. If not u might want to browse the web for a package to download with all the original stuff. ALWAYS back up ur stuff just so this doesnt happen.
Oct 01, 2008 | Texas Instruments TI-84 Plus Silver...
Garbage Collecting from hell
Hey soccerman
don't worry man, It's probably just frozen. So try hitting on. This MIGHT break the garage. Do what ever you have to do to try to get it to stop. I can't say how important it is to try to get it to make it stop. If you take out the batteries it will stop but if it's truly frozen it's likely it might come back to the same screen then you will be royally SCREWED. so if you get it back to the normal screen you need to try to get rid of some stuff.
calculators are much like computers they have RAM and a hard drive. However the hard drive is just called ARC space. so your computer is trying to get rid of stuff aka garbage collect so that it can find more space. so you need to hit 2nd then + then go to memory manager and delete some stuff. most archived programs run around 16,000. so like when i fix people calculators i often delete TI sample and TI problem simulator. that should free up enough space for you. then archive your games so that they won't get deleted. (you archive stuff by hitting enter when your in memory manager) it doesn't matter as long as you run them through mirage. that will give you more ARC and RAM space. just to let you know. when you make these changes it will garabe collect again or defragment. don't freak out just let it do it's thing. GOOD luck hope this helps. tell me if it doesn't work i'll try to help again
Feb 06, 2008 | Texas Instruments TI-84 Plus Silver...
Garbage Collecting
graphing calulators work much like computers. The have RAM space so they can remember what you have done recently and stuff like that. So when it's garbage collecting it means it's trying to find more space. This generally means that you don't have much much ARC or RAM space left. You can see this under your memerory manager. (2nd + enter) then you can reset your calculaor(2nd plus 7 1 2) or you can go to memory manager and unarchive your programs. Fur an example you have TI 84. Most new TI 84 have sientific tools. so if you don't you it take away the archive (*) by pressing enter and then hit DEL. the more RAM space and ARC space should make it so it doens't garababe collect. Hope this works. i can help you more if this doesn't work. GOOD LUCK
Jan 24, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-89 Calculator Logo
7,312 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
